5 Pages V  « < 2 3 4 5 >
> The new 5sfte, UPDATE: engine has low compression...
post Mar 19, 2008 - 4:24 PM
or you could just go on ebay...
downpipe
http://cgi.ebay.com/ebaymotors/Downpipe-Do...sspagenameZWDVW
adapter
http://cgi.ebay.com/ebaymotors/MR2-T3-T4-T...sspagenameZWDVW
just keep in mind that this is not the highest quality stuff.
post Mar 19, 2008 - 4:33 PM
QUOTE(6strngs @ Mar 19, 2008 - 5:09 PM) [snapback]655667[/snapback]
KO racing said that if I send them my turbo, they can make the adaptor and downpipe and modify my turbo to have a V-band like they do on their street bawler kits. ok sounds good, until he said it would be $900 plus shipping! HA! maybe I'll just get the adaptor from ATS racing and buy some universal pipe and have it welded for free by the welding instuctor at my school.
yea, ko can fabricate some GREAT stuff, and kris is a really cool guy, but it is NOT cheap.
i would go with the ATS adapter, and have a screamer pipe weled up, like you are talking about.
post Mar 19, 2008 - 4:37 PM
6strngs
Joined May 12, '06
From Wilmington, NC
I've already got an ebay adaptor, but I think everything would be easier if I had an adaptor more like the street brawler kit's. the oil filter probably wouldn't even need to be relocated then. I've thought of blocking off/welding shut the oping on the side of the adaptor, and then boring a hole the same size in the front of it and then it'd be the same as ATS's. Or getting one of those cheap ssautochrome MR2 manifolds and cutting off the CT26 flange and having a T3 flange welded on instead + have a wastegate flange welded onto it somewhere, but there's no telling if the turbo would fit then and the filter might still need to be reloacted then.
post Mar 19, 2008 - 5:15 PM
dont use the ssautochrome crap.
post Mar 19, 2008 - 5:31 PM
QUOTE(6strngs @ Mar 19, 2008 - 5:37 PM) [snapback]655681[/snapback]
i can tell you for sure the turbo will hit the manifold.
joe (supershannon77's future brother in law) has the ssautocrap manifold, with the T3 flange, and the ebay special turbo, sitting in his room. the turbo hits the manifold, the gap between the manifold and turbo flange is prolly 3/4" or more.
post Mar 31, 2008 - 5:32 PM
6strngs
Joined May 12, '06
From Wilmington, NC
no real updates yet. it's been 2 full weeks and Blaast still has not recieved my turbo yet. *sigh* I do have one thing for you though. I was at a hot-rod/muscle car type car show yesterday and found this battery tray for pretty cheap, so no more ghetto rigging of the battery hold-down smile.gif
post Apr 1, 2008 - 11:12 AM
QUOTE(6strngs @ Mar 31, 2008 - 6:32 PM) [snapback]660192[/snapback]
yup, thats the same tray we used in shannons car, and joes car.
clean, and simple.
good stuff.
post Apr 6, 2008 - 12:03 AM
6strngs
Joined May 12, '06
From Wilmington, NC
Blaast says they recieved my turbo on thursday and are working on it now. so, hopefully only 2 more weeks til I get that back. anyway, I've been thinking alot about how I'm gonna get this all to fit in here. It seems that getting an ATS adaptor and routing like the KO racing kit won't work if I'm following the same IC piping route that supershannon followed, which I was planning on doing, and since my housing has a 90 degree bend off it too there's not much else I could do without some crazy bends that would be terrible for flow. so I think I'm gonna stick with the adaptor I have, but I don't really see how the oil filter relocation is gonna work with the A/C still in there. today I was kinda thinking about selling the t3/t4 when I get it back and just getting a CT27, but I don't think that turbo will be big enough for what I want. I think I'll just give the garrett a shot anyway.
post Apr 9, 2008 - 3:17 PM
6strngs
Joined May 12, '06
From Wilmington, NC
turbo is on it's way back. currently still in canada but should be in the states by tomorrow at least.
anyway, after reading bccentaur's thread, I'm wondering if my engine might have blown piston rings too... It would explain why I've blown 2 turbos and I have a feeling this one might be on it's way out. I get some smoke coming out the tail pipe which looks white to me, but it could be blue. a friend driving behind me a couple weeks ago told me he saw a bunch of blue smoke come out of my tailpipe. I'm definately gonna do a compression check before I put this new turbo on, and, if it's determined that my engine isn't looking good, I want to get a 3sgte for it. I figure most of my mods will transfer over to that engine including the FMIC, the 3" exhaust, the SAFCII, the MBC, the gauges, the walbro fuel pump, and the t3/t4. I figure that'd be good for quite a bit of power on a 3sgte! perhaps as much as 280WHP at 15 PSI? not bad for merely putting a new engine in and swapping all my aftermarket stuff over. of course, I'd almost rather buy an ST165, swap a 3rd gen engine in, and then put all the mods on and probably break 300AWHP. but I'm getting ahead of myself, gotta do a compression test first.
