www.google.com
take off the timing belt cover and look. pretty simple thing to do.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) ![]() |
I'll that that after class tomorrow and I just hope it warms up.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Enthusiast Joined Jan 21, '08 From ON. Canada Currently Offline Reputation: 0 (0%) ![]() |
Same thing happened to me, it turned out to be a loose ground wire that was preventing my car from starting.
I dont understand how a ground wire can go loose? I didn't do any crazy driving.
Vibrations are enough. Lock-tite is your friend.
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(bccentaur3 @ Jan 29, 2008 - 6:25 PM) [snapback]635866[/snapback] WOW. I should've known better than that. The alternator belt is still good. Thanks a lot man. You had me running out side in -35 degrees. the reason why i dont think its the timing belt is because if your belt snapped your car will shut off immediately. Like BOOM dead. when an alternator belt snaps you run on the battery until your battery dies. This will take a while as your battery drains and your computer and ignition system slowly fails, you feel loss of power. I had this happen to me and had to floor it in first gear to slowly crawl my way back to my house. easy way to check if your timing belt snapped is take off the distributor cap ( 3 scews) and crank the engine. If the rotor in there spins, then your belt is fine. If it doesnt not move then your timing belt has snapped. Your engine ground can also cause this problem. Check the thick cable that goes from your valve cover to the radiator support. If in, doubt hook a jumper cable to the engine and the ground. See if it starts? How does your car sound when you try to start it? Does it crank really fast or is it a slow unwilling crank? |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Portsmouth, RI Currently Offline Reputation: 33 (100%) ![]() |
QUOTE(Supersprynt @ Jan 29, 2008 - 10:11 PM) [snapback]635895[/snapback] It may be an interference vs. non-interference motor thing. exactly. if a belt breaks the car will just die, no abnormal noises or anything, just dead. if a timing CHAIN breaks you will hear it and it won't sound good. -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) ![]() |
QUOTE(Supersprynt @ Jan 29, 2008 - 10:11 PM) [snapback]635895[/snapback] I think there's way to do it via rotating the distributor but I'm not sur ehow. Makes sense. The distributer is attached to the intake cam so if he rotates it by the rotor and it moves - the belt snapped. BTW - You keep saying the car won't crank. Do you really mean that or do you mean it will crank but won't turn over? If it won't crank it's not the belt. If the belt broke then the crank will turn with the starter but the cams won't so you will not get spark to the engine via the not turning distributer. Can you clarify that point? -------------------- ![]() ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Well the car cranks, but won't turn over, sorry
![]() -------------------- 98 Celica gt red- totaled deer
Turn over is cranking...turning over isn't starting.
If you left the hazards on all night your battery is def. dead. This post has been edited by Supersprynt: Jan 30, 2008 - 11:44 AM -------------------- |
yeah, very stupid, but I'll check my timing belt and any loose grounds later and keep you guys updated.
Enthusiast ![]() ![]() ![]() ![]() Joined Dec 14, '06 From MN, USA Currently Offline Reputation: 2 (100%) ![]() |
-45 tonight in MN. Good luck man.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) ![]() |
that's what propane is for roasty toasty in my garage. so what happened to the 40 degree weather. where do you live i can prob give ya a hand on diagnosis?
This post has been edited by rjbibeau: Jan 30, 2008 - 12:32 PM -------------------- ![]() |
I live in Fridley.
I have work tonight so I won't get to work on my car until tomorrow. Give me a call if you want to help. Tomorrow should be warmer. -------------------- 98 Celica gt red- totaled deer
Enthusiast ![]() ![]() ![]() Joined Jan 20, '08 From East Coast Currently Offline Reputation: 1 (100%) ![]() |
QUOTE(Supersprynt @ Jan 29, 2008 - 10:11 PM) [snapback]635895[/snapback] QUOTE(hurley97 @ Jan 29, 2008 - 10:04 PM) [snapback]635891[/snapback] and Erik, yes you would lose power immediately but it won't knock really bad or anything, it would pretty much just act like it stalled. It may be an interference vs. non-interference motor thing. Def. can be the belt, cold temps don't help - get in there and check. I think there's way to do it via rotating the distributor but I'm not sur ehow. If the celicas are interference and he snapped a timing belt, than pretty much you can assume there's now bent valves, damaged pistons, etc., etc. I have a 96 GT I picked up almost 2 weeks ago (first celica ever) and I don't even know if they are interference engines. My talon was. |
![]() Enthusiast ![]() Joined Nov 20, '03 From Derry, NH Currently Offline Reputation: 2 (100%) ![]() |
QUOTE(6G96GT @ Jan 30, 2008 - 9:25 PM) [snapback]636118[/snapback] QUOTE(Supersprynt @ Jan 29, 2008 - 10:11 PM) [snapback]635895[/snapback] QUOTE(hurley97 @ Jan 29, 2008 - 10:04 PM) [snapback]635891[/snapback] and Erik, yes you would lose power immediately but it won't knock really bad or anything, it would pretty much just act like it stalled. It may be an interference vs. non-interference motor thing. Def. can be the belt, cold temps don't help - get in there and check. I think there's way to do it via rotating the distributor but I'm not sur ehow. If the celicas are interference and he snapped a timing belt, than pretty much you can assume there's now bent valves, damaged pistons, etc., etc. I have a 96 GT I picked up almost 2 weeks ago (first celica ever) and I don't even know if they are interference engines. My talon was. 5sfe are not interference motors -------------------- |
it is very simple to tell if you have a snapped timing belt.
pull off the distributor cap. try and start the motor. if the rotor spins, the belt is still connected. if it dont, time for a timing belt job. -------------------- Former Team 5SFTE pro member ;)
Enthusiast Joined Jan 29, '08 From Australia Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(bccentaur3 @ Jan 29, 2008 - 8:23 PM) [snapback]635843[/snapback] ![]() Remove the distributor cap and spin the motor, if the distributor shaft turns the cam belt is intact, however it could have jumped a few teeth which would put your valve timing out and cause a loss of power. Broken belt!!! it cannot run at all. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 2, '05 From Guam Currently Offline Reputation: 15 (100%) ![]() |
From my experience, I've seen a car lose power and won't turn on again after your water pump goes. Also, Fuel Pump. Alternator is pretty easy to test because your car does not need the alternator to turn on, assuming you have a good battery, you can test the alternator.
Lo-Fi Version | Time is now: February 20th, 2025 - 1:12 AM |
