> tocking when i stop, What the heck?
post Feb 26, 2008 - 9:26 PM
D-Man
Joined Jan 18, '08
From Houston
okay, so i just changed my rotors...
I did the pads as well, everything was done correctly. I live by the law of doing it once, and doing it right. However, with the new rotors, on the front driver side, there is a tocking noise when i stop (tick-TOCK) tock noise. I can feel it in my break pedal as well, and i had another member (an ace of trades) over this night to help me trouble shoot the problem...
At first i thought it to be a loose clip (between the caliper and the pad) but i have readjusted it 3 times, and with my buddy over we did it again. This time we bent the flex of the clip to ensure proper connectivity. However it still tocked...
It is a noise that you can not only hear, but feel as well in the pedal. It's driving me nuts. This was not an issue on the old rotors. Plus, i know for a fact that the rotors are not warped, it only does this on breaking.
could i get any ideas? help? something? WTF? theese are nice rotors and i dont wanna revert back due to this...
Damn D-Man - most impressive.
post Feb 26, 2008 - 9:39 PM
thedrunkfish
Joined Jul 4, '07
QUOTE(D-Man @ Feb 26, 2008 - 9:26 PM) [snapback]646258[/snapback]
I had a similar problem with the back (tick tocking) and it was the brake pad moving around, the mechanic welded a little piece onto the brake pad to make it fit better, no knocking scince. Just my 2c
post Feb 26, 2008 - 10:11 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
hmmm failing brake hydraulics???
hope not O__o
post Feb 26, 2008 - 10:39 PM
D-Man
Joined Jan 18, '08
From Houston
the noise is adjacent with the revolution of the wheel (or rotor) It's only when breaking fairly hard.
*EDIT* ALSO, i need to fix this by friday, or i'm going to a local break place, and PAYING to have it fixed mad.gif mad.gif mad.gif mad.gif mad.gif mad.gif mad.gif mad.gif mad.gif mad.gif mad.gif mad.gif
This post has been edited by D-Man: Feb 27, 2008 - 9:30 AM
post Feb 27, 2008 - 9:30 AM
D-Man
Joined Jan 18, '08
From Houston
bump
post Feb 27, 2008 - 10:24 AM
D-Man
Joined Jan 18, '08
From Houston
someone? anyone? please?
post Feb 27, 2008 - 10:55 AM
DEATH
Joined Dec 19, '07
From tx
I like the moving pad idea - only problem is how to diagnose. Could simply be a problem with the pads or your caliper clips not holding them in place right. You did have four of those clips situated on each end of all four pads up front right?
BTW- Patience - someone on here will have the right answer [I think we may already have heard it] - I no longer think this is a life threatening situation [but def be carefull - we'll get it figured out]. Did you happen to keep your old pads? If so and if there is some life left in them, try switching them back on that wheel. If that fixes the problem then you can add one new pad back at a time until the problem comes back - then you'll know where it is. All of this should be done with slow 5-10mph driving/braking in an area where you know you won't get into traffic or problems.
There may be a better idea or a problem with mine but we are willing to listen to suggestions/critisisms
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Feb 27, 2008 - 11:03 AM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
my turn to take a crack at this:
1) did you put the 2 anti-rattle springs on the front pads?
2) did you use any anti-queel goop on the back of the pads t?
3) did you tighten your caliper bolt and make sure its tight and not just spinning freely because of that one annoying nut that you need to put a wrench on
post Feb 27, 2008 - 12:02 PM
D-Man
Joined Jan 18, '08
From Houston
QUOTE(DEATH @ Feb 27, 2008 - 10:55 AM) [snapback]646415[/snapback]
Yeah, i know it was dark last night, and hard to see under a black car, lol. But yeah, all 4 clips are on. And this morning, i felt that clip, and it was still holding (after i got to work)
Patience... I have as much patience as you (or the rest of us) have money... NO WHERE NEAR ENOUGH!! lol. laugh.gif
But for-sure, i'm going to swap out those pads tonight,and see how that treats me, if it still acts up, i think on friday, i'll flip that rotor and flip the pads back to see if it helps... Hopefuly it's something on those pads, bc i got the others (they were still good, i just wanted to install all the GT/hardcore stuff at once.)
QUOTE(LewFX @ Feb 27, 2008 - 11:03 AM) [snapback]646418[/snapback]
1) there are 2per pad, total of 4 per caliper. Yes they are installed, and was thought to be the problem. But nope, they're not.
2) Pads came with it, and yup it was put on.
3) ask that member DEATH (above your post) he watched me secure it before he drove my car. it's tighter than my first girlfri.... nevermind. it's tight.
This post has been edited by D-Man: Feb 27, 2008 - 12:03 PM
post Feb 27, 2008 - 12:05 PM
DEATH
Joined Dec 19, '07
From tx
Yeah but he may have something there - you didn't use a backup wrench on the nut "underneath" the one you tightened did you?
