Project Hellica, Due to popular demand; Lets watch this totaled Celica's reincarnat |
Feb 17, 2008 - 9:01 PM |
Enthusiast Joined Jan 18, '08 From Houston Currently Offline Reputation: 7 (100%) |
Okay; Many members have been wanting me to post up my work as i go thru it. I've decited to respect theese wishes, and try my best to make a decent thread form now till i finish this project.
Id also like to take a second and ask our more experienced members to not knock on parts of my job. I do live by the "Do it once, Do it right" theme, However; For my purposes, some things MUST be done over. In this first post, there will be some items that some people would consider "Half-Ass" (Mod's Please pardon the figure of speech) BUT please rember that due to time and financial restrictions; I'm posting this as i go. I DO infact have a motive to do theese things. There is a reason i do things the way i do. Also; NO, i am not a mechanic. Infact, I'm an accountant / Office supervisor. Many of you know that i spend my days online here at 6gc.net trying to help others. Everything i know, is because i've had to do it. I'll be the first person to say "I dont know" if i cant help you. I am aslo not a photographer. I dont have a camera. I use my Cell phone. Sorry they're blurry. With that said, I hope some of you can learn a thing or two from this project. Namely the Noobs. I would also like to take a second and mention that Noob is short for Newbi, someone who is new at something. I am new at 6 gen Celicas. I have had mine for almost 3 months now. There is nothing wrong with being new, it just means that you have a bit of catching up to do. Well, seeing as i wasn't a member when i did the power searing, and the window brackets; That wont be included here. Lets start off with this lovely image: And this is what we'll be working with on todays episode. First off; We'll have to remove the bumper. Now when you have a few of theese: 3 finger holes... And no suppots except for a zip-tie... It's not hard. For the rest of us, we'd start by poping the hood; removing the 4 bolts on the top lip of the bumper. Then we'd move downward to remove the plastic tabs holding to the frame in our grills. Witch would let us to remove the 3 bolts holding our splash guard. Then there are going to be 3 nuts to remove inside of the body, between the fender and the bumper. Voila, bumper has been removed. Now just for Schetts and giggles; I'm also going to show you how to fiberglass a bumper crack back into one peice. I'll do that in a second. Lets finish changing the fender first. Next we are going to Remove that bad fender. Start by removing your splash guard. There are something like 6 bolts i think... I dont know... Because i dont have one. It's in the mail... We're going to then remove the side skirt. You can unbolt the whole skirt if you want, But i only removed the first 3. There is one bolt holding the fender in, Look for yourself: And one more vertical to the top of the fender, Inside the door. You'll have to get an extention to get to it. Sorry again for the blurry images. Now we're going to move back under the hood. There are 3 final bolts holding that fender on located on the top lip of that fender: Now we should be looking at this: Now for my purposes, This was a great opportunity to look for crap like this: Oooohhhh THAT's why my hazard lights dont work Quick connect; and it's fixed. (And test to make sure you didnt wire something crazy up) Its a good idea to check wires before connecting them. However, it's also a good assumption that when you see 2 riped wires, Perfect length for each other, With matching colors... For my purposes, i assume they go together. but if it was YOUR car, i'd recommend to check first. Okay, I suppose this would be a good time to worry about that busted bumper as well... You see it was held on by a zip-tie... The lip that holds the bracket; that goes into the fender VIA the 3 nuts, Was riped off on the seam. Look: This is a quick advance into the future, but to prove my point: And the bracket it self was: Well it wasnt quite in tip top shape. So using the finest pliers i had... Is something like what it should look like. Also; for my purposes, A bit of fiberglass work was required. I dont need to, But for this fourm i will go back and finish this fabrication... Lets jump to that real quick. Now this is where i stoped. It was getting late, the wife and baby were hungry, I'll finish this next weekend for you guys. Please note; that last picture is actually 9 layers of fiber cloth. i didnt see any reason to post it up 9 times... Also: to mend cracks, your going to pull it together best you can and tape the front. Then on the reverse side you'r going to lay about 10 layres. Then when you come back to the front; it should look like, or better than this: Please note this is not a half-ass job. I am purchasing a full body kit after the 1st of next month. (Pay rent first ) Therefore there is no reason other than for this form, and peoples reference, to do this. Again, this is something i'll finish next week for you guys. But FYI, from here you'd lay a coat of resen/hardner over the crack and all arround. Then you'd sand it down. Then Bondo - Sand - Paint. I'll show you guys next weekend. Back to the