Larger amp upgrade, Anybody have electrical problems? |
Jan 26, 2008 - 1:17 PM |
Enthusiast Joined Oct 31, '03 From Orlando, Florida Currently Offline Reputation: 0 (0%) |
Alright guys, I need some help with a new amp I'm getting... I've heard after 1000 watts rms you should upgrade the alternator as well as the batter and wiring. If I got a 1500 watt mtx thunder class d amp and ran 1 or 0 gauge wiring instead of my 4 now, would there still be problems with the alt? I just do not want to get this amp and then run into a lot of electrical problems. Also, my hifonics is about 900 rms right now and I havn't had a problem, which is why im considering this... Thanks for any help or advice everybody
This post has been edited by tim86: Jan 26, 2008 - 1:22 PM |
Jan 26, 2008 - 3:50 PM |
Enthusiast Joined Dec 14, '07 From yorktown Va. Currently Offline Reputation: 1 (100%) |
well you deff would have to upgrade the wire to 1/0ga
then about the elec system it would be a good idea to get a h/o alt, however you will prob run into the same problem that i am having which is find a alt to put out good power, the only thing that i have found from almost everyone is about 110 amps at idle, i think ohio gen could get me 140 amps at idle however it was almost 800$, if you are looking else where i would say iraggi and excessive amperage are good alternatives and the alt will run around 350$ and do about 110 at idle. However i am running around 2300 watts of the stock alt. i do however have a 1000cca everstart maxx up front and a g31 1000cca marine batt in the back, it seems to do fine however i still have huge voltage drops after a while. i would say go for the alt and get a good batt up front and you should be fine to go and im sorry i see that you have a gt so there might be better options for alts out there but i have a st and ran into a lot of problems trying to find an alt This post has been edited by itssteve: Jan 26, 2008 - 3:50 PM |
Jan 26, 2008 - 7:26 PM |
Enthusiast Joined Apr 10, '07 From lodi, ca Currently Offline Reputation: 9 (100%) |
i have the mtx thunder 550 right now hooked up to my kicker 10L7 and a 1.5 fared cap and it draws so much power that while driving my lights almost turn off lol im running 4 gage now and i like my system but not being ablke to see sucks so i only use it during the day i need to find a better alt also mines dieing ne ways lol i hope u have better luck with a bigger amp but be carefull the mtxs run alot higher then what they say mine says 550rms but after being tested runs at around 800 rms so becare not to blow your subs lol
Jan 26, 2008 - 11:20 PM |
Enthusiast Joined Nov 17, '07 Currently Offline Reputation: 0 (0%) |
I hope you are also thinking about a high farad cap...
Jan 27, 2008 - 4:11 AM |
Thanks for the input guys, I have a big cap but I've heard caps and batts are really only good when playing music with the car off... I'm just tired of the hifonics because I know my type R's can be much louder and handle a lot more power, plus the type r's are dual 2 ohm so I have them running at 2 ohms... I really just want to know how long the alt will hold up since the mtx pushes 1000rms @2ohms and its underrated so it should be around 1200 which is about 300 more than my hifonics and I havnt had any problems... Just wanted to know if anybody has ran into any problems with huge mono amps.
Jan 27, 2008 - 4:39 AM |
tim, its good practive to buy a heavy duty alternator when adding anything with 1000watt... you might not need it always, but do you want to get caught the day that it wont be able to keep up, and the day it dies because there was too much strain on it..
Jan 28, 2008 - 8:02 AM |
Enthusiast Joined Sep 23, '04 From Ohio Currently Offline Reputation: 4 (100%) |
I was running a kx1200.1 kicker amp to 2 L7's and had a second kinetic battery. The amp was rated at 1374 watts, and i ran it all day long no problem. I only had 4 gauge wiring also.
Jan 29, 2008 - 5:58 PM |
QUOTE(dustinkemp @ Jan 28, 2008 - 8:02 AM) [snapback]635290[/snapback] I was running a kx1200.1 kicker amp to 2 L7's and had a second kinetic battery. The amp was rated at 1374 watts, and i ran it all day long no problem. I only had 4 gauge wiring also. Really? I appreciate your feedback... So even with a second battery you still didnt have any problems... hmm well i think il be fine then because i was looking at an mtx or maybe something kicker which are both power hungry |
Jan 30, 2008 - 12:57 AM |
Enthusiast Joined Feb 28, '07 Currently Offline Reputation: 1 (100%) |
i would just get a bigass cap if i were u...
-------------------- BANNED. for life, you moron.
Jan 30, 2008 - 8:35 PM |
QUOTE(tim86 @ Jan 29, 2008 - 7:58 PM) [snapback]635811[/snapback] QUOTE(dustinkemp @ Jan 28, 2008 - 8:02 AM) [snapback]635290[/snapback] I was running a kx1200.1 kicker amp to 2 L7's and had a second kinetic battery. The amp was rated at 1374 watts, and i ran it all day long no problem. I only had 4 gauge wiring also. Really? I appreciate your feedback... So even with a second battery you still didnt have any problems... hmm well i think il be fine then because i was looking at an mtx or maybe something kicker which are both power hungry With the 2nd battery and the amp turned up, I got a little dimming, But that was very rare cause i only had the amp up at competitions. even with it down everyone in town hated it cause it was so loud lol. I havent heard too much about mtx, but since i got into kicker equpiment, ill never go to ne thing else! and I looked at the birth sheet again and its rated 1440, not 1374 -------------------- |
Lo-Fi Version | Time is now: December 3rd, 2024 - 2:37 PM |
