HELP!!!!!!!!, one of those overheating problems |
Feb 28, 2008 - 8:17 PM |
Enthusiast Joined Jan 9, '08 From Scarborough, Ont Currently Offline Reputation: 1 (100%) |
Sorry guys i tried to search but nothing came up!!
ANYWAYS, so my car is infact over heating. First week i noticed this- K!!! so about a week ago my temp gauge started acting up....it would rise..then when i turn my heater on it would drop. Couple days later my heater would no longer work, so i checked my coolant and barley had anything left so i topped it up. Everything seemed fine for a bit, then a day or two after my temp gauge reach above 'H' and i pulled over and it sounded like my head was boiling a nice pot of soup. I waited a bit and quickly released the rad cap. It steemed for a bit (obviously) and i toped it off with coolant and it ran fine for a day or two. So today on my way to work i ended on heading back home on a flat bed. My temp gauge stayed at above 'H', no warm air....i topped it of with coolant, and i donno where it goes :| its hard for me to tell if theres a leak...and i hope its not my head gasket? |
Feb 28, 2008 - 8:21 PM |
Enthusiast Joined Aug 21, '07 From Toronto Currently Offline Reputation: 1 (100%) |
Is your radiator fan working alrigt? what about the radiator itself? Check radiator fan fuse. Is coolant actually getting low that's why you keep adding up? Then you might have a leak somewhere.
-------------------- -Derick
"In hoc signo vinces." In this sign thou shalt conquer." Gone but never forgotten.... |
Feb 28, 2008 - 8:25 PM |
thats what i thought hmmmm i'll go check right now...derick come over and help me :'(!!!!!!!!
Feb 28, 2008 - 8:27 PM |
Enthusiast Joined Nov 23, '07 From Houston TX Currently Offline Reputation: 0 (0%) |
check for leaks. hoses, Rad and water pump. those are the most likly things to be broke. check those first.
Feb 28, 2008 - 8:29 PM |
Not tonight and tomorrow coz its my turn to babysit... if you were'nt able to fix that up before saturday morning then I might be able to help you out if they don't call me at work.
Feb 28, 2008 - 8:31 PM |
Enthusiast Joined May 1, '03 From Houston , Texas Currently Offline Reputation: 4 (100%) |
You've definately got a leak somewhere.. You should not have to continue refilling it. Also check and make sure your water pump it flipping open that is a huge reason you would have boiling coolant. changing a water pump valve is fun and easy try and check that. When at idle you should hear something click and open your fans will get faster and your idle will drop a wee bit. Check that.
- Matt |
Feb 28, 2008 - 8:34 PM |
haha thank i was just kidding though, its late and cold....its been running for the past 3 minutes now and the fan isn't coming on
QUOTE(politicsareevil @ Feb 28, 2008 - 8:31 PM) [snapback]647408[/snapback] You've definately got a leak somewhere.. You should not have to continue refilling it. Also check and make sure your water pump it flipping open that is a huge reason you would have boiling coolant. changing a water pump valve is fun and easy try and check that. When at idle you should hear something click and open your fans will get faster and your idle will drop a wee bit. Check that. - Matt hmmm but can't there be a possibily that the coolant is burning off?? but yeah i'll check harder for leaks |
Feb 28, 2008 - 8:40 PM |
QUOTE(Theshanon @ Feb 28, 2008 - 8:34 PM) [snapback]647410[/snapback] haha thank i was just kidding though, its late and cold....its been running for the past 3 minutes now and the fan isn't coming on QUOTE(politicsareevil @ Feb 28, 2008 - 8:31 PM) [snapback]647408[/snapback] You've definately got a leak somewhere.. You should not have to continue refilling it. Also check and make sure your water pump it flipping open that is a huge reason you would have boiling coolant. changing a water pump valve is fun and easy try and check that. When at idle you should hear something click and open your fans will get faster and your idle will drop a wee bit. Check that. - Matt hmmm but can't there be a possibily that the coolant is burning off?? but yeah i'll check harder for leaks Isn't the fan supposed to turn on automatically when it heats the proper temp? Check your temp guage again and make sure it doesn't go to H or you might damage your engine. If the fan doesn't turn on check the fuse... That happened to me once... i checked everything and replaced a lot thinking those were the faults and when I checked the fuse its busted. Too late, after spending around 40$ on other parts rather than just 2$ on fuses. -------------------- -Derick
Feb 28, 2008 - 8:43 PM |
first, you killed the thermostat, that needs to be replaced. Next, there might be a leak or it might be even worse - change your oil - see if there is any coolant in there, it would look like coffee pouring out. If so, headgasket.
