> Lowering springs, spring compressors???
post Feb 27, 2008 - 11:15 PM
CelicaProgress
Joined Jan 15, '08
From Secaucus NJ
I was reading an article on this nissan with a seriousss drop... it was sayin how when u lower ur car u should put on spring compressors or use them or sumthing like that ...are they sumthing u leave on the springs ??? orr is it just used when ur installing them??? anyone know? anyone use sumthing like this on ur lowered ride?
post Feb 27, 2008 - 11:26 PM
_mikeE
Joined Sep 28, '07
From Toronto, ON
You need to use a spring compressor to install.
However if you're going to go with lowering springs, you should get some better shocks or gas struts.
I've heard that going this route is better than getting coilovers because it's set at a standard height already whereas if you get coilovers, you set your own and u can go too low and do some damage, and u might need a camber kit doing so.
post Feb 27, 2008 - 11:37 PM
celicaST
Joined Jun 23, '05
spring compressor is a tool to help removing/installing springs since they are usually under compression. i installed mine myself and didnt use a spring compressor, no big deal. just e careful unscrewing the nut when taking them off. to put the front springs on i just used the help of my bros body weight smile.gif on the 6g, only the fronts are under compression, so no need to worry about the back
post Feb 27, 2008 - 11:43 PM
CelicaProgress
Joined Jan 15, '08
From Secaucus NJ
Great thanks guys
post Feb 28, 2008 - 1:59 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
just to show of... I have own picture of spring compressor as well biggrin.gif
Lo-Fi Version Time is now: November 27th, 2024 - 9:15 AM
