> push button start
post Feb 2, 2008 - 5:51 PM
turboman23
Joined Jan 25, '08
From Topeka, KS
ok, i've got a push button start in my car. it just kinda hangs there over by the left vent. so i think to myself, "i'm gonna move it over by my cd player, that should be easy enough". so i unhook it, run the wires through, tighten the wires back down and i go to start it but nothing happens. any ideas???
1st car- 1994 Celica GT 2.2L 5s-fe SOLD
2nd car- 1995 Celica ST 2.0L 3s-gte SOLD
Current car- 1996 Z28 Camaro 5.7L LT1
post Feb 2, 2008 - 5:56 PM
Mangozac
Joined Mar 13, '07
From Gold Coast, QLD, Australia
Does it have two wires or just one going to the switch? How did you extend the wires? If you did extend the wires did you use the same cable size? Any pics?
post Feb 2, 2008 - 6:09 PM
turboman23
Joined Jan 25, '08
From Topeka, KS
QUOTE(Mangozac @ Feb 2, 2008 - 5:56 PM) [snapback]637286[/snapback]
i'm pretty sure two wires. i didn't extend anything. all i did was move the wires that were already there over a foot. here's a pic. of the button. and yes, thats how the wires were hooked up when i got it.
post Feb 2, 2008 - 6:17 PM
Havok1997GT
Joined Nov 23, '07
From Houston TX
you might have disconnected the connection somewhere when you moved it around, Follow the wires and see if you can find any break or if a ground is loose.
post Feb 2, 2008 - 6:22 PM
turboman23
Joined Jan 25, '08
From Topeka, KS
QUOTE(Havok1997GT @ Feb 2, 2008 - 6:17 PM) [snapback]637294[/snapback]
kk, i was just talking on the phone with a buddy. and he said the same exact thing.lol. i'll go try that. thanks.
post Feb 15, 2008 - 7:02 PM
addictions
Joined Sep 26, '07
From iowa
QUOTE(turboman23 @ Feb 2, 2008 - 6:22 PM) [snapback]637296[/snapback]
use a DMM or a volt meter and test the wires see if u can get a reading or not
-Boss III
post Feb 17, 2008 - 3:08 PM
cjh4l22
Joined Oct 18, '06
From cincinnati
want info on the push button start.... !
post Feb 18, 2008 - 11:23 PM
cjh4l22
Joined Oct 18, '06
From cincinnati
post Feb 18, 2008 - 11:34 PM
turboman23
Joined Jan 25, '08
From Topeka, KS
QUOTE(cjh4l22 @ Feb 18, 2008 - 11:23 PM) [snapback]643012[/snapback]
o ok! u just wanting to know what happened? it was just a bad fuse....
post Feb 18, 2008 - 11:39 PM
cjh4l22
Joined Oct 18, '06
From cincinnati
ha well that and... where'd u get the push button start? or how'd u set it up?
This post has been edited by cjh4l22: Feb 18, 2008 - 11:40 PM
post Feb 19, 2008 - 8:32 AM
turboman23
Joined Jan 25, '08
From Topeka, KS
it was already set up when i got the car but the button you can get at advance autoparts for $4, its a switch thats meant for a horn or something like that. umm...if it helps, it bypasses my neutral safety switch. when it gets warmer out and i'm not working, i'll try to see how its wired and let ya'll know.
post Feb 19, 2008 - 10:47 AM
D-Man
Joined Jan 18, '08
From Houston
QUOTE(turboman23 @ Feb 19, 2008 - 8:32 AM) [snapback]643168[/snapback]
it sounds like a hot-button to me... i bet it doesn't require the key at all to start does it? If its wired off of presure switches and stuff, sounds like the previous owner just slaped that in there...
Usualy push starts have more parts depending on features, that address security issues, ect. your ignition switch is just a switch, only the key completes the circut as you turn it. It requires power from a constatnt source (battery) and sends it to your acc feed,(witch starts your fuel pump, and readys the engine for startup) then it transfers to your ignition startup (starter, solonioid ect.) and that's what starts your car.
Like (and i dont like to use this term; nor do i endorse it. I am not affiliated with 6gc.net) "hot-wiring" a car, requires taking the constant, the acc. and the startup and putting them together. This hot-button is a switch between the constant; and the acc/ignition lines.
with real setups, they can bypass the key provided that your in park, but require it to take the car out of park. or for manuel transmitions, out of gear, or via the parking break.
*EDIT* MODS, please dont delete my account for using the H/W word... i was referencing not endorsing!!
This post has been edited by D-Man: Feb 19, 2008 - 10:50 AM
Damn D-Man - most impressive.
post Feb 19, 2008 - 4:15 PM
turboman23
Joined Jan 25, '08
From Topeka, KS
no u still need the key to start it. rolleyes.gif that would defeat the purpose of having a "key" tongue.gif
post Feb 19, 2008 - 4:58 PM
D-Man
Joined Jan 18, '08
From Houston
QUOTE(turboman23 @ Feb 19, 2008 - 4:15 PM) [snapback]643298[/snapback]
But i've seen people do it... I had to do it a few years ago, due to the fact that i bought a car that had no keys, so for 3.5 months untill i got the car re-keyed by a locksmith, i never locked the doors and just had it wired up like that!!
But no-one wanted to steal this:
Lo-Fi Version Time is now: November 27th, 2024 - 8:42 PM
