installing front brakes |
Feb 28, 2008 - 9:05 PM |
Enthusiast Joined Jul 26, '07 From riverside,CA Currently Offline Reputation: 0 (0%) |
i did my back brakes and now im doing the front.. im just trying to get rid of the screw so i can slide the caliper up and replace the brakes for now but the screw islike different for both sides which way to i unscrew on the passenger side? do i pull up or do i push down to unscrew it? same for the driver side.
[/size] i went both ways on the passenger side i pulled up and i even broke the ratchet thing, so i started pushing down on it but its not budging... and i dont want to go full strength and break some more.. [size="1"]help please :[ -------------------- QUOTE(thespacepanda @ Feb 21, 2008 - 4:37 PM) [snapback]644164[/snapback] When I worked for Pizza Hut our store won a health code violation. |
Feb 28, 2008 - 9:16 PM |
Enthusiast Joined May 30, '05 From MN Currently Offline Reputation: 8 (100%) |
If your question is about swinging the calipers out of the way to put in pads, then to loosen the bolt you have to turn it counterclockwise. I hope I'm getting your question right.
good luck. Also if the bolt is stuck or hard to turn, use PB blaster on it or a wrench with good leverage. This post has been edited by malecrod: Feb 28, 2008 - 9:21 PM -------------------- 3sgteing.
..burns twice as bright, lasts half as long. "The weight of the world is love. Under the burden of solitude, under the burden of dissatisfaction." -Allen Ginsberg- |
Feb 28, 2008 - 9:31 PM |
Enthusiast Joined Feb 16, '07 From BP, MN Currently Offline Reputation: 7 (100%) |
If removing caliper......bleed brakes...otherwise you would have to put pressure back to the valve that pushes the circular tube enforcing the brakes to bite the rotor......I always use a c-clamp to push it in to easily put the caliper back on....and then pump the brakes after installment....dunno but just might be me...
Feb 28, 2008 - 10:45 PM |
ehi counterclockwise was how i broke the attatchment LOL iunoo maybe it was just cheap... since it felt pretty thin
Feb 28, 2008 - 11:14 PM |
Enthusiast Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
Maybe you need to pump some irons.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Feb 28, 2008 - 11:17 PM |
if i needed to pump iron.... howd i break the attatchment -_-
Feb 28, 2008 - 11:21 PM |
Because the bolt was too strong. lol...
Feb 28, 2008 - 11:23 PM |
so... i need to get a stronger attatchment thingy....? lol
Feb 28, 2008 - 11:30 PM |
Fine you win. Yes you need a stronger attatchment.
Feb 29, 2008 - 1:02 AM |
QUOTE(hongkongnerdboy @ Feb 28, 2008 - 8:05 PM) [snapback]647436[/snapback] i went both ways on the passenger side i pulled up and i even broke the ratchet thing, so i started pushing down on it but its not budging... and i dont want to go full strength and break some more.. with the socket on the bolt (behind the caliper) on the passenger side, pulling up tightens it.. you're supposed to pull down. -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Feb 29, 2008 - 1:31 AM |
thank you. and i guess on the driver side is the opposite?
Feb 29, 2008 - 2:56 PM |
correct. no offense, but this is pretty basic stuff.. g/l with your install..
Feb 29, 2008 - 3:03 PM |
just wondering, did you break the ratchet? or the socket.. more likely the rotating end of the ratchet is what will shear right off from over-torquing. anyway, i hope you have a good branded ratchet that has lifetime warranty. and i hope you're not using a small 1/2" ratchet, you should be using at least a 3/4".
Feb 29, 2008 - 3:13 PM |
you mean a 3/8 not 3/4!
Feb 29, 2008 - 3:15 PM |
well sorry for being a noob..
but we all gotta start learning somewhere right? its not like i can just out of nowhere know how to replace an engine or anything... i got learn and ask questions -------------------- QUOTE(thespacepanda @ Feb 21, 2008 - 4:37 PM) [snapback]644164[/snapback] When I worked for Pizza Hut our store won a health code violation. |
Feb 29, 2008 - 9:13 PM |
Very true.
IMO breaking things is one of the best ways to learn, makes it stick in your mind. I've got a lot of mistakes behind me on the trail. The way I always remembered was loosening is counterclockwise [facing what you're loosening] and tightening is clockwise. -------------------- |
Lo-Fi Version | Time is now: December 12th, 2024 - 3:12 PM |
