> 5 Speed conversion/setup
post Mar 5, 2008 - 8:35 PM
supra12big
Joined Aug 19, '07
From Farmington, MI
Hi, what shifter cables do u use for the 5 speed conversion on a 94 st with a 3sgte mr2 trans, i have a alltrac bracket, but when i put it in i can only go into 1,2,3,4, the cables right now are gt cables, are they not long enough for when i put the alltrac bracket in.
post Mar 6, 2008 - 6:38 AM
how many times are you going to post these SAME QUESTIONS???
you need to use ST-205 bracket, mount and shifter cables
post Mar 6, 2008 - 6:57 AM
supra12big
Joined Aug 19, '07
From Farmington, MI
u know i am not talking about mounts, I am talking about the shifter bracket for the cables right by the speedo sensor, i have the alltrac one, but when i swapped it out for this custom mr2 welded one that was one there, i only had 1,2,3,4 so i am guessing the st205 shifter cables are longer then the gt cables
post Mar 6, 2008 - 10:19 AM
celicaGT96
Joined Aug 14, '05
From Corpus Christi Tx
are the rhd shifters different from the lhd or are they the same?
not the cables but the actual shifter assembly..
post Mar 6, 2008 - 10:28 AM
supra12big
Joined Aug 19, '07
From Farmington, MI
i wouldn't think so
post Mar 6, 2008 - 10:58 AM
lubu
Joined Apr 2, '07
From Great Western Plateau
QUOTE(celicaGT96 @ Mar 7, 2008 - 12:19 AM) [snapback]649814[/snapback]
I got the lhd shifter assembly, when i mount it I found that its kinda tilted to the left...had to fixed it since mine is rhd.
98% completion
aaRon
post Mar 6, 2008 - 1:40 PM
supra12big
Joined Aug 19, '07
From Farmington, MI
how much longer are gt4(st205) shifter cables then the usdm gt cables?
Lo-Fi Version Time is now: February 23rd, 2025 - 8:35 AM
