![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '07 From Portland, Oregon Currently Offline Reputation: 67 (96%) ![]() |
Due to an oversight, the image used for August in the 2008 Celica calendar printed in low resolution. I was able to obtain the high-resolution image and format it to the same specs as it appears in the calendar. For those of you who wish to download the revised image, you may do so here (6.8 MB):
High Res August 2008 image In order to view the image, you will need Adobe Acrobat Reader which can be downloaded for free at http://www.adobe.com. It is available for most platforms out there. The image is sized 11" w x 8.753" h, and as such will need slight trimming on the height. If this is a major problem for anyone, I can resize and repost the image. I just figured it allows for some extra room if needed. For optimal output quality, if you do not have access to a color laser printer (which, don't forget, will NOT print all the way to the edges), it is my recommendation that the file be output onto 11 x 17 (Tabloid) size paper by a service bureau such as Kinko's. You can even upload your file to them online and have them print it out if you don't want to burn it to a CD. Here's a direct link to that service. Please feel free to address any concerns about the image or download in this thread. If you opt to use the Kinko's online service, please read through the instructions on their site thoroughly before posting here about it. I've used this service of theirs MANY times, and have literally uploaded documents containing hundreds of pages several times this way. Basically I've had thousands of jobs printed this way... it's really easy and self explanatory on their site. Thanks, Michelle -------------------- ![]() |
I'll do a Monday bump - is anyone downloading the image though? If not I won't bump any more.
Lo-Fi Version | Time is now: February 22nd, 2025 - 12:45 AM |
