> 5sfe stock hp
post Feb 3, 2008 - 11:57 PM
JasonX
Joined Oct 18, '07
From Orange County, CA
hello guys,
just wondering when 5sfe supposingly says it's 135hp, is it really 135 hp? and what's the difference between hp and whp? i was wondering 'cause I heard the gains from cams is 20-30 hp. so, if I had colt cams and injen sri, could i claim 160 hp. just don't wanna say I have around 160 hp and bs myself biggrin.gif.
thanks
post Feb 4, 2008 - 12:23 AM
goferris
Joined Feb 14, '07
From Provo, UT USA
QUOTE(JasonX @ Feb 3, 2008 - 9:57 PM) [snapback]637719[/snapback]
hello guys,
thanks
the diff between hp and whp is hp is the power to the crank where whp is power to the wheels. i believe the also call it bhp or braking horse power. as far as i know the 5sfe has a measly 110 whp frown.gif if that
post Feb 4, 2008 - 12:58 AM
96bluevert
Joined Mar 19, '07
From Washington
QUOTE(Batman722 @ Jan 12, 2008 - 4:55 AM) [snapback]630164[/snapback]
1995 GT 158K miles
2.2l 5s-fe
hardwelded camshafts (grind 294)
header, cat back exhaust
123.59 hp @ 5811 rpm
126.84 tq @ 4179 rpm
the closest dyno test to stock hp for the 5sfe I've seen on here.
post Feb 4, 2008 - 6:35 AM
QUOTE(JasonX @ Feb 3, 2008 - 11:57 PM) [snapback]637719[/snapback]
hello guys,
thanks
its 135 FLYWHEEL hp.
dustins dyno is WHEEL hp.
2 diffrent things.
post Feb 4, 2008 - 10:26 AM
96bluevert
Joined Mar 19, '07
From Washington
also thought it would be useful to answering the question.
This post has been edited by 96bluevert: Feb 4, 2008 - 10:27 AM
post Feb 4, 2008 - 11:09 AM
CelicaGT04
Joined Nov 22, '05
From Mesquite, Texas
Do not overlook Dustin's mod's that he has to his celica at the time of the dyno.
It claims he had:
Now that to me, is by no means STOCK.
135 crank HP might be found in a well maintained slightly high mileage 5SFE, but for a typically abused motor with over 100XXX one can only fathom the loss of HP.
Basically, the only way you can get a real look at your HP is to dyno your car, everyone has different results, even with the same mods.
post Feb 4, 2008 - 5:10 PM
heres what a good condition, lower mile 5s will look like on the dyno.
this is with a injen short ram intake only.
this is from my car, pre turbo.
the engine had under 55K on it.
post Feb 4, 2008 - 8:58 PM
JasonX
Joined Oct 18, '07
on this dyno what's the line that initially starts low, and what's the higher one?
This post has been edited by JasonX: Feb 4, 2008 - 8:58 PM
post Feb 6, 2008 - 7:09 PM
Jaws4God
Joined Mar 27, '04
I don't know if I have my dyno sheet but I got 99 whp with a short ram intake and muffler only... pretty much stock..
post Feb 6, 2008 - 11:42 PM
Rusty
Joined Nov 5, '07
From New Zealand
the top one is for torque(unless we all have 125HP at idle)[use the right axis to find the reading]
the lower one that starts off is the power (HP)[use the left axis to find a reading]
so looking at rpm (right down the bottom) 90HP @ 3750rpm
(hope I dont sound like a school teacher)
post Feb 7, 2008 - 12:28 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(JasonX @ Feb 5, 2008 - 1:58 AM) [snapback]638065[/snapback]
The first dyno is not what a stock 5SFE dyno looks like. That's vastly improved over stock by about 10-20whp depending on the motor's condition, and the torque curve is significantly better. Typical 5SFE's will run out of breath around 4500 rpms and the torque dips significantly. The top dyno doesn't lose much torque until around 5300-5400 rpms. That is a significant difference in terms of accelerating the car. IMO, whoever that dyno belongs to, can still squeeze extra power with some good cam tuning.
As far as which is which, the flatter line that starts flat is usually the torque (applies to most engines) and the line that climbs as the rpms increase is horsepower.
Lo-Fi Version Time is now: January 5th, 2025 - 9:14 PM
