> greddy emanage ultimate
post Feb 5, 2008 - 3:41 PM
1994toyotaracer
Joined Sep 2, '05
From delaware
hey guys i see everyone has came to the conclusion that the greddy emanage ultimate is the way to go i just have some questions like
1 whats the big difference between the enanage and emanage ultimate
2 does anyone have a write up on how to install and wire
3 what harnesses do you need for it like igntition injector etc
4 does anyone have basic tunning settings
and 5 where is the cheapest place to get one
thanks
post Feb 5, 2008 - 6:33 PM
QUOTE(1994toyotaracer @ Feb 5, 2008 - 3:41 PM) [snapback]638365[/snapback]
you can control the injectors independantly of airflow. in other words, the emanage "blue" controls fuel much in the same manner as the SAFC, by manipulating the MAP signal. the "ultimate" can do this, and also control the injector outputs from the ECU, and modify the opening time of the injectors, without changing the MAP signal
i made a "cheat sheet" a while back, when i got mine, but there are options on setting it up ect that will require your own work.
i have yet to get the ignition side of it working properly with my car.
i got the coplete harness.
you need to set it up based on what features you are going to use, then you need to tune your car with a wideband, preferably on a dyno. using someone elses "settings" is not a good idea, every engine is a bit diffrent.
youll have to shop around for that, remember, sometimes the cheapest isnt the best. wink.gif
thanks
post Feb 6, 2008 - 6:35 AM
Tony_the_Tiger
Joined Dec 2, '07
From Canada
thanks
As presure2 stated already, the Ultimate can modify the actual injector duty cycle.. It can intercept the injector wire and modify the fuel without affecting anything else.
The other main advantage of the Ultimate is temperature correction. The Ultimate has both water temp and air temp correction which is absolutely necessary for a good tune. The E-manage blue will need constant retunes when weather changes, which I do have a fair share of customers coming in each winter for retunes with the E-manage blue.
One other feature I like about the Ultimate is the ability to drive 4 additional injectors on a 4cyl engine. You can literally set it up so it fires accordingly to your factory injectors under boost when you need more fuel. That's a major bonus because I set all my customer's cars with additional injector setups so their gas mileage, idle quality, starting/cranking, and emissions remain 100% factory but no problems running up to twice or three times the amount of power over stock smile.gif
This post has been edited by Tony_the_Tiger: Feb 6, 2008 - 6:36 AM
'94 Supra TT 6spd; AEM EMS, HKS T51R KAI BB; 737 WHP @ 23 psi
'94 Camry V6; AEM EMS, GT4088R; 520 WHP @ 26 psi
'01 IS300; EMU, GT4088R; 381 WHP @ 10.5 psi
'95 Integra GSR; AEM EMS GT2871R; 383 WHP @ 18 psi
post Feb 6, 2008 - 3:59 PM
QUOTE(Tony_the_Tiger @ Feb 6, 2008 - 6:35 AM) [snapback]638608[/snapback]
thanks
tony, have you been able to interface the igniton side of the ultimate with the 5sfe?
if so, would you mind sharing your wiring info?
post Feb 6, 2008 - 9:34 PM
Tony_the_Tiger
Joined Dec 2, '07
From Canada
Hey presure2, the wiring portion is straight forward; but due to differences between US/CAN/Cali spec ECU's in a variety of years, I cannot confirm exactly which pinout it would be for your particular Celica. The wire I intercepted is the white wire located on Plug A Pin#20... As long as the wire you decide to use is labelled as "IGT" which is a wire that leads to the ignitor module, then it is all good. You can verify this wire by testing the continuity between the ignitor's white wire and at the ECU.
At the E-manage's section, you will need to configure the ignition output signal jumper (JP8) to 12v by referring to the manual smile.gif
post Feb 7, 2008 - 6:38 AM
QUOTE(Tony_the_Tiger @ Feb 6, 2008 - 9:34 PM) [snapback]638851[/snapback]
IIRC i have that hooked up, that is only the RPM signal wire.
im talking about the actual ignition timing interface, that allows you to manipulate timing, on the fly.
post Feb 7, 2008 - 1:18 PM
markie
Joined Aug 6, '05
From cerritos, california
Sorry to thread hi-jack.. but had 2 quick questions that relate to the subject at hand:
1. how does the apexi super avc type-r compare with the emanage ultimate?
2. are there any good dyno/tune shops that anyone would recommend here in so. cal?
thanks =)
things happen for a reason.
post Feb 7, 2008 - 11:48 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
QUOTE(markie @ Feb 7, 2008 - 10:18 AM) [snapback]639046[/snapback]
thanks =)
I know Jeff took his car to Mavrik Motorsports in Fullerton to tune his 5sfte. Pretty nice guy and very knowledgeable. The address is 3811 Atesia Ave Unit B. Fullerton CA, 92833. You can call him up if you want, the number is 714-523-1896, the guy's name is Teddy Hiraoka. He is availible upon appointment only.
post Feb 8, 2008 - 3:19 AM
Tony_the_Tiger
Joined Dec 2, '07
From Canada
QUOTE(presure2 @ Feb 7, 2008 - 6:38 AM) [snapback]638963[/snapback]
The white wire is the one you are supposed to intercept... Do not emphazise too much on the wire colour because pin out and colour may be different for other years and models. The most important part is to identify the IGT signal from the ECU. Cut this wire, and feed it to the E-manage's ignition output/input according the E-manage instructions. That is the ignitor's trigger wire which is what the ECU sends to the ignition module to fire the coil. By intercepting this wire, the E-manage is advancing or retarding this signal, therefore, changing timing. The 5S-FE is one of the easiest cars to hook up an ignition signal because it uses a distributor, and literally fool-proof in getting this wire correct...lol
My RPM signal is taken from the "IGF" signal, which is the ignitor's feedback wire.. This would be the black/yellow wire.
RPM signal aka IGF = Black/Yellow at stock ECU's harness
Ignition signal aka IGT = White at stock ECU's harness
To double check if everything works, you can verify timing changes with a timing light smile.gif
QUOTE(markie @ Feb 7, 2008 - 1:18 PM) [snapback]639046[/snapback]
thanks =)
1. No comparison at all... One is an electronic boost controller, and the other is fuel/ignition management...lol
Lo-Fi Version Time is now: November 24th, 2024 - 3:43 PM
