> 3rd gear, i think shes going slowly
post Feb 27, 2008 - 2:54 PM
speedfeen
Joined Jan 31, '08
From Canada
well i am mechanically inclined BUT remember i do autobody not mechanical lol
SO heres the story
Your driving, your going faster than 50km/h and u go to shift into 3rd and it grinds bad.....you do it when your going slower it doesnt do that....and well lets just say that more than once i go to ds into 3rd and it doesnt wanna go in.......
syncro? transmission? i know its easier to guess at what it is instead of seeing it but what do you guys think it is? just because it will do it sometimes and not other times im thinkin it may be the syncro....
ideas..
FEEN
post Feb 27, 2008 - 2:57 PM
_mikeE
Joined Sep 28, '07
From Toronto, ON
Most likely the synchro, I have to change my synchros in my 2nd and 3rd gear as well, shifting is so choppy.
Also, have you changed out your tranny fluid too.
However, best bet is to bring your tranny into a tranmission shop, some will do a free inspection for you to find the issue.
The acura tl's have this similar problem as well, and their resolution is to change their tranny fluid particular from GM. Interesting but yeah.
This post has been edited by _mikeE: Feb 27, 2008 - 2:58 PM
post Feb 27, 2008 - 3:00 PM
speedfeen
Joined Jan 31, '08
From Canada
wholly fast freakin reply
no actually while i think about it the tranny fluid hasnt been changed, get some and throw some lucas in it....wouldnt hurt any
FEEN
post Feb 27, 2008 - 3:20 PM
_mikeE
Joined Sep 28, '07
From Toronto, ON
Yea, I'm a pretty active member on this site.
I too need to change my tranny fluid. I'm thiknin bout using Quakerstate 100% synthetic.
post Feb 27, 2008 - 3:34 PM
97lestyousay
Joined Jul 7, '03
eh 3rd gear you don't need it I have been driving my corolla gts
JDM guy made me do it.
post Feb 27, 2008 - 3:43 PM
speedfeen
Joined Jan 31, '08
From Canada
tis true its not a gear that you absolutely need but i wanna drive a car where everything works lol
FEEN
post Feb 27, 2008 - 4:42 PM
celicamike
Joined Dec 26, '05
From So Cal
A lot of people on here who have had problems with their synchros, especially grinding into third gear, have had the problem solved by changing tranny fluid using Pennzoil syncromesh (spelling?). I had the same problem you did, and it went away when I replaced the gear oil with syncromesh. The stuff really works, which came as a surprise to me, because I've always been told that Pennzoil is crap.
post Feb 27, 2008 - 4:48 PM
QUOTE(celicamike @ Feb 27, 2008 - 4:42 PM) [snapback]646628[/snapback]
agreed.
penziol syncromesh ftw.
post Feb 27, 2008 - 5:09 PM
speedfeen
Joined Jan 31, '08
From Canada
is syncromesh universal? or does it come in grades like the rest of the fluid?
This post has been edited by speedfeen: Feb 27, 2008 - 5:09 PM
FEEN
post Feb 27, 2008 - 6:20 PM
post Feb 27, 2008 - 7:05 PM
alltracman78
Joined Aug 9, '06
From Ma
QUOTE(speedfeen @ Feb 27, 2008 - 3:00 PM) [snapback]646552[/snapback]
Changing it's a good idea, but don't use Lucas, it will thicken your oil, to stop the synchros from grinding you want to thin it.
That's what the synchromesh will do, thin it.
The GM stuff Mike E is talking about is the same stuff, just in a different bottle and more expensive.
I would suggest you do half and half or less [no more than half synchromesh], thin is better for the synchros, but thick is better for the gears. Since you live in Canada, 75W 90 is best. The synchromesh will mix with gear oil fine.
It only comes in one grade, what you see in the pic.
However, I would also suggest you shift at a bit higher engine speed. The snychros job is to match gear speeds, but you can help it by shifting in the right engine speed range [sounds like you're shifting a bit to low].
Less work for the synchros [they're metal brakes in your trans] means they won't wear out or break as soon.
QUOTE(speedfeen @ Feb 27, 2008 - 3:43 PM) [snapback]646582[/snapback]
post Feb 27, 2008 - 7:42 PM
celicamike
Joined Dec 26, '05
From So Cal
QUOTE(alltracman78 @ Feb 27, 2008 - 4:05 PM) [snapback]646722[/snapback]
Yeah, I mixed syncromesh with the regular 75W90 gear oil when I did mine. It takes about 3 quarts to fill the gearbox, so I bought 2 quarts of syncromech and 1 quart of regular gear oil. I live in southern california though.
