> engine code 54, been on since swap
post Feb 3, 2008 - 5:19 PM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
well ive been workin on the car and that dame check engine finally is getting to me. i check it out and it comes out to be 54..check it out on alldata and it says something like p1 squib line to p2 squib line.. asking around its something about the air bag?? wiring harness was made by dr.tweak and i am sure i put the engine in right. just cant seem to get rid of the dame code..anyone have a clue help please.
post Feb 3, 2008 - 5:40 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
from troublecodes.net/toyota
DTC 54 - Inter-cooler ECM signal
if it had something to do with the airbag system your airbag light would be on, not the check engine light.
I <3 Dustin---07/16/06
post Feb 3, 2008 - 7:27 PM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
yeha i just got done doing what insanity-74 posted up..doesnt seem to be working. i got to look at the wiring harness again. yeah i also have 2 wires just sitting there what dr. tweak wrote on there i think was evp. does that have anything to do with the check engine light on..
This post has been edited by RUNNIN-LOW: Feb 3, 2008 - 8:37 PM
post Feb 3, 2008 - 8:47 PM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
code 54 is the intercooler level sensor fault.
are you running the stock wta intercooler? does it have fluid in it?
if not then you need to bridge the connection (cut and join the two wires that previously went to the intercooler coolant level sensor togther)
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
post Feb 3, 2008 - 9:01 PM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
yeah im runnin a front mount right now. i think i bridge the connection together correctly. now the problem is the did i bridge the right one. the only plug that doesnt have a male connection only has a black/yellow and a yellow/blue wire. i think the one that goes to the intercooler has three wires. i now also see that i need to get a new evp sensor cause i just have two expose wires just sitting there. but the code is still 54 so im still tryin to figure out where tweak placed the coolant lvl sensor plug..?
post Feb 3, 2008 - 9:03 PM
Cuts_the_Pilot
Joined Dec 15, '02
so your using the OE ecu, what are you doing about the intercooler coolant pump?
also code 54 puts you in limp mode, meaning your loosing valuable hp
This post has been edited by Cuts_the_Pilot: Feb 3, 2008 - 9:04 PM
post Feb 3, 2008 - 9:13 PM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
yeah i have the oe ecu. where is the coolant pump located on the motor. i dont see anything that looks like the coolant pump. now that u say that i do feel as if the car isnt at its full potiental anymore.
post Feb 3, 2008 - 9:16 PM
Cuts_the_Pilot
Joined Dec 15, '02
the coolant pump is electric, hence can give error codes. The pump in its stock location is under the passenger (well driver in your case) guard, under and beside the resonator air box. the wires for it is some funky setup where 5 wires merge into two and go into the pump.
post Feb 3, 2008 - 9:23 PM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
well my car is orignally a 5sfe (st204) body so i dont have the pump. now all i have to figure out is where dr. tweak put the ECM sensor. i have just one plug that isnt connected to anything and im tryin that out.
post Feb 4, 2008 - 12:18 AM
phattyduck
Joined Dec 5, '05
From LA, CA
Are you running an ST185RC or ST205 motor?
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Feb 4, 2008 - 2:13 AM
Insanity-74
Joined Jan 9, '05
From Under the car
How to wire in a substitute to the chargecooler pump to fool the ECU (ST205)
This post has been edited by Insanity-74: Feb 4, 2008 - 2:14 AM
post Feb 4, 2008 - 10:40 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(Insanity-74 @ Feb 4, 2008 - 1:13 AM) [snapback]637761[/snapback]
That will only work if Tweak left the ST205 pump wiring in place and added the Intercooler Relay, if that doesn't work this will:
Just a relay and a couple resistors connected to the ECU.
post Feb 4, 2008 - 1:21 PM
DEATH
Joined Dec 19, '07
From tx
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Feb 4, 2008 - 4:24 PM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
wow thanks guys yeah im runnin a st205 motor. and let me try talkin to dr.tweak first then ill try and do the wiring.. thanks for all the help ill let yah know how it goes
going to post up pictures of the only wires exposed (pink/gray and black /yellow) i think is the evp sensor wires no clue what connects to it and the connector that i thought was the intercooler lvl sensor plug grey/red stripe and white/black stripe.
This post has been edited by RUNNIN-LOW: Feb 4, 2008 - 4:42 PM
post Feb 4, 2008 - 4:47 PM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
sorry not 56k friendly..kinda blurry took the picture really fast.
This post has been edited by RUNNIN-LOW: Feb 4, 2008 - 4:51 PM
post Feb 5, 2008 - 1:08 PM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
I can't see the pics, broken links?
Yeah the Evap plug is just fine if left unplugged, it just connects to a sensor on the ST205's evap canister for emissions. Mine has been unplugged for months now and it runs perfect, no codes.
A Code 54 will pop up if the intercooler water level gets too low, if the water level sensor is bad, or if there is an error with the pump in any way. This will also occur if the pump isn't connected, because the ECU will trigger a Code 54 if the resistance load isn't there from the pump being present. Unless Tweak wired this properly to compensate for the lack of a level sensor or pump, then it will trip a code 54.
In order for your stock 3rd gen ECU to be happy with a FMIC, the two wires for the intercooler water level sensor must be jumped, as well as wiring in the resistors like WannabeGT4 posted for the intercooler pump wiring.
Have Tweak examine how he wired your harness and have him follow the schematic that WannabeGT4 posted....it should be a very easy fix, since not much is needed at all to make the ST205 harness work on a ST204
-Corey
Lo-Fi Version Time is now: November 28th, 2024 - 12:12 AM
