> E-Brake Light, comes on when I brake "hard"
post Feb 12, 2008 - 1:28 PM
UTSlickVic
Joined Mar 6, '05
From Fort Worth, TX
I decided to push it on the Hway last night (took awhile to get up to 90mph wink.gif ). Anyways, I applied my brakes harder than I usually do (did not slam on them) and the ebrake like flashes.
What does this mean?
post Feb 12, 2008 - 1:32 PM
low on fluid. Top it off.
post Feb 12, 2008 - 1:33 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
Is it actually your brake light in the dash, you mean? This could be one of two things. Most likely, it's because you're low on brake fluid. Less likely, it could be a bad e-brake switch that's triggering the sensor to make the light come on. If it's coming on randomly, it's likely your fluid level.
post Feb 12, 2008 - 1:51 PM
UTSlickVic
Joined Mar 6, '05
From Fort Worth, TX
Cool I hope its just fluid. It doesnt come on randomly... just when I brake hard.
post Feb 12, 2008 - 2:48 PM
GriffGirl
Joined Feb 7, '07
Probably fluid.
post Feb 13, 2008 - 2:40 AM
airfron
Joined Jul 31, '05
From Southern California
i'd put my money on it being the brake fluid... and i bet its because your brake lines are expanding enough under the extra pressure caused by hard braking to bring the level down, maybe some SS brake lines would do you well
post Feb 13, 2008 - 2:10 PM
94GT
Joined Feb 25, '04
From Fairfield, CA
plus when you brake hard, the fluid sloshes around in the reservoir, so it will give you a low reading if your level is borderline, turning on the light.
post Feb 13, 2008 - 4:17 PM
GriffGirl
Joined Feb 7, '07
QUOTE(94GT @ Feb 13, 2008 - 11:10 AM) [snapback]641134[/snapback]
Ding-ding-ding! That's what I'm bettin' on too...
post Feb 14, 2008 - 2:02 AM
purplegt4
Joined Feb 7, '03
From Northern Virginia
also check your pads, they might be low.
post Feb 16, 2008 - 2:31 AM
6strngs
Joined May 12, '06
From Wilmington, NC
yep, happened to me too. just top off the fluid and it'll take care of the light. what you should be more worried about is why your fluid got low. most likely the pads are getting pretty low.
Lo-Fi Version Time is now: November 24th, 2024 - 12:09 AM
