> 5sfte tuning, for the people who are doing the project now or soon :)
post Mar 4, 2008 - 2:07 AM
6strngs
Joined May 12, '06
From Wilmington, NC
ok, well, I've had a couple different members on here ask me for SAFC/AFC Neo settings for when they get their 5sfte project finished, but want to take the car for a test drive, or want to be able drive it to a dyno for tuning. So, I've decided to post some. here's my disclaimer first: These are NOT intended to be final settings for your 5sfte. in fact, these aren't my exact settings. I actually am posting slightly milder settings than what I use because every engine is different, and what settings make my engine run good could be dangerous for yours, which is why no one has ever posted settings before. but, most 5sfte's run very similar settings from what I've seen, so these would be a good place to start and will give you something to build off of.
For the record, these are meant for cars using a CT-26 turbo, 460cc injectors, an APEXI SAFCII or AFC Neo and a 2bar map sensor. if you're using a different turbo, different injectors, different piggyback, or a different sensor, then these settings will most likely not even be close for you and you could damage your engine!
Throttle point: Low - 20% High - 25%
Low Throttle Map:
RPM...Correction %
800....-39%
1400..-28%
2000..-28%
2400..-26%
3000..-30%
3400..-16%
4000..-12%
4400-6400..0%
(I haven't tuned above 4000 RPM yet, but I don't really ever go past 4000 RPM at low throttle...)
High Throttle Map:
RPM...Correction %
800...-11%
1400..-11%
2000..-11%
2400..-11%
3000..-11%
3400..-13%
4000..-13%
4400..-12%
5000..-5%
5400..-5%
6000..-5%
6400..-5%
again, I haven't really tuned past 5000 RPM, so this map makes you go pretty rich right around there, but that'll be safer since detonation tends to happen around those RPMs and lean mixtures burn hotter and thus lead to more detonation. One more thing to keep in mind with all these settings is that they are all NEGATIVE, meaning subtracting fuel. you shouldn't ever need to add fuel!
Once again, I have to state that these are only to help you get your running after your turbo project is done and you need to drive it from your house to the dyno shop to get tuned. Unless you have a wideband o2 gauge, I'd strongly recommend keeping your foot out of the throttle until it's properly tuned, as tempting as it'll be with the newfound power. if you do have a wideband, keep a close eye on it if you do step on it and let off if you see anything leaner than 11.5 during WOT.
This post has been edited by 6strngs: Mar 4, 2008 - 2:08 AM
post Mar 4, 2008 - 6:33 AM
DONT EVER USE SOMEONE ELSES SETTINGS ON A SAFC.
every motor requires its own "tune"
this thread is a VERY bad idea.
post Mar 4, 2008 - 11:11 AM
Celiracer18
Joined Aug 23, '05
From Princeton, Minnesota
rather than just posting your settings, you should post how you came up with and made those changes so that they can generate their own.
This post has been edited by Celiracer18: Mar 4, 2008 - 11:11 AM
-Brian
post Mar 4, 2008 - 5:31 PM
why are the high and low throttle at 20% and 25% ?
post Mar 4, 2008 - 5:34 PM
QUOTE(Batman722 @ Mar 4, 2008 - 5:31 PM) [snapback]649207[/snapback]
i would guess much the same reason mine was close to the same.
once your over ~20% throttle, your building boost, when you need the hi-throttle settings.. you know this D, we've discussed it while drunk several times..lol
post Mar 4, 2008 - 6:55 PM
mikecelica
Joined Jan 31, '07
From Ontario, Canada
Just a quick question, kinda stupid but Im almost done putting together my 7afte and was wondering can i do something so that it doesnt build boost till i get it from the shop to the tune shop. Or do i just have to get it towed? thanks for the help
post Mar 4, 2008 - 7:13 PM
QUOTE(mikecelica @ Mar 4, 2008 - 6:55 PM) [snapback]649265[/snapback]
just dont press the go pedal.
nice, and easy on the throttle, and you can easily stay out of boost.
