> A quest for all 3rd gen 3sgte owners!
post Feb 11, 2008 - 9:08 PM
pitcelica
Joined Jan 28, '07
From Québec, Canada
Hi, I have a little test that I want you to perform on your engine. I want to do it for my personal knowledge, but I will share it with everyone else on this board or on other forum.
I want you to take a timing light, hook it to your engine and note the where is your timing where the engine is idling. Here's the steps to perform the test :
1- Start your engine and let it reach the normal running coolant temp (about 190°F).
2- When the engine is hot, hook up a timing light to the cyl #1 spark plug wire. DO NOT BRIDGE ANY TERMINAL IN THE DIAGNOSIS PORT.
3- Aim the crank pulley and notice what is the timing that the timing light is showing (It may be difficult because there is not a lot of timing reference (the reference is from 20° BTDC to 5° ATDC). I think that the timing should be between 15-25° BTDC.
4- Note what is the current RPM (your idle RPM).
5- If you have an aftermarket boost gauge, note what is the vaccum value when your engine is idling (it should be close of 19 in-hg vaccum)
Post your value on this thread.
This will be very helpful for me and for other people who are trying to build an ignition advance table on their Engine Management system.
Thanks in advance!
Sam
This post has been edited by pitcelica: Feb 11, 2008 - 9:08 PM
post Mar 1, 2008 - 3:52 PM
pitcelica
Joined Jan 28, '07
From Québec, Canada
bump, cmon its a easy test!
post Mar 3, 2008 - 1:44 PM
Insanity-74
Joined Jan 9, '05
From Under the car
QUOTE(pitcelica @ Mar 1, 2008 - 8:52 PM) [snapback]648120[/snapback]
I`ll try this at the weekend for you, but having done this before the timing mark wonders around a bit as the ecu is constantly making adjustments to the timing.
post Mar 4, 2008 - 11:27 AM
pitcelica
Joined Jan 28, '07
From Québec, Canada
Good, thanks man!
I just need an approximation. I want to know if its more near 20 degrees or near 15 degrees. Dont forget to look at your RPM at idle and at your in/hg number on your boost gauge. Do this when engine is at operating temp plz.
Thanks a lot!!
Sam
post Mar 10, 2008 - 2:47 PM
pitcelica
Joined Jan 28, '07
From Québec, Canada
Hi, did you take time to make the test?
Let me know!
Sam
post Mar 10, 2008 - 3:11 PM
Insanity-74
Joined Jan 9, '05
From Under the car
QUOTE(pitcelica @ Mar 10, 2008 - 7:47 PM) [snapback]651503[/snapback]
Let me know!
Sam
I did attempt to try..the tools for the job are next to the door...unfortunately living in the UK it has a nasty habit of raining just when you want to work on the car and guess what...the worst storms in many years have payed us a visit...it done nothing but rain all weekend...I might have time on wednesday, if not I`ll do it on friday...I have not forgotten.
post Mar 12, 2008 - 7:16 AM
pitcelica
Joined Jan 28, '07
From Québec, Canada
Ok, thanks a lot,
I'm sry if i'm not very patient.
Here in Canada, this was the biggest snow storm in 40 years this weekend. We received 2 feet of snow within 10 hours.
Anyway, I know what you're talking about when you say working on your car when its raining.
I'm waiting your news!
Thanks again
Sam
post Mar 12, 2008 - 5:16 PM
yarik83
Joined Nov 22, '04
From FL
I dont have the tools and my tach meter is not hooked up. I can say that from sound of it my 3rg gen is idling at about 2K rpm. I do have greddy prospec 2 err whatever its called boost controller thing. I also have sprecter EMS all installed by xat racing. My car takes 3 times to start and or I have to keep pumping gas pedal first 20 ish seconds for it not to stall. It just does not like to start at all. When it runs it looks like it runs at about 2000 rpm having a very sexy growl sound. my boost meter reads 58-60 and i think its x100. I do assume normal boost level is around 5-6 even at highway speeds. When I step on gas i seem my gause go as high as 11-12 lbs of boost.
Captain Pessimist
post Mar 12, 2008 - 9:01 PM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
well at idle my boost guage reads about 16 in/hg. but i have large cams and therefore have less vacuum at idle then a stocker.
you ignition should be around 10 deg btdc
This post has been edited by Cuts_the_Pilot: Mar 25, 2008 - 9:38 PM
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
post Mar 13, 2008 - 7:55 AM
pitcelica
Joined Jan 28, '07
From Québec, Canada
i dont want cam timing, I want ignition advance at idle. This can be seen with a timing light when the engine is idling. But DO NOT BRIDGE ANY TERMINAL IN THE DIAGNOSIS PORT. I want the realtime ignition advance, not the base ignition advance that is normally 10 degree BTDC.
post Mar 20, 2008 - 10:52 AM
pitcelica
Joined Jan 28, '07
From Québec, Canada
bump
post Mar 23, 2008 - 9:05 AM
Insanity-74
Joined Jan 9, '05
From Under the car
OK I finally got around to doing this for you...sorry for the delay...but as your request, with the engine warm and nothing bridged the timing gun shows that the timing is pretty steady on 10deg but it does fluctuate a little...never more than 10 deg but it does go up and down between 9 and 10deg...very occasionally getting as far as 8 deg. But it only did tat once or twice in the full ten mins I was checking the timing for.
post Mar 23, 2008 - 12:59 PM
pitcelica
Joined Jan 28, '07
From Québec, Canada
Good, thanks a lot for this info, very useful!!!
So, if you have something you want me to check on my engine too, go ahead!
Thanks again!!
post Mar 29, 2008 - 8:03 PM
jazzcornet
Joined Mar 27, '08
From newport news, va
16* BTDC
23" hg
845rpm
genIII, stock longblock with BFT
post Mar 30, 2008 - 1:08 AM
QUOTE(pitcelica @ Mar 13, 2008 - 8:55 AM) [snapback]653119[/snapback]
If you read the bgb, it will tell you what ignition timing you should have on a warm idle. I think for the 2nd gen motor is about 12deg. So it might be useful to look it up in a 3rd gen bgb.
post Mar 30, 2008 - 8:47 AM
mrgt4
Joined Mar 27, '08
From england
mine also is @ 10degree once at normal temp, like insanity 74
1994 ST-205 JDM GTFour... fmic conversion finshed, project GT500 is underway
www.rising-sun-racing.com
tuning , performance, repairs and conversions... Blitz, TRD and many more suppliers :)
post Apr 8, 2008 - 2:39 PM
DEATH
Joined Dec 19, '07
From tx
QUOTE(lagos @ Mar 30, 2008 - 1:08 AM) [snapback]659647[/snapback]
Believe it or not I was working with my friend who is a Toyota Tech at a local dealership on my timing [genII motor] and the BGB he brought up at his terminal said to set the base timing at 10* but after removing the jumper the normal at temp would be between 13* and 21* BTDC at idle. I didn't believe it and had to take a second look but it was right there for all techs to see. IDK - seemed too advanced to me.
This post has been edited by DEATH: Apr 8, 2008 - 2:40 PM
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Apr 10, 2008 - 11:00 AM
pitcelica
Joined Jan 28, '07
From Québec, Canada
between 13 and 21 degree of advance at idle is correct. For now, I'm at 19 @ 1100 RM @ 19in-hg vaccum and my idle is pretty rock solid. Thanks a lot guys for all that info!
Lo-Fi Version Time is now: February 13th, 2025 - 1:22 PM