This post has been edited by celicamike: Feb 27, 2008 - 7:42 PM
post Feb 28, 2008 - 4:27 AM
_mikeE
Joined Sep 28, '07
From Toronto, ON
Okay, i'im gonna change my tranny fluid and see if it still feels choppy when shifting into 2nd and 3rd gear at higher rpm's.
Also, around how many km's do you think I should change the fluids mixing 2 quarts of the pennzoil and 1 quart of regular 75W90
post Feb 28, 2008 - 4:29 AM
TGC-Komodo
Joined Dec 17, '07
From Montreal
What Mike says is true .. sort of.
The 3G Acura TLs have the infamous 3rd gear issue, as well as second. The gear will either grind in our out of gear... and as well as pop out of place and back into neutral.
What he has wrong is that it's not just "GM Synchromesh" that we use to resolve [not fix] the issue. It's GM Synchromesh Manual Transmission Fluid: Friction Modified. It's much better than ordinary GM Synchromesh Manual Transmission Fluid.
I'm not sure about 6GCs but on the 3G TL, the GM Syncromesh:FM works miracles.
It's not that expensive either. Not even 14 dollars Canadian. The regular Synchromesh is just about 11 or so.
'89 3.1L Oldsmobile Cutlass Supreme
'o4 Acura TL: Dynamic
;; AEM CAI, P2R TB Spacers+Gaskets, C.F. Pillars, JDM Roof Spoiler, C.F. Front Bumper Insert
Sound.Vision.Soul // Drive.Drift.Dream
QUOTE(purplegt4)
you better hope _mikeE doesn't become the next moderator: he makes the big font bold.
post Feb 28, 2008 - 10:35 AM
speedfeen
Joined Jan 31, '08
From Canada
Well we have had the car since i joined so less than one month and we are still trying to get everything else right so tranny fluid wasnt the first thing, and the higher i shift the worse the grinding gets, if i go low then it wont :S works weird, and it terrible when down shifting so i now entirely skip 3rd gear and brake a little bit more.....i am almost apt to not to even use 3rd gear the sound drives me crazy!
and yea dont mind putting some money into it of course till i get my fd lmao then its an arguement of what car the money goes to biggrin.gif
i cant wait! lol
and thanks for the pic of the syncromesh!
My .02
not to be a suck hole but i love this site, its the first place that im actually taken seriously being a woman in the trade and on the site! AND that im not degraded and if i say something wrong i dont get completely flamed...Appreciate that!
FEEN
post Feb 28, 2008 - 10:51 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
I just changed out my fluid with Lucas oil and DAMN shifting is a pain!
but i'm more concerned with my gears than shifting so w/e.
i shift slow now, theres no need to shift hard and try and chirp gears lol.
Maybe ill try more syncromesh.
post Feb 28, 2008 - 12:07 PM
Rayme
Joined Feb 18, '06
From NB, Canada
I used synchromesh (GM synchromesh, which is beleived to be the same as penzoil) in the transmission.
And thats 4 quarts of that stuff, not just half or 1 quart.
Greatest thing ever.. I drove 100 000 KM on it and the grinding never came back.
do it! In those cold NB winter, the tranny shifter BETTER as it gets colder, pretty awesome stuff...
This post has been edited by Rayme: Feb 28, 2008 - 12:08 PM
-Rémy
02 SiR, 08 250R
post Feb 28, 2008 - 12:14 PM
_mikeE
Joined Sep 28, '07
From Toronto, ON
What?! 4 quart's?
I'm reading some ppl using 3, my buddy's TL using 2.3 quarts, and now you're using 4? Ah I hope my manual tells me how much I'll need.
Btw you used completely the GM fluid, you didn't mix with regular like the other member did?
post Feb 28, 2008 - 1:17 PM
TGC-Komodo
Joined Dec 17, '07
From Montreal
QUOTE(speedfeen @ Feb 28, 2008 - 10:35 AM) [snapback]647037[/snapback]
i cant wait! lol
My .02
A woman driving manual... and who will eventually get an FD? Oh thats hot =o lol thumbsup.gif
I suggest someone with a 6GC try using the GM Synchromesh friction modified. It's better than the ordinary synchromesh. I can provide the part number for US and Canadian members if anyone is interested.
QUOTE(purplegt4)
post Feb 28, 2008 - 1:53 PM
speedfeen
Joined Jan 31, '08
From Canada
right here! me want me want!
thanks for the compliment
and no i dont care if im 100 and my bones are brittal i will never drive an auto.....if i cant shift cause my hip will break then....ill do it the paddle way wink.gif
FEEN
Lo-Fi Version Time is now: November 23rd, 2024 - 10:44 AM
