![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 26, '07 From riverside,CA Currently Offline Reputation: 0 (0%) ![]() |
have any of you installed it yourself?
-------------------- QUOTE(thespacepanda @ Feb 21, 2008 - 4:37 PM) [snapback]644164[/snapback] When I worked for Pizza Hut our store won a health code violation. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 28, '05 From Redondo Beach, CA Currently Offline Reputation: 86 (100%) ![]() |
since i have tools to do it, its easy.
This post has been edited by LewFX: Jan 24, 2008 - 3:00 PM -------------------- ![]() |
how would you like to do mine?
![]() -------------------- QUOTE(thespacepanda @ Feb 21, 2008 - 4:37 PM) [snapback]644164[/snapback] When I worked for Pizza Hut our store won a health code violation. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 30, '06 From West Windsor NJ, USA Currently Offline Reputation: 14 (94%) ![]() |
I need to do this as well =/
-------------------- ![]() --------------------------------私は銀行に漂う,TRD Inspired |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 10, '04 From Shoreline, WA Currently Offline Reputation: 4 (100%) ![]() |
rotors are a very easy install, pretty much just take the tire off and swing the calipar up, the old onces should just pound off, just gata be careful and take your time as your cars breaks are extreamly important when it comes to stopping
QUOTE(hongkongnerdboy @ Jan 24, 2008 - 2:57 PM) [snapback]634119[/snapback] how would you like to do mine? ![]() charge you only 20 bucks to do it -------------------- ![]() |
Enthusiast ![]() Joined Jan 19, '08 From PA Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(creis @ Jan 25, 2008 - 1:36 AM) [snapback]634314[/snapback] rotors are a very easy install, pretty much just take the tire off and swing the calipar up, the old onces should just pound off, just gata be careful and take your time as your cars breaks are extreamly important when it comes to stopping ![]() Where'd you get the Brembo kit? I've been looking but all I can find is for the 00+. Did you do the front and rear? I'm wanting to upgrade sometime soon. |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 11, '06 From Sefner, FL Currently Offline Reputation: 24 (100%) ![]() |
did it this weekend for the 2nd time ever , easy. first time the how to helped tons
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 28, '07 Currently Offline Reputation: 1 (100%) ![]() |
QUOTE(LewFX @ Jan 25, 2008 - 9:29 AM) [snapback]634398[/snapback] QUOTE(hongkongnerdboy @ Jan 24, 2008 - 2:57 PM) [snapback]634119[/snapback] how would you like to do mine? ![]() charge you only 20 bucks to do it id haggle with him,mabye a steak dinner ![]() -------------------- BANNED. for life, you moron.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 14, '07 From Provo, UT USA Currently Offline Reputation: 25 (100%) ![]() |
really easy did it in a couple hours by myself. needless to say i was quite pleased with myself.a
![]() Enthusiast ![]() Joined Nov 8, '07 From Surrey, England Currently Offline Reputation: 0 (0%) ![]() |
When I changed my discs I had to buy one of these:
![]() As the previous owner / mechanic rounded off the caliper bolts. When reinstalling calipers you should use some loctite 243 on the caplier to car bolts, and possibly others if you've broken their seal, I took my calipers off in a different way to the how to as I wasn't changing pads. Quote from Loctite: "LOCTITE® 243™ is designed for the locking and sealing of threaded fasteners which require normal disassembly with standard hand tools. The product cures when confined in the absence of air between close fitting metal surfaces and prevents loosening and leakage from shock and vibration. Particularly suitable for applications on less active substrates such as stainless steel and plated surfaces, where disassembly with hand tools is required for servicing. The thixotropic nature of LOCTITE® 243™ reduces the migration of liquid product after application to the substrate." This post has been edited by SteveHall: Jan 29, 2008 - 6:36 AM |
Lo-Fi Version | Time is now: February 22nd, 2025 - 12:51 AM |
