6 Pages V  « < 3 4 5 6 >
> 7th gen brake system !, pics are up !
post Feb 29, 2008 - 3:52 AM
celicaGT96
Joined Aug 14, '05
From Corpus Christi Tx
either way its always nice to know there are other options out there for our celicas.
post Feb 29, 2008 - 2:49 PM
azian_advanced
Joined Apr 18, '05
From Calgary
they 'are' an upgrade for GTs (assuming they fit the same was as on an ST), but not the same kinda difference you would get from an actual bbk. i'm sure the 7th GT-S brake assembly is bigger than the 6th gen GT disc brake assembly.
once i find someone local parting out a 7th gen GT-S, i will try this myself!
post Feb 29, 2008 - 2:55 PM
Culpable04
Joined Apr 17, '06
From New Jersey
Kwanza posted the specs of the disc, they are about the same size, the only way this would be an upgrade from GT is if the caliper and pads are bigger, probably GTs can just swap the caliper instead of having to get new disc like us ST drivers
post Feb 29, 2008 - 3:00 PM
6strngs
Joined May 12, '06
From Wilmington, NC
well, if they do in fact need 16's to clear the caliper on this car (i know you do for 7th gens, but maybe our's is mounted slightly closer or something, I dunno) then it would be bigger then stock 6th gen GTs which can use 15" rims.
if somebody had the measurements on the diameter of the caliper piston on 7th gen and 6th gen GT brakes, that would tell you right away if it would be an improvement.
post Feb 29, 2008 - 3:24 PM
azian_advanced
Joined Apr 18, '05
From Calgary
QUOTE(Culpable04 @ Feb 29, 2008 - 1:55 PM) [snapback]647771[/snapback]
lubu also posted a chart of rotor sizes.. and the 7th gen GT-S and 6th gen GT have identical rotor dimensions but the 7th gen is 3mm thinner.
my assumption is if the 6th gen GT calipers and axle carriers are the same as the STs (which i'll verify when i get home today), then the 7th gen GT-S calipers will mount to the 6th gen axle carriers and won't need to have 7th gen GT rotors (if the 3mm thicker rotors from the 6th gen doesn't affect the 7th gen calipers' performance). but all this is pointless, if the piston diameters of both calipers are the same.
post Feb 29, 2008 - 3:47 PM
Culpable04
Joined Apr 17, '06
From New Jersey
3 mm thicker will make a difference, that means swaping the caliper to the GT and keeping the stock rotors will not work, the piston will travel a different distance in order to compress the pads, a thiner rotor will means that the piston will not travel enough to apply the required pressure.
post Feb 29, 2008 - 5:23 PM
99GT
Joined Dec 14, '06
From MN, USA
Can't somebody who has part numbers confirm if the brake parts used are the same from ST to GT? Just a thought.
post Feb 29, 2008 - 5:27 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(Culpable04 @ Feb 29, 2008 - 12:47 PM) [snapback]647811[/snapback]
but that's not the case. the piston moves closer to the disc as the pads wear out, and when you release the brakes, it moves back only a very small amount. for example, when your pads aren worn, the piston sits closer to the disc, this is why you push the piston back in when you put new pads in. then after a brake job you pump the brakes to get the piston to the proper position. the thinner rotor may or may not cause problems for other reasons, but the distance the piston needs to travel is not a problem. the only problem I could see with it is that when the pads get extremely worn, the piston may extend too far to the point where it'll blow the seals in the caliper.
post Feb 29, 2008 - 8:50 PM
azian_advanced
Joined Apr 18, '05
From Calgary
^ that, and also the possibility that with 7th gen calipers, new (thick) brake pads and the thicker 6th gen rotors, the extra 3mm rotor thickness might be too much...
anyway, i just checked the ST and GT brakes... they have the same caliper mounting bolt distances, same steering knuckles and same hubs.. i don't see why it wouldn't work on a GT. we just need to get this confirmed now.. any takers?
post Feb 29, 2008 - 9:20 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(azian_advanced @ Feb 29, 2008 - 5:50 PM) [snapback]647921[/snapback]
the 6th gen GT rotor is 3mm thinner than 7th gen rotors, not thicker. there shouldn't be an issue with the rotors/pads being too thick to fit in the caliper.
I'll put them on and test them out if somebody wants to give me the calipers tongue.gif
post Feb 29, 2008 - 10:02 PM
azian_advanced
Joined Apr 18, '05
From Calgary
but this says otherwise
post Feb 29, 2008 - 10:37 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(azian_advanced @ Feb 29, 2008 - 7:02 PM) [snapback]647942[/snapback]
Ah, I thought it was the other way around. then yes, brand new brake pads w/ 7th gen calipers might not fit with GT rotors.
post Mar 2, 2008 - 2:19 AM
CelicaST_CALI
Joined Feb 28, '07
soo all 7th gen brakes work or just gts??
BANNED. for life, you moron.
post Mar 2, 2008 - 2:43 AM
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE(CelicaST_CALI @ Mar 2, 2008 - 2:19 AM) [snapback]648271[/snapback]
they all should work, but why install something that is not an upgrade from what you already have ?
post Mar 2, 2008 - 3:30 AM
CelicaST_CALI
Joined Feb 28, '07
i have an st...
post Mar 2, 2008 - 3:32 AM
Culpable04
Joined Apr 17, '06
From New Jersey
yeah, but the 7th gen GT brakes after certain year ( 2001 ? ) are tha same as GTS, and before that, they are smaller than GTS which makes them smaller than 6th gen GT brakes. so not that big of an upgrade from the ST, especially when price wise is not much of a difference from one to the other.
post Mar 2, 2008 - 3:34 AM
CelicaST_CALI
Joined Feb 28, '07
post Jun 7, 2008 - 1:10 AM
purplegt4
Joined Feb 7, '03
From Northern Virginia
QUOTE (bccentaur3 @ Feb 28, 2008 - 3:36 PM) *
QUOTE (dabazied @ Feb 27, 2008 - 8:22 AM) *
Would these fit with stock rims?
No 15's will not fit. I had a 7th gen gts and tried to fit 15's for winter, but won't clear the calipers.
14's won't. 15's will.
at least the 15" 7th gen GT rims do.
post Jun 12, 2008 - 5:41 PM
Davesceli
Joined Apr 24, '04
From S. Cali
ok so if i wanna instal a bbk for a 7gc...all i would need to do is bolt up all the brakets and stuff right...nothing special needed??
post Jun 12, 2008 - 6:06 PM
tomazws
Joined Oct 30, '04
From So Cal
QUOTE (lagos @ Feb 19, 2008 - 9:19 PM) *
bleed everything starting from the rear pass side.
QUOTE (Culpable04 @ Feb 20, 2008 - 4:22 PM) *
it was exactly what you guys said, I bleed them again in the order you guys told me to and that was it.
May I ask if the order was clockwise or counter clockwise starting from rear passenger side?!?!?!
Lo-Fi Version Time is now: November 28th, 2024 - 9:27 PM
