Man my left head light mount broke :/ |
Mar 4, 2008 - 11:28 AM |
Enthusiast Joined Jan 31, '08 From atlanta Currently Offline Reputation: 0 (0%) |
The mounts that hold my left headlight housing broke the other day and Ive temporarily put some krazy glueon there to hold it in place but I really need to replace it soon. Does anyone know how much the headlight with the entire housing assembly would go for?
Mar 4, 2008 - 12:09 PM |
Enthusiast Joined Jan 18, '08 From Houston Currently Offline Reputation: 7 (100%) |
QUOTE(emachine @ Mar 4, 2008 - 12:28 PM) [snapback]649031[/snapback] The mounts that hold my left headlight housing broke the other day and Ive temporarily put some krazy glueon there to hold it in place but I really need to replace it soon. Does anyone know how much the headlight with the entire housing assembly would go for? wait, just the tabs? if that's the case, fiberglass em back on. BC factory wants near $200 or more, and any good deals you find are going to be at least $100+ If all thats broken is repairable, then fix it first. And if not then send it to me so i can fix and resell it -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Mar 5, 2008 - 11:30 AM |
yeah its jus the tabs that are broken, so would any auto garage be able to fix em?
Mar 5, 2008 - 11:48 AM |
QUOTE(emachine @ Mar 5, 2008 - 12:30 PM) [snapback]649470[/snapback] yeah its jus the tabs that are broken, so would any auto garage be able to fix em? DUDE! stop now. Go to walmart, go to the automotive section and buy a "fiberglass kit" for $10. okay? Now, follow the directions and put that thing back together. Auto shop is going to say it's unfixable; charge you dealerhsip price for a new one, then labor, and installation, then tax... that kit comes with everything you need and then some. You will not be needing the fibercloth. Just the resin hardner, and the mixer-stick and cup. Clean the broken tab; and where it attaches really well. Poor about 2 ounces of resin into the cup, and probly about 15-20 drops of hardener. I'd just give it a quick squirt. Mix it up really well; and If you have spray adhisive, go ahead and spray the tab and the the housing; just give it a *quick spray where your going to be sealing. then apply a layre of fiberglass mixture between the tab and the housing, and hold it together for a few minitues. If your wife has a blowdryer that would be fantastic for someone to hold to dry these parts. After it begins to hold enough for you to take your hands off, Apply more. get a good coat all around the break in the tab because your going to want it to hold. Let it dry, and BAM, it's fixed. yeah, it looks kind of crazy, but for a 15 minitue job, You'd look kinda crazy for speding $200+ lol. Besides, it's not how it looks, it's how it works. Happy glassing~ -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Mar 5, 2008 - 12:00 PM |
Is fiberglass going to be sturdy enough for something like that?
What about using steel reinforced putty? I'm not sure how it'll bond to the ABS, but it might bond pretty okay, then you can shape it, let it set and it'll harden to super-duper hard. It's drillable too, so you can drill it out once it's hardened, and be able to securely fasten that bolt! -------------------- |
Mar 5, 2008 - 12:21 PM |
QUOTE(GriffGirl @ Mar 5, 2008 - 1:00 PM) [snapback]649479[/snapback] Is fiberglass going to be sturdy enough for something like that? What about using steel reinforced putty? I'm not sure how it'll bond to the ABS, but it might bond pretty okay, then you can shape it, let it set and it'll harden to super-duper hard. It's drillable too, so you can drill it out once it's hardened, and be able to securely fasten that bolt! you could, but the word "overkill" comes to mind. besides, this'll hold, it'll hold just fine. With a good squirt of hardner, it'll be as hard as as the ABS and will seal like no-body's business. Cheaper too!! i've also heard somone say you can JBweld it... Whatever~ I'd glass it personaly, hey, if you wanted to you could re-fabricate one out of stainless steal, lol. Just gotta know what your doin is all. I'm just comfortable with Fiberglass.... -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Mar 5, 2008 - 1:27 PM |
ebay also...
