Enthusiast ![]() ![]() Joined Sep 13, '06 From St. paul, MN Currently Offline Reputation: 10 (100%) ![]() |
ok, let's see, guages light up but don't work, radio, clock, dome light don't work at all, everything else does. I pulled and tested EVERY fuse (with an actual fuse tester) and they are all good. I tested the accessory (gray) wire and it's not getting power. I don't know what else to look for.
please help!!! -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 18, '08 From Houston Currently Offline Reputation: 7 (100%) ![]() |
QUOTE(Muggs @ Mar 4, 2008 - 1:41 PM) [snapback]649059[/snapback] ok, let's see, guages light up but don't work, radio, clock, dome light don't work at all, everything else does. I pulled and tested EVERY fuse (with an actual fuse tester) and they are all good. I tested the accessory (gray) wire and it's not getting power. I don't know what else to look for. please help!!! !! Your gauge lights work But their functions do not? yet their is no power to your radio, clock, dome ect? I'm not the pro, but it would sound like you have 2 different problems here... No guage function could mean that your cluster has come unpluged (if fuse is good) or that you've lost the ground connection to the entire thing. No power to radio, clock, dome ect, i would bet to be a fuse, or a fuse terminal connection has come undone... Unless you've somehow cut that wire that suplies your fuse board. (VERY unlikely) Or you've blown ALL of your bulbs and fried your raido at the same time... possible, but not probable. i think that one is chaulked under "act's of God" cuz i dont think it's ever happened, unless your car was struck by lightning...lol. Check the fuses again. Remember there are multiple fuse panels in your car. -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
QUOTE(D-Man @ Mar 4, 2008 - 2:07 PM) [snapback]649089[/snapback] Check the fuses again. Remember there are multiple fuse panels in your car. agreed. Did you check both fuse boxes ? -------------------- |
I checked both the fuse block inside, (by the left knee) and the one under the hood. I guess I'll go check again to make sure.
Enthusiast ![]() Joined Dec 6, '06 From Massachusetts Currently Offline Reputation: 0 (0%) ![]() |
check ground. sounds like a connection problem
Lo-Fi Version | Time is now: February 17th, 2025 - 6:19 AM |
