Closed TopicStart new topic
> FS: 2.5" SS Magnaflow Cat, Sold. Thanks !!!
post Feb 1, 2008 - 5:29 PM
CaliJeff
Joined Apr 22, '07
From Bay Area, California
Selling cat because i thought it was OBD II. It is actually OBD I & CARB approved. Welding will be needed to get it on the car. I never used it. It is out of the box. Body is Stainless Steel and along with the ends. WIll ship via UPS and will give tracking number. I paid around 75 with tax. Yours for 65 shipped. Feel free to pm me with any questions.
This post has been edited by CaliJeff: Feb 20, 2008 - 4:56 PM
You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=-
post Feb 1, 2008 - 5:36 PM
Celicav
From Virginia
post Feb 1, 2008 - 5:44 PM
CaliJeff
Joined Apr 22, '07
pm replied. BTW, here is an overview of the cat.
Inlet Quantity: Single
Inlet Diameter (in): 2.500 in.
Converter Inlet Attachment: Slip fit
Outlet Quantity: Single
Outlet Diameter (in): 2.500 in.
Converter Outlet Attachment: Slip fit
AIR Tube: No
Converter Case Material: Stainless steel
Converter Substrate Material: Ceramic honeycomb
Heat Shield: Yes
Converter Overall Length (in): 16.000 in.
Converter Overall Thickness (in): 4.000 in.
Converter Overall Width (in): 6.500 in.
Converter Style: 3-way
GVW (lbs): 6,000 lbs.
* A ribbed body that minimizes expansion and distortion when the converter heats up. The ribs form a channel that protects the cushioning mat from direct exposure to exhaust gasses, and they hold the ceramic catalyst in proper alignment.
* A 1/2 in. lap joint where the necks meet the body. The neck does not extend into the converter body, where it could hamper exhaust flow.
* Manufactured with separate dies on different sized inlets. Putting larger neck sizes on smaller bodies would reduce the flow of the converter and the quality of the product.
* A monolithic honeycomb catalyst. The ceramic is designed for maximum flow and surface area. The coating method is strictly controlled to maintain exact specifications. An improper coating could result in flow restrictions or an emissions test failure.
* Seam-welded close to the converter body for a strong, tight bond. Welding along the edge could allow the converter to expand like the folds in an accordion, allowing the catalyst to move around.
* Heavier-gauge stainless steel, tip-to-tip. Other manufacturers use mixed weights and materials.
* An aluminized or stainless OEM-style ribbed heat shield that creates a rigid wall of protection against heat and adds to the structural stability of the converter.
post Feb 3, 2008 - 2:42 AM
Fate
Joined Nov 30, '04
From Atlantic City
if celicav bails i'll buy most likely.
post Feb 3, 2008 - 12:51 PM
CaliJeff
Joined Apr 22, '07
alright, i'll let u know. should be within a couple days.
post Feb 3, 2008 - 3:08 PM
Celicav
From Virginia
I'm out. Sorry, That is why I did not PM back. I think I would rather get a 2.25 to match my current piping. Thanks!
post Feb 3, 2008 - 8:57 PM
CaliJeff
Joined Apr 22, '07
Update: I also have a OEM stock cat as well with approx 120 k miles on it. 45 shipped
Magnaflow converter is still availble. Ideal cat for a 5sfte or 7afte project !
This post has been edited by CaliJeff: Feb 3, 2008 - 8:58 PM
post Feb 5, 2008 - 12:19 AM
CaliJeff
Joined Apr 22, '07
bump
post Feb 5, 2008 - 2:30 AM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
Will you take $40 shipped for the stock cat?
post Feb 5, 2008 - 11:13 AM
CaliJeff
Joined Apr 22, '07
if you are in US, then 40 is fine. If you over oversea, it might be like 5 dollars more, i'll get a quote when the UPS store opens up in like 20 minutes.
post Feb 5, 2008 - 11:48 AM
DEATH
Joined Dec 19, '07
From tx
How about $55 shipped to 77040 for the magnaflow?
This post has been edited by DEATH: Feb 5, 2008 - 11:53 AM
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Feb 5, 2008 - 4:18 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
QUOTE(CaliJeff @ Feb 5, 2008 - 8:13 AM) [snapback]638287[/snapback]
post Feb 5, 2008 - 5:21 PM
CaliJeff
Joined Apr 22, '07
u have pm maskedman
post Feb 5, 2008 - 5:41 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
QUOTE(CaliJeff @ Feb 5, 2008 - 2:21 PM) [snapback]638410[/snapback]
u have pm maskedman
Payment sent.
post Feb 5, 2008 - 6:04 PM
CaliJeff
Joined Apr 22, '07
Magnaflow cat: Sale pending
OEM Cat: Sold
post Feb 20, 2008 - 4:00 PM
DEATH
Joined Dec 19, '07
From tx
Magnaflow is mine and paid for!
EXT: WRC/TRD/404
post Feb 20, 2008 - 4:54 PM
CaliJeff
Joined Apr 22, '07
Lol. Updated status, everything is sold. Thanks guys !
Lo-Fi Version Time is now: April 20th, 2025 - 7:48 PM
