> Short shifter, pics
post Feb 28, 2008 - 11:10 PM
mikecelica
Joined Jan 31, '07
From Ontario, Canada
Im about to order a short shifter, the 7th gen ones. but i wanted to see first how short the shaft actualy is? Anyone got a pic of their car with a 7th gen short shifter? thanks
post Feb 29, 2008 - 3:06 PM
Jaws4God
Joined Mar 27, '04
before:
after
post Feb 29, 2008 - 4:36 PM
illneversellmyce...
Joined Jul 11, '06
From Sefner, FL
hmm i see a diff but it aint that much shorter......which one did you like better jaws?
post Feb 29, 2008 - 4:55 PM
FunkySR
Joined Apr 22, '07
From Buckinghamshire, UK
QUOTE(illneversellmycelli @ Feb 29, 2008 - 9:36 PM) [snapback]647837[/snapback]
post Feb 29, 2008 - 8:45 PM
politicsareevil
Joined May 1, '03
From Houston , Texas
Short shifters are sweet but I just put on a razo shift knob the long thin one and the way it sits on the arm makes it feel like a shorter throw. I love it..
- Matt
post Feb 29, 2008 - 8:48 PM
DEATH
Joined Dec 19, '07
From tx
QUOTE(politicsareevil @ Feb 29, 2008 - 8:45 PM) [snapback]647916[/snapback]
- Matt
Remind me about that - I have something you may like.
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Feb 29, 2008 - 10:21 PM
bootslimo
Joined Feb 2, '08
From ohio
QUOTE(mikecelica @ Feb 28, 2008 - 11:10 PM) [snapback]647495[/snapback]
There is a difference between a short shifter and a short throw shifter, if you want a short shift cut your shaft and reweld it.
If you want a short throw weld any type of extension to the underside of the shifter. The longer the extension the shorter the throw.
post Mar 1, 2008 - 10:16 AM
Jaws4God
Joined Mar 27, '04
maybe the angle of the picture doesn't really show but its a lot shorter (height)
it does have a shorter throw and is nice. Def goes into gears faster and smoother.
post Mar 2, 2008 - 12:30 PM
malecrod
Joined May 30, '05
From MN
QUOTE(bootslimo @ Feb 29, 2008 - 10:21 PM) [snapback]647946[/snapback]
X2 thats exactly what I did. I bought a 7gc short throw shifter and cut the bottom part off and welded it to the bottom of my 6gc shifter. Much better and accurate shifting experience.
3sgteing.
..burns twice as bright, lasts half as long.
"The weight of the world is love. Under the burden of solitude, under the burden of dissatisfaction."
-Allen Ginsberg-
post Mar 11, 2008 - 11:51 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
Concerning the short shifters, has anyone ever tried one of these:
http://cgi.ebay.com/ebaymotors/00-04-Toyot...sspagenameZWDVW
I'm looking on Ebay, and all these 7th gen ones look the exact same. Will they work? And how well made are they?
-Matt
post Mar 12, 2008 - 12:05 AM
i have a 7th gen, looks like that too...
post Mar 12, 2008 - 12:31 AM
_mikeE
Joined Sep 28, '07
From Toronto, ON
Well, I don't have any 7th gen's
BUT here's a pic when i took out my stock shifter comparing it with a 6th gen TWM short-shifter.
post Mar 12, 2008 - 1:03 AM
politicsareevil
Joined May 1, '03
Heres what would probably do best. Cut a link out of the top portion and reweld a bit shorter. Cut the bottom and add a bit of length to it... should work yes?
- Matt
post Mar 12, 2008 - 2:33 AM
QUOTE(politicsareevil @ Mar 12, 2008 - 2:03 AM) [snapback]652500[/snapback]
- Matt
i believe there is a how to about that, but it would be easier to buy
post Mar 12, 2008 - 12:31 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
So I could buy the shifter I linked to on Ebay and it would work just fine?
How do you take out the stock piece for that in the first place?
-Matt
post Mar 12, 2008 - 3:17 PM
j0e_p3t
Joined Dec 8, '05
From torrance/carson, ca
^ yeah, that ebay ss will work just fine. as far as quality, its just a metal stick. not much can go wrong. best 40 bucks you can spend. there's a pdf file on how to install the twm ss. same exact instructions. someone should have it saved on their computer.
post Mar 13, 2008 - 1:01 AM
goferris
Joined Feb 14, '07
From Provo, UT USA
the short throw won't look all that much shorter because you have to put the assembly on risers so you don't hit on the bottom. it's designed shorten the throw, not necessarily the height of the shifter. if you want a short throw/short shift stick, get a cheap ebay one, cut a bit off the top portion then weld it back together. now you have a shorter throw (distance between gears when shifting) and the shift stick now looks shorter.
all i can say is i love mine and most people who have been in my car have made comments about it. best 30 bucks spent IMO.
hey jaws, i used to have that same shift boot (except red) on my old 97 LE. i do miss that car sometimes.
This post has been edited by goferris: Mar 13, 2008 - 1:03 AM
Lo-Fi Version Time is now: December 3rd, 2024 - 6:05 AM