fender. Because i have need for a new bumper, and wife/baby getting hungry and complaining about it; I actualy drilled holes and used more zip-ties to secure the bracket to the bumper. I then secured the bumper to the fender as if it were legit. For my purposes, it is okay. I'm buying a new one in 2 weeks. At witch point the old one will be scraped. But holes like this cannot be fixed, not after it's warped so bad, and for so long: Back to the fender -> For anyone still useing this as a refferance, Replaceing the fender is just like taking it off... But in Rewind. Now lets assume that you read this backwards and put it on. It may not be stright. Thats okay. There may be a scientific method, But i'm a fan of trial and error. Put it back on; close your hood, and see how it looks. If there are large gaps, loosen the top 3 bolts, and put weight where the gaps were. If its too close together, than pull out before re-tightening the bolts. When its done, you'll want to compare one side with the other. And dont forget the bottom: Now we should end up with this: Also, make sure that if your doing this, that you take every attachment off your old fender; Even if you have new ones, A fourm member here may not, and it'd be a very nice thing to do, if you helped that member out, those attachements may be cheap and crapy, but can make a world of difference. Plus the dealership is going to screw you hard if you want to buy them. So if you dont need em, sell em for a dollar or something, please? ***** If anyone has any questions or comments on this thus far, Please feel free to speak your mind. I'm going to be adding a little more every weekend, and hopefuly this helps someone, Or atleast entertains them. Stay tuned, For soon we'll be doing a full body kit, a spoiler, and custom fabricated sub boxes. I have a Turbo Project in the works... Early phases, i'm trying to get my hands on all the parts, and with certain fourm members helping me, It may be pretty soon, Or in a milllion years. Who knows... Thanks for tuning in~ This post has been edited by D-Man: Jun 9, 2008 - 3:11 PM -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Feb 17, 2008 - 10:12 PM |
Enthusiast Joined Feb 28, '07 Currently Offline Reputation: 1 (100%) |
that has got to be the biggest post i have ever seen...
-------------------- BANNED. for life, you moron.
Feb 17, 2008 - 10:13 PM |
Enthusiast Joined Mar 29, '07 From Philly Currently Offline Reputation: 11 (100%) |
good work bro...i woulda just ordered new but that didnt come out bad at all...A++ for effort in my book
-------------------- I"M NOT A TOYOTA FAN, IM A FANATIC 1984 accord hatch 5 speed (T-Belt)-Junkyard 1991 VDUB jetta wolfsburg Ed. 5 speed (clutch)-junkyard 1988 Dodge Aries K (sold) 1969 Chevy El camino - Traded for celica 1991 Dodge Daytona-Traded for Celica 1988 Chevy Camaro-Work in Progress 1989 Ford Mustang LX 5.0 - For Sale 1995 Toyota Celica-Work in Progress |
Feb 17, 2008 - 10:30 PM |
QUOTE(CelicaST_CALI @ Feb 17, 2008 - 10:12 PM) [snapback]642618[/snapback] that has got to be the biggest post i have ever seen... Stay tuned, There will be MUCH more~ There IS a reason that you can get a car for dirt cheap... It just require a whole lot of work, and forum space QUOTE(95st-celica @ Feb 17, 2008 - 10:13 PM) [snapback]642620[/snapback] good work bro...i woulda just ordered new but that didnt come out bad at all...A++ for effort in my book Thank ya The fender was used, but in good shape. For $125- Cant beat it. I'm planing on doing an invader kit possibly with a blitz front next month, so; whats the point of spending the money for 2-3 weeks? Plus, i have a few other imperfections on the body that i'm going to do away with; so that i can get her painted fresh and clean! This post has been edited by D-Man: Feb 17, 2008 - 10:32 PM -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Feb 18, 2008 - 12:00 AM |
i guess i read it now...
Feb 18, 2008 - 11:44 AM |
I think this is awesome, especially for people like myself for whom the word "fiberglass" strikes fear and intimidation with.
Feb 18, 2008 - 12:10 PM |
QUOTE(GriffGirl @ Feb 18, 2008 - 11:44 AM) [snapback]642762[/snapback] I think this is awesome, especially for people like myself for whom the word "fiberglass" strikes fear and intimidation with. Hah-hah... Griff, we've talked about fiberglass on other occasions! Wait till we get to the sub box; You'll get to learn my fabrication secrets! lol I've said it before and i'll say it again, "The only thing difficult about fiberglass work is staying sober while it's drying." -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Feb 18, 2008 - 5:06 PM |
Enthusiast Joined Jan 13, '08 From Christchurch New Zealand Currently Offline Reputation: 0 (0%) |
QUOTE(D-Man @ Feb 18, 2008 - 12:10 PM) [snapback]642771[/snapback] "The only thing difficult about fiberglass work is staying sober while it's drying." Haha what an awesome quote. -------------------- 1994年 トヨタ 神々しい My Facebook My Bebo QUOTE (loll6g @ Nov 6, 2008 - 5:53 AM) automatics are for lazy ass drivers who jst want there car so that they can look cool |
Feb 18, 2008 - 5:36 PM |
Yeah, well I learned the hard way... i was learning to do door panels, passed out while drinking some Crown flavored Cola, Woke up painted blueish-greenish.