Feb 28, 2008 - 8:46 PM |
Lets hope you didnt blow your head gasket but yeah definately thermostat is gone... and no your coolant wont burn off unless it escapes its closed system. if you see steam that means your coolant escaped to a hot componant and is venting its steam..
- Matt |
Feb 28, 2008 - 8:53 PM |
Enthusiast Joined Sep 28, '07 From new jersey Currently Offline Reputation: 1 (100%) |
you should replace your radiator, or thier a little cap under the raditor its on the left bottom side of the radiator mayb its lose.
Feb 28, 2008 - 8:57 PM |
Is the radiator leaking..... Go to your local autoparts store and buy a leak detector. It will be a can of something to put in the radiator and a light pen. Have you ever seen the CSI shows where they shine the purple light and see all the semens and the hidden bloods..... thats exactly what this is. Its a uv visible liquid and a UV light pen put it in and run the car and see your leaks. Check the thermostat if you dont hear a click at idle and rpms dont drop your therm housing didnt open.
- Matt |
Feb 28, 2008 - 8:59 PM |
QUOTE(pabel89 @ Feb 28, 2008 - 8:53 PM) [snapback]647426[/snapback] you should replace your radiator, or thier a little cap under the raditor its on the left bottom side of the radiator mayb its lose. hmmm you my friend might be right, but my rad was replaced a couple of monthes ago but it looks kinda wet around where the drain plug for the rad might be i'll check!!!! ***Update*** noticed when i came back from toyota that they didn't put the rad cap on properly.....so i put it on and let it idle since the time i started this topic.....cars temp stayed at level for the first five minutes and then rose slightly higher....fan has not come on since so i need to check that big fuse.... i switched the car off cause the temp rose up higher QUOTE(politicsareevil @ Feb 28, 2008 - 8:57 PM) [snapback]647428[/snapback] Is the radiator leaking..... Go to your local autoparts store and buy a leak detector. It will be a can of something to put in the radiator and a light pen. Have you ever seen the CSI shows where they shine the purple light and see all the semens and the hidden bloods..... thats exactly what this is. Its a uv visible liquid and a UV light pen put it in and run the car and see your leaks. Check the thermostat if you dont hear a click at idle and rpms dont drop your therm housing didnt open. - Matt sorry for the double post but i was posting right after you put that, hmmmm that sounds wicked i wanna give that a try but my partssource is closed!!! do you know how much those go for?? |
Feb 28, 2008 - 9:06 PM |
About 20-45$ depending. Its pretty sweet. It works wonders. Even if the plug was loose or the cap was not on properly, that isnt your main problem. By the way... Rinse your engine and radiator off before you do the UV stuff so you dont see stuff with the light that might be old. When I did mine I saw blood from the times I racked my knuckles on stuff haha. Good luck. Let me know how it goes.
- Matt |
Feb 29, 2008 - 2:50 PM |
Enthusiast Joined May 1, '03 From Michigan Currently Offline Reputation: 0 (0%) |
Another way to test the radiator fan - unplug the temp switch / sensor on the bottom of the radiator (for GT, GT-S, and GT4 cars). This will cause the fan to kick on instantly, as long as its got power and relays are working. You can do this test with the car on, but not running - so no worries about overheating while troubleshooting.
-------------------- Scott
West Michigan |
Feb 29, 2008 - 8:43 PM |
Shanon?
