Dumb question, about engine swaps in general |
Feb 23, 2008 - 1:41 AM |
Enthusiast Joined Oct 2, '07 From Manitoba, Canada Currently Offline Reputation: 6 (100%) |
My friend keeps telling me that it is impossible to put an engine from a rwd or awd car into a fwd car because the engine would not face the same direction and would need to be rotated
And i am trying to tell him that a 3sgte would drop right into my gt with no custom work (if i got a clip) So could someone please explain... This post has been edited by Promasta: Apr 10, 2010 - 4:02 PM |
Feb 23, 2008 - 1:53 AM |
Enthusiast Joined Aug 28, '04 From FLA USA Currently Offline Reputation: 4 (100%) |
Then your friend doesn't know much about Celica and MR2 and how S-series engine is mounted on these cars.
They are basically the exact same engine mating to different transmissions. You can put 3sgte engine from MR2 turbo in your Celica without any custom work. It has been done many many times. This post has been edited by Gary: Feb 23, 2008 - 1:57 AM -------------------- _Gary
Feb 23, 2008 - 2:39 AM |
Enthusiast Joined Dec 8, '05 From torrance/carson, ca Currently Offline Reputation: 11 (100%) |
first tell your friend that nothing is impossible. then tell your friend that he don't know ish and needs to do some research before running his mouth. finally, swap in a 3s into your car and tell your friend i told you so.
-------------------- ss-iii splitters and 404 skirts are on. which means i need to update my sig. |
Feb 23, 2008 - 4:41 AM |
Enthusiast Joined Aug 11, '07 From Corona, CA Currently Offline Reputation: 4 (100%) |
QUOTE(j0e_p3t @ Feb 22, 2008 - 11:39 PM) [snapback]644834[/snapback] first tell your friend that nothing is impossible. then tell your friend that he don't know ish and needs to do some research before running his mouth. finally, swap in a 3s into your car and tell your friend i told you so. x2 -------------------- Pandelica 2.0 in progress. |
Feb 25, 2008 - 1:18 AM |
Enthusiast Joined Sep 29, '05 From Rochester, Massachusetts Currently Offline Reputation: 2 (100%) |
you can take a look here for a bunch of info...
http://www.6gc.net/forums/index.php?showtopic=1311 - the engines sit the same way, the only thing that is effected by the fact that the engine may come from a rwd or awd car is the transmission (mostly) as far as "how engines work" if u want to learn the basics... http://auto.howstuffworks.com/engine.htm -------------------- The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed? |
Lo-Fi Version | Time is now: November 25th, 2024 - 9:38 PM |