post Mar 4, 2008 - 8:56 PM
mikecelica
Joined Jan 31, '07
Thing is this turbo should kick in very low rpms, but I guess I'll have to try and stay under 2000rpm. thanks
post Mar 4, 2008 - 9:12 PM
6strngs
Joined May 12, '06
From Wilmington, NC
these aren't my exact settings, these are milder than my settings beacuse I know that every engine requires it's own tune. These were meant to give something to build off of. We all know running too lean is very dangerous for the engine, but running too rich is also not good for it. it's better to be rich than lean, to an extent. when I first started up my car after getting my project together I was looking at my wideband and I thought it was malfunctioning because all it read was 10.0:1 which is the absolute richest that it reads. I probably was closer to 9.0:1, 8.0:0, maybe even richer! when you dump too much fuel into an engine, you risk what is called cylinder washdown where the gas washes all the oil off the cylinder walls and it could seize your engine.
how I came up with these settings? I actually copied somebody elses high throttle map and it was pretty darn close to being dead-on. I only made changes of 1 or 2 % at 2 or 3 different points. I made up the low throttle by myself but it took a while. If someone would've posted something like this for me when I was tuning, it would've been a lot easier and taken less time.
one more note for anyone planning on tuning their own engine, don't tune anything until the engine is fully warmed up. it'll run richer at start-up because that's what it was designed to do. and just because the water temp gauge is at halfway doesn't mean it's fully warmed up. if you have an oil temp or oil pressure gauge, you would be able to tell when it's fully warmed up by looking at those.
QUOTE(mikecelica @ Mar 4, 2008 - 5:56 PM) [snapback]649298[/snapback]
you can cruise at higher rpms without the turbo spooling as long as you stay out of the throttle and just lightly press the gas.
post Mar 4, 2008 - 9:20 PM
mikecelica
Joined Jan 31, '07
OK, and just another thing kinda related. Do I have to get a wideband AFR sensor or can my SAFC2 also able to read AFR?
post Mar 4, 2008 - 10:37 PM
pabel89
Joined Sep 28, '07
From new jersey
just leave your the intercooler pipe that goes to the turbo with out a coupler. it will be sucking air from the outside so just put a airfilter on it. smile.gif
post Mar 5, 2008 - 3:06 AM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(pabel89 @ Mar 4, 2008 - 7:37 PM) [snapback]649341[/snapback]
You really should have a restrictor on the outlet of the turbo if you want to do that... The compressor can overspeed if you do that without opening the wastegate and restricting the turbo.
It should be really easy to stay out of boost... just be light on the pedal! (heck, i drove my WRX for 1k miles only hitting boost a couple times!)
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Mar 29, 2010 - 3:02 PM
BoostedGT
Joined Mar 28, '10
From NY
Why is hi-throttle so low? would that dump more fuel?
im not too sure though on how the safc-II works so sorry if i sound stupid haha
i just recently bought the car with the same setup ,ct26 turbo 460cc injectors and im looking for a tune that wont dump as much fuel....shoud i use the one you posted up?
post Mar 29, 2010 - 7:59 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE (BoostedGT @ Mar 29, 2010 - 12:02 PM) *
wow, old thread. lol
but basically it's because when you're under boost there is a lot more air coming in and you need more fuel to compensate, hence the reason for upgrading to 460cc injectors in the first place.
I stated it several times in this thread, but I'll state it again, these are not final settings you can just put in and go, they are intended to give you something to build off of to make your own map using a wideband O2 sensor, or to get you to the dyno so the tuner can tune it. If the car you bought is running too rich (is getting too much fuel) then you want to lean it out in the areas where it is too rich. These changes should only be done if you have a wideband to monitor the changes or done by a tuner on a dyno. You should be at about 14.7:1 while cruising in the low throttle map, but when you build boost you want to be much richer around 11.5:1. Any leaner than that and you risk detonation which will destroy your motor. (unless you run race gas 100% of the time, lol)
post Mar 29, 2010 - 11:03 PM
BoostedGT
Joined Mar 28, '10
From NY
i just set it to that and its not bad...
Can you just explain that lo/hi throttle setting :-? hahha
Lo-Fi Version Time is now: November 29th, 2024 - 5:32 AM
