![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 6, '06 From massachusetts Currently Offline Reputation: 30 (97%) ![]() |
So after running some sea foam through my car on Monday I noticed something. While having it sucked up into the engine some smoke started coming out from under neath my heat shield
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 29, '07 From Philly Currently Offline Reputation: 11 (100%) ![]() |
could just be an exhaust leak or a bad gasket...nothin to worry about...make sure you change your oil after you use the sea foam thoguh because it thins your oil out
-------------------- ![]() I"M NOT A TOYOTA FAN, IM A FANATIC 1984 accord hatch 5 speed (T-Belt)-Junkyard 1991 VDUB jetta wolfsburg Ed. 5 speed (clutch)-junkyard 1988 Dodge Aries K (sold) 1969 Chevy El camino - Traded for celica 1991 Dodge Daytona-Traded for Celica 1988 Chevy Camaro-Work in Progress 1989 Ford Mustang LX 5.0 - For Sale 1995 Toyota Celica-Work in Progress |
did it about 10 minutes after I finished the sea foam. Thanks for the info.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) ![]() |
You only have to change your oil if you add the sea foam into your oil right? I mean if you suck it up through your vac or add it into your fuel it doesn't effect the oil at all. This is one thing I need to do to my car. Since I here that high mileage cars shouldn't be seafoamed due to worst things will show up after sea foaming.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
I have 166K on my car and it is running awesome.
I have 208 and worried about it. I doubt I'll run into issues through my vac and fuel, but its the oil I'm worried about.
I just had mine sucked in through one of the vac lines. It is running fine. If anything changes I will post.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '07 From Portland, Oregon Currently Offline Reputation: 67 (96%) ![]() |
It's fine on high mileage cars; yes, change your oil; no, don't add it straight to the oil.
Yeah, I read that its fine for high mileage cars. I have had nothing but good things so far.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jan 25, '06 From MN Currently Offline Reputation: 19 (100%) ![]() |
QUOTE(massbrandon @ Mar 5, 2008 - 4:35 PM) [snapback]649572[/snapback] Yeah, I read that its fine for high mileage cars. I have had nothing but good things so far. The reason why most people don't recommend on higher mileage engines is because after putting seafoam into your oil it'll eat up all those sludge that was build up in your engine and will cause oil leaks thats been covered by the build up after seafoaming. If you have a higher mileage engine just suck it through a vac line you should be fine. ![]() And yes you need to replace your exhaust manifold gasket theirs a leak their keep an eye on your engine bay too when your seafoaming it'll tell you where you have bad gaskets or leaks that you need to replace or take a look at. ![]() -------------------- "To Protect And To Serve The Wealthy" -POLICE
Lo-Fi Version | Time is now: February 23rd, 2025 - 10:30 AM |