I'd use fiberglass... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Mar 5, 2008 - 1:47 PM |
Enthusiast Joined Dec 6, '06 From Massachusetts Currently Offline Reputation: 0 (0%) |
i would weld it with a plastic welder. I dont know if you can find a shop the has one but ive got one and it works great
Mar 5, 2008 - 2:23 PM |
QUOTE(D-Man @ Mar 5, 2008 - 9:21 AM) [snapback]649494[/snapback] QUOTE(GriffGirl @ Mar 5, 2008 - 1:00 PM) [snapback]649479[/snapback] Is fiberglass going to be sturdy enough for something like that? What about using steel reinforced putty? I'm not sure how it'll bond to the ABS, but it might bond pretty okay, then you can shape it, let it set and it'll harden to super-duper hard. It's drillable too, so you can drill it out once it's hardened, and be able to securely fasten that bolt! you could, but the word "overkill" comes to mind. besides, this'll hold, it'll hold just fine. With a good squirt of hardner, it'll be as hard as as the ABS and will seal like no-body's business. Cheaper too!! i've also heard somone say you can JBweld it... Whatever~ I'd glass it personaly, hey, if you wanted to you could re-fabricate one out of stainless steal, lol. Just gotta know what your doin is all. I'm just comfortable with Fiberglass.... Overkill? Really? It's just a little tube of stuff, like the size of a cigar... it's pliable and easy to shape... but this, coming from someone who recreated an entire air induction box out of that stuff and a rusted shell of what was left of one. Gotta put the BFA to practical real-life use. -------------------- |
Mar 5, 2008 - 2:36 PM |
Oh, well as i said, to each their own.
Griff, you just dont like fiberglass though. lol. (you couldnt stay sober could you ) This post has been edited by D-Man: Mar 5, 2008 - 2:38 PM -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Mar 6, 2008 - 8:48 AM |
alrighty Ill head over to wal mart this afternoon and see about getting the repair kit.. right now its holding together fairly well on super glue but my left head light is aimed a LOT lower than the right one. (my car has a lazy eye at night) how would i fix this?
Mar 6, 2008 - 9:38 AM |
After you get it fixed, there are a set of screws that control the vert. and horozont. angle of the beams pitch.
Just adjust those screws untill the beam sits comfortable for ya. Requires 1) Philips screwdriver. I know that's alot of tools, lol, but i think you'll manage. Also, you can use a socket; i forgot what size though... (like 10mm??) -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Mar 6, 2008 - 11:28 AM |
LOL alrighty Ill get to workin on that this afternoon.. Thanks for all your input guys!
Mar 6, 2008 - 11:33 AM |
QUOTE(D-Man @ Mar 5, 2008 - 11:48 AM) [snapback]649475[/snapback] QUOTE(emachine @ Mar 5, 2008 - 12:30 PM) [snapback]649470[/snapback] yeah its jus the tabs that are broken, so would any auto garage be able to fix em? DUDE! stop now. Go to walmart, go to the automotive section and buy a "fiberglass kit" for $10. okay? Now, follow the directions and put that thing back together. Auto shop is going to say it's unfixable; charge you dealerhsip price for a new one, then labor, and installation, then tax... that kit comes with everything you need and then some. You will not be needing the fibercloth. Just the resin hardner, and the mixer-stick and cup. Clean the broken tab; and where it attaches really well. Poor about 2 ounces of resin into the cup, and probly about 15-20 drops of hardener. I'd just give it a quick squirt. Mix it up really well; and If you have spray adhisive, go ahead and spray the tab and the the housing; just give it a *quick spray where your going to be sealing. then apply a layre of fiberglass mixture between the tab and the housing, and hold it together for a few minitues. If your wife has a blowdryer that would be fantastic for someone to hold to dry these parts. After it begins to hold enough for you to take your hands off, Apply more. get a good coat all around the break in the tab because your going to want it to hold. Let it dry, and BAM, it's fixed. yeah, it looks kind of crazy, but for a 15 minitue job, You'd look kinda crazy for speding $200+ lol. Besides, it's not how it looks, it's how it works. Happy glassing~ Ok so the break is kind of weird, the whole top mount of the headlight is broken in two pieces.. one 1 inch long piece at the top (with the hole for the screw), and then another piece that just kinda shattered from the plastic headlight housing itself. Should I put the fibercloth on the headlight housing so i will hold better? I can take pics when i get home and post em here |
Mar 6, 2008 - 11:55 AM |
def need pics.
