> 15mpg on my ST wtf?
post Feb 5, 2008 - 12:00 AM
mikecelica
Joined Jan 31, '07
From Ontario, Canada
i recently was tryna do my gauges and broke the pointer for the gas gauge and the little ACTUAL NEEDLE that is inside a lil motor which controls the fuel gauge. anways i couldnt fix it and now my gauge is broken but after about 300km = 190miles , the gas light comes on. so do the actual needle and whatver controls the gas light work together as in if one gets messed up so is the other or no. cuz it cant be possible im gettin half the fuel economy i shud be getting. my car is pretty stock, i checked gas tank and lines no leak anywhere..??? THANKS FOR ANY HELP.
post Feb 5, 2008 - 1:10 AM
mikecelica
Joined Jan 31, '07
anyone know?
post Feb 5, 2008 - 8:40 AM
illneversellmyce...
Joined Jul 11, '06
From Sefner, FL
the guage jsut reads an electrical signal it doesnt actually control the fuel consumption im pretty sure off. ive never heard of an st loosing that much mileage, i would seriously suggest taking it to a shop to run an eng code check and see if any error codes come up. Also make sure they check the fuel system, fuel pump, fuel filter injectors etc
post Feb 5, 2008 - 9:59 AM
1900WattCelica
Joined Jul 7, '04
From Germantown, WI
If you really want to check your gas mileage just fill up until the nozzle auto shuts off, take note of the station and pump you used, reset your trip odometer, and drive for a few days. Then fill up at the same pump until it auto shuts off and then divide the distance on your trip odo by the liters you pumped. You don't need a gas gauge to determine gas mileage.
post Feb 5, 2008 - 3:02 PM
red94celicast
Joined Feb 4, '08
From Brunswick, Ohio
jw..how many gallons can a 94 st coupe hold?
Totaled 3-10-08 =[
-Someone pulled out in front of me, so wasn't my fault.
*Just got the insurance check*--> I paid $2700 for my celica and i got $3200 from insurance. Nooice another 6GC Coming soon!!!!!!!!!!!!!!!!
post Feb 5, 2008 - 4:00 PM
laff09
Joined Jul 28, '06
From Delaware
bad o2 sensor.
mikecelica
Joined Jan 31, '07
about 50 something litres = 11 gallons
post Feb 5, 2008 - 4:06 PM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
i think an st holds more to 14.5 15 gallons.
my fuel light comes on a 1/4 tank left... and that gives me another 120 or so miles. never ran outta fuel.
i just note the trip milage when the light comes on, add 100, and get gas when it gets there
seems like something may be setting your gas light on sooner than it should be
post Feb 5, 2008 - 4:14 PM
mneal2_92788
Joined Nov 7, '06
From Lawrence IN, 46226
its 15.9 for a GT....well close to that. im sure the st isnt too far off
post Feb 5, 2008 - 4:57 PM
QUOTE(red94celicast @ Feb 5, 2008 - 3:02 PM) [snapback]638349[/snapback]
QUOTE(mneal2_92788 @ Feb 5, 2008 - 4:14 PM) [snapback]638378[/snapback]
correct. It's actually 60 liters (15.85 gallons) for ST and GT, same tanks.
no dount you have a bad 02 sensor.
post Feb 5, 2008 - 6:18 PM
CelicaProgress
Joined Jan 15, '08
From Secaucus NJ
Mine fills up at like 12.3 or sumthing
Lo-Fi Version Time is now: November 23rd, 2024 - 3:42 AM