You need to take a step back here, there's a lot of confusion in this thread. If you want to sort out what is wrong, do this, it's the most practical way to find out what is wrong. You start with the easy, common stuff and work your way up. It might save you a whole bunch of trouble and some money. First off, try what Scot said. If the fan doesn't turn on, the fan motor is bad or you have a problem in the circuit that supplies power to the fan. Make sure the key is in the on position. If the fan runs, plug the switch [sensor] back in. The next thing you need to do is top off your coolant and put the cap back on. Remove the overflow cap and point it in a safe direction, you don't want to get hot coolant shot at you. Then, run the car. Keep an eye on the temp gauge; the fans should kick on once it reaches [or just before, factory gauges aren't super accurate] a bit past half way. See if the fans come on, if not, you have a problem in the fan control circuit [controls when the fan turns on and off; switch, relay, wiring, ect]. If the fans do come on, let it run. See where the coolant is leaking from. Most likely it will spit out of the coolant overflow. This is the pressure release for the system, instead of blowing a huge hole in something it vents into the overflow tank, and if enough coolant is in there, overflows the tank and you lose the coolant. If this is the case, you either have a bad [clogged] radiator or thermostat [or possibly another problem]. If it leaks out of somewhere else, get that leak fixed [the leak itself could be what is causing the overheating, if you lose too much coolant to a leak it will overheat regardless how well the rest of the system is working]. I'm sorry man, there's no easy way to say this. I'm really not trying to be an ass, but if you want to post and help people you need to learn quite a bit first, this isn't even CLOSE to accurate.... QUOTE(politicsareevil @ Feb 28, 2008 - 8:31 PM) [snapback]647408[/snapback] You've definately got a leak somewhere.. You should not have to continue refilling it. Also check and make sure your water pump it flipping open that is a huge reason you would have boiling coolant. changing a water pump valve is fun and easy try and check that. When at idle you should hear something click and open your fans will get faster and your idle will drop a wee bit. Check that. - Matt QUOTE(politicsareevil @ Feb 28, 2008 - 8:57 PM) [snapback]647428[/snapback] Check the thermostat if you dont hear a click at idle and rpms dont drop your therm housing didnt open. - Matt Your thermostat doesn't make ANY noise when it opens, and doesn't effect engine speed at all. The water pump is always moving coolant [it doesn't "flip" open], that's what the coolant bypass lines are for, they bypass the radiator. There is no water pump valve, though I'm guessing you're referring to the thermostat. QUOTE(politicsareevil @ Feb 28, 2008 - 8:46 PM) [snapback]647420[/snapback] Lets hope you didnt blow your head gasket but yeah definately thermostat is gone... and no your coolant wont burn off unless it escapes its closed system. if you see steam that means your coolant escaped to a hot componant and is venting its steam.. - Matt And overheating does nothing to a thermostat [a bad one can cause overheating, but overheating isn't going to make it go bad] If you see steam it means your coolant is leaking, it will "steam" whether it vents onto the exhaust manifold or if it vents out the radiator overflow. -------------------- |
Mar 1, 2008 - 12:47 AM |
Hey Shanon, were you able to get your car fixed? What was the problem?
Mar 1, 2008 - 1:53 AM |
well i removed the old thermostat and tested it....it was faulty...so i bought a new one replaced it, ran it and its not over heating but had it running for 30 minutes and the fan hasn't come on :| so i'm gonna take it to a shop and check and see.....theres no fuse for the fans....i tried to look, only relays and they cost 40$ :|
Mar 1, 2008 - 2:39 AM |
QUOTE(scothaniel @ Feb 29, 2008 - 2:50 PM) [snapback]647764[/snapback] Another way to test the radiator fan - unplug the temp switch / sensor on the bottom of the radiator (for GT, GT-S, and GT4 cars). This will cause the fan to kick on instantly, as long as its got power and relays are working. You can do this test with the car on, but not running - so no worries about overheating while troubleshooting. thats for the tip man, i unplugged the sensor and the fans did come on instantly!!! |
Mar 1, 2008 - 2:54 AM |
QUOTE(Theshanon @ Mar 1, 2008 - 12:53 AM) [snapback]648008[/snapback] well i removed the old thermostat and tested it....it was faulty...so i bought a new one replaced it, ran it and its not over heating but had it running for 30 minutes and the fan hasn't come on :| so i'm gonna take it to a shop and check and see.....theres no fuse for the fans....i tried to look, only relays and they cost 40$ :| hhhhmmmm thermostat sounds kinda something like something I said... interesting. I might not know everything but I'm not an idiot. |
Lo-Fi Version | Time is now: November 27th, 2024 - 9:38 PM |
