1996 Celica GT, When Stopped car revs |
Jan 30, 2008 - 10:15 PM |
Enthusiast Joined Jan 20, '08 From East Coast Currently Offline Reputation: 1 (100%) |
So I've had my celica for 2 weeks, it runs awesome. Anyway it's a 5 spd MT (don't know if that matters for this thread) anyway today for the first time since I've had it, when I came to a stop after about 20 minutes of city driving, it revved and stayed at about 1500 rpms until I "tapped" the gas pedal and then it dropped back down to its normal 900 rpms at idle. Then, later again today I took it out (and it is freezing outside) and this time it revved to 2K rpm at idle until I "tapped" the gas pedal again and then it came down to normal 900 rpms.
What's up with that? I just did a full tune up last week (properly gapped), fresh oil/filter yesterday, it has an injen ram air intake (properly hooked up) and then I just checked the throttle spring in the engine and it didn't seem to stick at all. So...... This post has been edited by 6G96GT: Jan 30, 2008 - 10:17 PM |
Jan 30, 2008 - 10:21 PM |
Enthusiast Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
Did you sea foam the car during your tune up session? It could be a dirty IAC?
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Jan 30, 2008 - 10:24 PM |
no, I didn't. I just want to clarify tune up (not tune). Usually tune "sessions" are tuning.
Jan 30, 2008 - 10:31 PM |
Enthusiast Joined Jul 22, '06 From San Antonio / georgetown, Texas Currently Offline Reputation: 9 (100%) |
mine did this for awhile, i just used some wd-40 on the throttle cable inside the engine bay(sorry for my lack of car vocab) and that seemed to stop it after a few days. not really sure if what i did solved the problem but it did stop shortly after i used the oil.
Jan 30, 2008 - 10:32 PM |
I'll give that a try tomorrow and see if it helps. You said it stopped a couple days "after" you sprayed it? Should I just spray the whole assembly (the bracket and wire)?
Jan 30, 2008 - 10:56 PM |
yea i pretty much just sprayed the whole thing. hope it works for you.
Jan 31, 2008 - 12:01 AM |
Enthusiast Joined Nov 1, '07 From Santa Barbara, CA Currently Offline Reputation: 2 (100%) |
um thats kinda sketch...I definitely recommend removing the iac and cleaning it manually. I hear sea foam or power foam sprays can give your car a miss.
Lo-Fi Version | Time is now: November 23rd, 2024 - 9:41 AM |
