> turbo help asap, would this fit
post Aug 26, 2003 - 4:19 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=2428836113 its a supra turbo but would the flange bolt onto a 3sgte manifold. everyhting else should work right?
post Aug 26, 2003 - 5:47 PM
AJcelica
Joined Sep 13, '02
From BC, Canada
i'm not an expert by any means on this subject, but isn't the CT26 turbo the one that comes stock on the 3sgte? and doesn't the supra come with a twin turbo or something? i'm not sure if i trust what this guy is saying, his english is kind of shotty and it's a little weird that he wanted to keep the turbo for so long without selling it sooner...
but like i said before, you should get another opinion as well as mine rolleyes.gif
post Aug 26, 2003 - 6:14 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
yes, that is the ct-26 turbo, it will bolt up to a 3s-gte turbo manifold, which will bolt up to your 5s-fe block.
feel free to read the thread on turbocharging your 5s-fe.
post Aug 26, 2003 - 7:01 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
i have read ur thread dam it slipped my mind. very good thred by the way. thx
post Aug 27, 2003 - 4:23 AM
1bwilson
Joined Aug 30, '02
From Maryland
Make sure you read the part about the turbo's...... You reminded me about it wink.gif .
-Bryan-
Member of Team 5sfTe
post Aug 27, 2003 - 4:35 AM
KAMiX
Joined Mar 4, '03
I would say if you get it for a bargain you might as well, because you have a lot of options on getting work done on it.
Unless there is a major problem with it, you will be able to get it reconditioned (if not upgraded) fairly cheaply if you shop around.
post Aug 27, 2003 - 5:04 AM
1bwilson
Joined Aug 30, '02
From Maryland
It looks clean and all but the pics are a bit ruff and there are no shots of the impellers. I would not buy a turbo from ebay. Go on the mr2 boards and get one from them. You can get a low milage one from a swap for around 200 or so.
-Bryan-
post Aug 27, 2003 - 11:07 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
i read one turbo add on ebay and it said. two fns are slightly bent but not enuf to affect perfomance. is this true... cuz i told my dad i liked this turbo and he boght it without me even knowing.... so chek it ous. hopefully it works. http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=2429133167 biggrin.gif
post Aug 27, 2003 - 1:47 PM
1bwilson
Joined Aug 30, '02
From Maryland
Well I would take the turbo to a shop to be checked out. Even if you need to rebuild it you made out by getting all the oil and coolent lines with it.
-Bryan-
post Aug 27, 2003 - 9:26 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
what type of shop will do turbo's? also its cheaper to repair a turbo than buy a new one right?...
post Aug 27, 2003 - 9:42 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
well, you just kinda half to look around for a local speed shop, and as far as the cost goes, I've found that its sometimes cheaper to buy a new turbo.
but that allways depends and who you buy from, or who repairs your turbo
post Aug 27, 2003 - 10:40 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
whats a safe psi to run.
post Aug 28, 2003 - 8:50 AM
blkGT
Joined Jun 10, '03
From FL
Hope it all works out for ya, kepe us posted. Im just glad u didnt buy that one from the guy with the shotty english.
post Aug 28, 2003 - 12:42 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
on the 5s-fe I would never recommend boosting higher than 8 psi unless you sre intercooled, this kind of pressure really puts a strain on your connecting rods.
the reason I say no more than 8 unless intercooled is because if you have an intercooler to cool the air in your intake the result will be colder denser air, so if you run 11 or 12 psi intercooled, the mass that the air takes up is less.
also, you will need larger fuel injectors for this kind of boost, something like 360cc, couple these injectors with a supra fuel pump or a nice walbro.
but, as far as having a reliable motor, I would run only like 5 pounds of boost.
keep in mind the intercooler, while many kits do not comewith one, its great to have, the cooler the air, the more dense the air is, the more air is cramed into the combustion chamber, the more power you get
so, at like 5 psi you may make about 9 hp for each psi, with an intercooler it might be a little more wink.gif
post Aug 28, 2003 - 7:54 PM
west_minist
Joined Oct 27, '02
From Barbados
QUOTE (jayi12-15psi @ Aug 28, 2003 - 12:42 PM)
Hi!
There are some conflicting statements above. Review on air mass and dense air.
Why no no to high boost?
>>>Greater heat generated when compress, and more strain on the piston and crank and con. rod when compressing the air.
As always, fuel delivery, head design, carbon built up and many other factors can contribute to pinging since the temp. of the intake air is alot higher.
Also remember that the speed of the compressor wheel also contribute to the temp. as it compress the air.
West_Minist
Hydra EMS Dealer & Tuner
Subaru ECUFlash Tuner
http://www.socob.bb
http://xtremeracingtuning.com
Viciously Tuned, Driven Hard
post Sep 5, 2003 - 10:47 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
alright i bought a ct 26 turbo. i think its a its first genneration one. so this header would fit that turbo...? http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=2431421812 check out how the flange is circular.
thats what my flange on my turbo looks like. soooo any thawts?
post Sep 6, 2003 - 1:52 AM
1bwilson
Joined Aug 30, '02
From Maryland
Yup that sure is thee one you want, make sure it has no cracks first tho.
-Bryan-
Lo-Fi Version Time is now: December 1st, 2024 - 6:04 PM