Like my WHOLE body was painted... This guy josh took a spray rig and painted me... it was f-ed up... I had a headache for a week due to the paint... -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Feb 18, 2008 - 10:33 PM |
Enthusiast Joined May 14, '05 Currently Offline Reputation: 0 (0%) |
Thank you for making this thread. Great work. I'll be sure to check back often.
Feb 18, 2008 - 10:36 PM |
Okay, so i'm installing a few new toys today; I got pics of some, and i'll update with the rest tonight. But i just got to show theese off!!
Plus one of theese in black. Also, i will be doing an OEM front bumper for now. Not today, maybe next weekend. (it's on order) But i got a great deal on it. So~ I'll show off the body kit later... For the money, it's better to do it this way. Plus, by the end of this month, i will be starting the 5sfTe project!! Whoot for Boost!! This post has been edited by D-Man: Feb 24, 2008 - 1:07 PM -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Feb 25, 2008 - 9:26 PM |
Enthusiast Joined Aug 2, '06 From bay area Currently Offline Reputation: 21 (100%) |
can u get another set of front brake rotors like urs slotted and cross-drilled?
Feb 26, 2008 - 3:54 AM |
Enthusiast Joined Jul 28, '06 From Delaware Currently Offline Reputation: 0 (0%) |
Not tryna bash, but you dont need that much 'downforce' aka drag.
Feb 26, 2008 - 11:18 AM |
Enthusiast Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) |
QUOTE(azn87 @ Feb 25, 2008 - 9:26 PM) [snapback]645759[/snapback] can u get another set of front brake rotors like urs slotted and cross-drilled? We are working something out on that [sorry to answer for you D-man]. Watch for a FS thread in the near future. Killer thread dude - now we need to work out the rest of the kinks in my front end and I think I about have my brake money ready to go. -------------------- ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Feb 26, 2008 - 11:39 AM |
QUOTE(DEATH @ Feb 26, 2008 - 11:18 AM) [snapback]645982[/snapback] QUOTE(azn87 @ Feb 25, 2008 - 9:26 PM) [snapback]645759[/snapback] can u get another set of front brake rotors like urs slotted and cross-drilled? We are working something out on that [sorry to answer for you D-man]. Watch for a FS thread in the near future. Killer thread dude - now we need to work out the rest of the kinks in my front end and I think I about have my brake money ready to go. Well, i have an assistant!! 2 Woot's for me! and 1 Woot for my assistant; lol ~kidding~ But yes, they guy i bough em from is going to call me back with the number; he's got to find the paper it was wrote on. They will be distributed!! WOOT for sloted and drilled rotors!! Oh and Death, I have a whole 'nother idea for your Fiberglass hood, (does your girl have a hair dryer?) Also, that damn pad clip keeps poping out of place; i put it back 3 times now, i think the clip is bent or something, Matt, do you have another one? -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Feb 26, 2008 - 1:29 PM |
Bring it over - I'll fix it.
Should have stayed longer Sat - we got Havok pulling a 2nd gear scratch and almost taking out my neighbors new camry [speaking of making something fit - the kirkasaurus motor mount was the event of the day] -------------------- ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Mar 1, 2008 - 6:14 PM |
QUOTE(DEATH @ Feb 26, 2008 - 2:29 PM) [snapback]646049[/snapback] Bring it over - I'll fix it. Should have stayed longer Sat - we got Havok pulling a 2nd gear scratch and almost taking out my neighbors new camry [speaking of making something fit - the kirkasaurus motor mount was the event of the day] Hah- that motor mount. I sure could use one too~ -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Aug 10, 2008 - 1:28 PM |
Okay, it's been a while sience my last update, I even forgot to shoot out on here for my last few mods Sorry ya'll. Just busy.
Mostly been chasing down electrical gremlins, I'm going to update the old stuff (w/ pics) and TRY to get new stuff pics! I've finaly got the new shop open and back in busniess! Fiberglass work has already started, and i'm currently installing a few gauges in the car. Several turbo parts have been purchased (about 40-50 percent, but by the time i'm done i'll be working with 175-200 percent of the items i need ) The d/s rotors have been installed, and i dont believe any intorduction to the gellette spoiler is needed I'm also trying to rather grab a new bumper and my new spray equip should be in, maybe 2-3 weeks, IDK for sure. Start switch installed, and idk what else off the top of my head. I'll get ya'll hooked up w/ an update soon. Also, if anyone needs fiberglass work done, Feel free to PM, by next weekend you guys will have fully finished pictures of what i've got up my sleeve. I've talked alot, but finaly out of the tiny appt, and back in a garage time for yall to see what i'm all about (BTW newcougar.net may still have some of my work, IDK, IDC ) oh yeah, my daugter is fcuking huge!! -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Aug 10, 2008 - 7:36 PM |
just curious but how did u secure the razor blade??
Aug 10, 2008 - 9:06 PM |
Fiberglass 101,
stay tuned in.. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Lo-Fi Version | Time is now: November 23rd, 2024 - 7:50 PM |