post Apr 15, 2008 - 10:57 PM
6strngs
Joined May 12, '06
From Wilmington, NC
5sfe specifications for compression:
178 PSI
Minimum of 142 PSI
Maximum allowable difference of 14 PSI
here's the numbers I got:
Cyl 1: 140 PSI
Cyl 2: 131 PSI
Cyl 3: 135 PSI
Cyl 4: 150 PSI
frown.gif x 1000000! I didn't think to do a wet compression test, but since I had a theory that the piston rings were worn, I would guess that I was right. I'm not really sure what to do now, I want to do a 3sgte, but I really can't see putting that much MORE money into this car... I would love to get an alltrac, but the ST185's are so expensive, and the ST165's I think wouldn't be "new enough" as I kind of want to get a newer car rather than an older one. *sigh*
post Apr 16, 2008 - 1:32 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
If its not your daily driver I say hang in there. Just think of all the time and money you've put into the celi. I was in the same boat, but after thinking and my girlfriend wanting to beat me down. I decided I should just keep on track and think of the outcome.
94 Celica gt white (sold)
post Apr 16, 2008 - 9:20 AM
6strngs
Joined May 12, '06
From Wilmington, NC
the thing is, I know that if I "rebuild" this engine, I'm not gonna be satisfied to just use stock stuff. I'm gonna want forged, low compression pistons, forged rods, balanced crank, port and polished head, oversized valves, cams, etc etc. and then even if I pull all this turbo stuff off, I know I still won't pass smog!
post Apr 16, 2008 - 2:10 PM
addictions
Joined Sep 26, '07
From iowa
MOVE TO IOWA! lol no smog test here
-Boss III
post Apr 16, 2008 - 7:31 PM
99GT
Joined Dec 14, '06
From MN, USA
Move to MN too. Nothing, stupid people run open header all the time.
post Apr 17, 2008 - 5:48 PM
supershannon77
Joined Jan 18, '07
From Bergen county NJ
What about buying a newer 5sfe motor? Thats what I ended up doing...the only thing is if you wanna swap at all now is the time if you are planning on taking the motor out. It really comes down t goals and $$$
facebook WRC st205
post Apr 18, 2008 - 1:59 AM
6strngs
Joined May 12, '06
From Wilmington, NC
yeah, I want to keep the car and finish what I started, especially since i had such high hopes for it. tonight I was at a local import meet and as I had about 10 total strangers gathered around my car asking questions about it, I realized I would never get that kind of attention with any other car. however, I think in terms of the $ to horsepower ratio, a 3sgte swap would be a better idea, BUT, then I could never get my car smogged. So, say I want to build up a 5sfte, well, what I was planning on doing in 12 months when I need to smog again was just take all the turbo stuff off and throw the stock stuff on and then put it back on again after the smog, but if you change the internals, it's not that easy. I know I'd want forged, low compression pistons and forged 3sgte rods with ARP rod bolts and head bolts, and a metal headgasket at least. but possibly also a ported and polished head with a valve job and oversized valves. maybe port and polish the intake manifold too. and a set of cams of course... but that wouldn't be so easy to swap out.
do you think emissions will go up from using lower compression pistons? if I don't do anything to the head and just build the bottom end?
post Apr 18, 2008 - 8:19 AM
DEATH
Joined Dec 19, '07
From tx
QUOTE(6strngs @ Apr 18, 2008 - 1:59 AM) [snapback]665796[/snapback]
Never thought of it that way - why do you think that [what are your suspicions]?
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Apr 18, 2008 - 9:52 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(DEATH @ Apr 18, 2008 - 6:19 AM) [snapback]665826[/snapback]
it might not get complete combustion and then the CO would increase.
one things for sure, if I do use low compression pistons, then when I am ready to sell the car and I sell all the modifications seperate from the car like I plan to, somebody isn't gonna be happy about only getting like 115 flywheel HP when it's NA opposed to 135. lol.
anyway, if building the bottom end does not raise emissions any, then I could have 2 heads, one stock, and one fully built that I could put on and then swap out when smog comes around.
post Apr 18, 2008 - 10:27 AM
DEATH
Joined Dec 19, '07
From tx
T-spoon [currently owned by Ngofcukingway] has slightly lowered compression with built bottom end and it's not significantly slower than other GTs by any means - in fact it's one of the quickest N/A 5s's I know.
EXT: WRC/TRD/404
post Apr 18, 2008 - 11:10 AM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
QUOTE(DEATH @ Apr 18, 2008 - 10:27 AM) [snapback]665871[/snapback]
Fo shizzle.
-Alex {](O_o)[}
Lo-Fi Version Time is now: December 2nd, 2024 - 1:12 PM