Lew - you think this would cause that noise? I was sort of under the impression that if you didn' use a backup wrench but still got it tight itwould just bind up the caliper - but IDK cause I've always used one.
This post has been edited by DEATH: Feb 27, 2008 - 12:09 PM
EXT: WRC/TRD/404
post Feb 27, 2008 - 12:13 PM
LewFX
Joined Jan 28, '05
it might be since the pad is still moving
take the long caliper bolt out...see if you can wrench that 17mm nut or whatever size it is...tighten that then try the caliper bolt with wrench on the nut
This post has been edited by LewFX: Feb 27, 2008 - 12:15 PM
post Feb 27, 2008 - 12:23 PM
D-Man
Joined Jan 18, '08
From Houston
QUOTE(DEATH @ Feb 27, 2008 - 12:05 PM) [snapback]646438[/snapback]
not to sound like a 'tard, but what do you mean "backup" wrench?
QUOTE(LewFX @ Feb 27, 2008 - 12:13 PM) [snapback]646442[/snapback]
Yeah, i've been using regular sockets...
So take off the caliper and the caliper-bracket? secure the caliper onto the bracket and replace as one assembly? Because the long bolt is on the bracket. (17mm or 18mm i believe)
How would that help? Or have i misunderstood completely?
This post has been edited by D-Man: Feb 27, 2008 - 12:23 PM
post Feb 27, 2008 - 12:26 PM
DEATH
Joined Dec 19, '07
From tx
right on - any other thoughts? I'm gonna try to get him to my garage where the tools light and heat will allow us to work better and longer. Unfortunately he's the proud father of a new born so getting time for this is tough. then again brakes are important to her daddy's safety too.
I'm free Sat morning for an in depth investigation. Or any night for an emergency situation or an hour or two w/e.
DON'T TAKE THIS TO A SO CALLED "PROFESSIONAL" yet
EXT: WRC/TRD/404
post Feb 27, 2008 - 12:30 PM
LewFX
Joined Jan 28, '05
no need to take caliper off..someone host a pic of the caliper so i can highlight the area
post Feb 27, 2008 - 12:31 PM
DEATH
Joined Dec 19, '07
From tx
QUOTE(D-Man @ Feb 27, 2008 - 12:23 PM) [snapback]646447[/snapback]
Bingo - I'm getting what he's saying tho.
EXT: WRC/TRD/404
post Feb 27, 2008 - 12:39 PM
D-Man
Joined Jan 18, '08
From Houston
QUOTE(DEATH @ Feb 27, 2008 - 12:26 PM) [snapback]646451[/snapback]
yeah, thats deffienetly a plan for sat. morning. gotta figure out this break problem...
So I'm going to swap pads, and see whats up with this bolt too... See if i cant see anything... (in my cold & dark working/parking lot...) tonight, Because i'm scared it going to break something, Especialy if i'm crusin down eldrige pushing 60-65 (90-95 when i'm late for work) or one of our MANY freeways and have to crunch on em...
I know that i'll stop, the others are holding in perfect condition. But that one, it could really do some damage to the rotor, or maby to the calipers or worse.... And i dont wanna be shredding those beautiful new calipers; Death, you seen em.
So any 2cents would earn my thanks....anyone~
post Feb 27, 2008 - 12:44 PM
D-Man
Joined Jan 18, '08
From Houston
QUOTE(LewFX @ Feb 27, 2008 - 12:30 PM) [snapback]646455[/snapback]
here's a few
IPB ImageIPB Image
IPB ImageIPB Image
IPB ImageIPB Image
i dont have any of the calp pulled all the way off....
This post has been edited by D-Man: Feb 27, 2008 - 12:46 PM
post Feb 27, 2008 - 12:52 PM
DEATH
Joined Dec 19, '07
From tx
You don't need it. Top right picture would be perfect if it was light enough to make out the diff parts. I can't from here but my monitor is a few years old flat screen - maybe someone else can? I can see whre it's at but couldn't make it out enough to explain it to you.
EXT: WRC/TRD/404
post Feb 27, 2008 - 1:04 PM
D-Man
Joined Jan 18, '08
From Houston
QUOTE(DEATH @ Feb 27, 2008 - 12:52 PM) [snapback]646486[/snapback]
you know my phone sucks... remember the last houston meet? @ dennys? you and me were the only ones with pics... mine were blury and yours were dark, lol. We still need to put em together to make a decent camera for this saturday.
But it would be awsome if someone could break it down for me. Plus i made sure i had pics of all stages so if it'll help.
Oh death, on the 1st pic, the caliper isnt on. Its the pads and the caliper bracket only. lol. your moniter at work does suck huu? laugh.gif
post Feb 27, 2008 - 1:09 PM
DEATH
Joined Dec 19, '07
From tx
EXT: WRC/TRD/404
Lo-Fi Version Time is now: December 4th, 2024 - 4:16 AM