I kinda understand what your talking about, but to know if it needs reinforcement or not; or if clothing it is even practical without adding dead weight, i wont know till i see it. Shoot some pics and PM me a reminder; incase i forget to check back. (i have the worst memory lol) but i really wanna help you set this right; and keep you from getting your wallet molested at the Auto Shop. -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Mar 6, 2008 - 11:56 AM |
Enthusiast Joined Mar 29, '07 From Philly Currently Offline Reputation: 11 (100%) |
GUY'S, Guy's, guy's...no...its called apoxy...cheap and does the job perfect...thats all you need....thats what i have on mine and it fixed the problem very nicely
-------------------- I"M NOT A TOYOTA FAN, IM A FANATIC 1984 accord hatch 5 speed (T-Belt)-Junkyard 1991 VDUB jetta wolfsburg Ed. 5 speed (clutch)-junkyard 1988 Dodge Aries K (sold) 1969 Chevy El camino - Traded for celica 1991 Dodge Daytona-Traded for Celica 1988 Chevy Camaro-Work in Progress 1989 Ford Mustang LX 5.0 - For Sale 1995 Toyota Celica-Work in Progress |
Mar 6, 2008 - 11:57 AM |
lol alrighty ill post them here and pm them to you around 3-4 pm eastern time. And thanks a lot for your help! (thank god i can just fix it with the fiberglass stuff.. I had to sell a whole bunch of stuff on ebay this past week because I didnt know how much headlights would cost)
Mar 6, 2008 - 12:04 PM |
mine is broken as well. my light is pointing about 2-3 inches higher than the other
-------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Mar 6, 2008 - 1:37 PM |
QUOTE(95st-celica @ Mar 6, 2008 - 12:56 PM) [snapback]649837[/snapback] GUY'S, Guy's, guy's...no...its called apoxy...cheap and does the job perfect...thats all you need....thats what i have on mine and it fixed the problem very nicely Yeah, an Apoxy would work well also, but it wont last as long. (but we're talking year(s), lol) Apoxy/Epoxy are basicly just SUPER-DOOPER-Glues, lol. Would work well; And i'm not knocking that idea 95st-celica, It is a valid point. And it's all up to EMachine for what he uses. Lol, as said before, It really depends on what your comfortable using. I love working with fiberglass, and the fact that you seal it, then reinforce the break as so it's stornger than the rest of the ABS lol, i love that idea. Apoxy/Epoxy, Putty, Superglue, Screwing in a Steel Bracket, Fiberglass, Duct Tape ( ) Are all capable of working. EMachine, it Matters what you would like to use. Everything has an advantage and a disadvantage. lol, We're such a helpful bunch, this guy is going to goto wal mart and spend $100 on different stuff... lol, and test em all out QUOTE(Tigawoods @ Mar 6, 2008 - 1:04 PM) [snapback]649841[/snapback] mine is broken as well. my light is pointing about 2-3 inches higher than the other Pics? Start from the top of the post and read your way down. Everyone has a different way of fixing it, lol. You can find 10 different ways to fix it here -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Mar 6, 2008 - 2:19 PM |
QUOTE(D-Man @ Mar 6, 2008 - 10:37 AM) [snapback]649890[/snapback] Start from the top of the post and read your way down. Everyone has a different way of fixing it, lol. You can find 10 different ways to fix it here fifty ways to leave your lover... fifty ways to leave your lover.... get on the bus, Gus... (and I don't hate fiberglass, DMan, I just fear it. for now.) -------------------- |
Lo-Fi Version | Time is now: November 23rd, 2024 - 1:19 PM |
