![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) ![]() |
so did you get a chance to weld in the crossmembers yet?
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) ![]() |
x2, set the rest of your life aside you now have an obligation to the 6gc community
![]() Enthusiast ![]() ![]() Joined Nov 4, '03 From Colorful Colorado Currently Offline Reputation: 13 (100%) ![]() |
let just inform you that you have been talked about a lot...people are impressed... i have been getting ims from ppl telling me i should have shown them this thread lol...lots of props...word is getting around fast. only one question....whats it like being famous? LOL thats funny, I'm doing what I love to do, Custom Automotive Fabrication Thank You all for your comments! -------------------- 1996 Toyota Celica Convertible GT (My 1st Celi,Owned since 2002)
1995 Toyota Celica Coupe GT 3S-GTE 1994 Toyota Celica Liftback GT-Four (RHD/GT-Four conversion) 1990 Toyota Xcab 1UZ-FE Lexus V8, Solid Axle Swap on 35s geared and locked dual Tcases (Rock Crawler) 1990 Toyota 4Runner 5VZ-FE V6 swap, Solid Axle Swap on 38s (Rock Crawler) 1972 Ford F-350 Crew Cab 4X4 Cummins Turbo Diesel (Tow Rig) 1956 Ford F-100 429 / Automatic 1969 Ford Mustang Fastback 429 Tubbed and Caged (Drag Car) 1967 Ford Mustang Fastback 427W / Automatic 1965 Ford Mustang Fastback 347 / 5-speed |
so did you get a chance to weld in the crossmembers yet? It's welded just enough to keep from falling out. I'm going to run it up to the alignment shop to make sure its nice and square before I make it permanet -------------------- 1996 Toyota Celica Convertible GT (My 1st Celi,Owned since 2002)
x2, set the rest of your life aside you now have an obligation to the 6gc community ![]() I would cause I have the time. But since I was laid off the week of thanksgiving I have no money ![]() and besides its been like below zero the last couple days (cost too much too heat the shop) This post has been edited by TheMadScientist: Dec 17, 2008 - 11:47 PM -------------------- 1996 Toyota Celica Convertible GT (My 1st Celi,Owned since 2002)
what size wire are you feeding for the weld?
what size wire are you feeding for the weld? thirty five thousandths .035" -------------------- 1996 Toyota Celica Convertible GT (My 1st Celi,Owned since 2002)
Nice, thats what I use now in class.
Do you think Rav4 parts would work for an awd conversion? -------------------- 98 Celica gt red- totaled deer
Do you think Rav4 parts would work for an awd conversion? Don't know haven't seen the suspension on one. I bet its more trouble than it's worth. I'm sure its has a completly different geometry -------------------- 1996 Toyota Celica Convertible GT (My 1st Celi,Owned since 2002)
I thought so, I guess I'll have to save up the grand for the 205 rear end parts.
offtopic:
werent you trading for a subaru? -------------------- ![]() |
Just added 4 more pics , You asked for them
thanks for the updated pics. That looks really good.
o btw enderswift, I'm keeping it and doing the awd conversion this summer, if I can collect the parts. -------------------- 98 Celica gt red- totaled deer
![]() mad scientist, your a beast. cant wait to see how you set up the tank -------------------- ![]() |
Enthusiast ![]() ![]() ![]() Joined Apr 23, '08 From boston MA Currently Offline Reputation: 5 (100%) ![]() |
Good job man... makes me wish I took more usefull pics...lol
What did you use to cut the spare wheel well with? A plasma cutter?
What lines are you using to run the fuel? I would assume you would have to extend the lines correct? Are the channels in your crossmember threaded for the bolts to hold the cradle on, or did you weld on a nut onto the channel? -------------------- 98 Celica gt red- totaled deer
What did you use to cut the spare wheel well with? A plasma cutter? I used a cut off wheel on a grinder What lines are you using to run the fuel? I would assume you would have to extend the lines correct? I was just going to extend them Are the channels in your crossmember threaded for the bolts to hold the cradle on, or did you weld on a nut onto the channel? I welded a nut inside the channel This post has been edited by TheMadScientist: Dec 18, 2008 - 4:12 PM -------------------- 1996 Toyota Celica Convertible GT (My 1st Celi,Owned since 2002)
![]() Enthusiast Joined May 26, '07 From Foco, CO Currently Offline Reputation: 0 (0%) ![]() |
Nice project. where in colorado are you. i live in fort collins since i go to CSU, but im down in denver every weekend...
-------------------- ^^Ted^^
1990 Pearl White Celica Alltrac 2006 kawasaki ninja |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 7, '07 From Corpus Christi, TX Currently Offline Reputation: 7 (100%) ![]() |
So did u tac the crass member or did u spot weld in certen areas? how hard was it to make the template, and did the drrive shaft sit flush easily next to the exhaust?
-------------------- From Japan to Texas my st202 follows me.
![]() Being different from every angle of the word, leading the Revolution (TOYOTA NATION) The RHD st202 that made it from Japan check it out. http://www.6gc.net/forums/index.php?showtopic=78103 |
So did u tac the crass member or did u spot weld in certen areas? how hard was it to make the template, and did the drrive shaft sit flush easily next to the exhaust? The cross members will be fully welded to the frame rails. The back one was easy the front one was not. I don't know about the exhaust haven't installed it yet. -------------------- 1996 Toyota Celica Convertible GT (My 1st Celi,Owned since 2002)
Lo-Fi Version | Time is now: April 21st, 2025 - 7:12 PM |
