6 Pages V   1 2 3 > »
> 7th gen brake system !, pics are up !
post Feb 7, 2008 - 9:45 PM
Culpable04
Joined Apr 17, '06
From New Jersey
I ordered a pair of 7th gen front calipers and today finally took the time to test fit one of them, the brake line is exactly the same, the brake bolts into the same exact location, but the bolts on the GTS are longer so we have to use the bolts from the ST, obviously we need the rotors and pads from the 7th gen ( just in case someone dare to ask ) .
I know that there have been a lot of discussions about this, and they all said that they fit but no one tried it, so just in case someone else is wondering if they fit, YES they do,
I'll take pictures when I get everything ( rotors, brake lines, pads ) to show the fitment.
I ordered EBC slotted rotors, green stuff brake pads, SS brake lines and motul brake fluid. looking at one or two week to install everything.
if you want any specific pictures, let me know so I'll take them during installation.
This post has been edited by Culpable04: Feb 21, 2008 - 6:46 PM
post Feb 7, 2008 - 10:12 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
what's the advantage?
post Feb 7, 2008 - 10:17 PM
Culpable04
Joined Apr 17, '06
From New Jersey
bigger brake system for cheap, I'm not sure on the size of the ST rotors, but the GTS are 10.8", by the looks ST rotors are ~ 9" which represents a 1.8" increase on size for better braking when using the right components
post Feb 7, 2008 - 10:33 PM
what about the back
post Feb 7, 2008 - 10:51 PM
Daftboy
Joined Jun 30, '06
From West Windsor NJ, USA
One step at a time Dan..
post Feb 7, 2008 - 10:52 PM
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE(playr158 @ Feb 7, 2008 - 10:33 PM) [snapback]639224[/snapback]
what about the back
I have drums on the back so I guess I'll be installing GTs since I don't wanna test GTS rear and discover they don't fit after having paid for the whole thing kindasad.gif
post Feb 7, 2008 - 11:15 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
awesome. how much it run u?
post Feb 7, 2008 - 11:26 PM
purplegt4
Joined Feb 7, '03
7th gen parts: rotors, mounting bracket, pads
6gen st: brake line, brake bolts
which caliper did you use?
post Feb 7, 2008 - 11:51 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
He used the Calipers from a 7th gen GTS apparently. Are the GT calipers different than the GTS? Would this mean that the big brake kits for the GTS should also theoretically fit on the ST's too then?
post Feb 7, 2008 - 11:55 PM
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE(purplegt4 @ Feb 7, 2008 - 11:26 PM) [snapback]639244[/snapback]
GTS calipers
QUOTE(MaskedMan @ Feb 7, 2008 - 11:51 PM) [snapback]639257[/snapback]
teh calipers from7th gen GTS is a little bit bigger than the 6th gen GT, and yes, since the OEM brake kit fits, so will the big brake kit as well smile.gif
post Feb 7, 2008 - 11:58 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(playr158 @ Feb 8, 2008 - 3:33 AM) [snapback]639224[/snapback]
what about the back
7th gen rears are double wishbone... so No.
post Feb 7, 2008 - 11:59 PM
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE(purplegt4 @ Feb 7, 2008 - 11:15 PM) [snapback]639240[/snapback]
calipers ( with brakets ) US$125.00
EBC slotted rotors US$150.00
EBC green stuff pads US$90.00
SS brake lines US$64.00
motul brake fluid ??
you don't have to do it this way, for a budget set-up you can go with a set of used rotors, calipers and TRD ( US$45.00 ) or OEM pads. that all together should be ~ 225.00 if you install everything yourself, which is pretty straight forward if you have replace brakes before.
post Feb 8, 2008 - 12:01 AM
purplegt4
Joined Feb 7, '03
can't wait for pics thumbsup.gif thumbsup.gif gj
post Feb 8, 2008 - 12:04 AM
great, so spedtoe169 was right for the last few years.
http://www.6gc.net/forums/index.php?showtopic=8498
post Feb 8, 2008 - 12:06 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
So the 7th gen gts brakes are actually bigger than the 6th gen GT's?
94 Celica gt white (sold)
post Feb 8, 2008 - 12:12 AM
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE(Batman722 @ Feb 8, 2008 - 12:04 AM) [snapback]639269[/snapback]
yeah, I read the whole thing and that's why I decided to give it a try. I can't believe after all this time, no one tried it after he assure they'd fit. I'm just glad he was right, because if not, I'd have discover it the hard way after spending the money on the calipers lol
QUOTE(bccentaur3 @ Feb 8, 2008 - 12:06 AM) [snapback]639271[/snapback]
I don't have the dimensions of the GT's but they do look bigger than GT's
post Feb 8, 2008 - 12:25 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Well if thats the case I might have to save up for the SSBC big brake kit. 12" rotors with 2 piston calipers. only 725$. Beats any other bbk out there, well atleats price wise.
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(bccentaur3 @ Feb 8, 2008 - 5:06 AM) [snapback]639271[/snapback]
I think they are the same diameter. 6th gen GT's are 275mm in diameter according to brembo, and 7th gens are listed at 10.82 inches which is roughly 274.9mm... basically 275mm. The thickness of the rotor however might not be the same... along with the center hub bores. Part numbers are different between the two rotors, so they are more than likely different beyond the rotor diameter. Also note, the Scion tC, Matrix/Vibe, Corolla XRS, and a few other models share the same basic front brake systems as the 7th gen Celica.
This post has been edited by Kwanza26: Feb 8, 2008 - 12:28 AM
post Feb 8, 2008 - 12:28 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Well since Culp confirmed this SSBC here we go.
post Feb 8, 2008 - 12:40 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Another CONFIRMED cheap option if you ST guys want to "upgrade" your brakes... I'm still running them... and yeah... yay!
http://www.6gc.net/forums/index.php?showto...6&hl=brakes
6 Pages V   1 2 3 > »
Lo-Fi Version Time is now: November 28th, 2024 - 3:21 PM
