> axle problem
post Mar 6, 2008 - 10:59 AM
my96celica
Joined Jul 15, '07
From High ridge MO
my driver side axle will not go on all the way I have taken my car to a shop and they couldnt get it on any ideas on how to put in on I have not worked in like two weeks cause of this axle not going on all the way
post Mar 6, 2008 - 11:42 AM
Hanyo
Joined Aug 16, '03
From Bay area
is it the correct axle? Do you have your old one to compare the two?
post Mar 6, 2008 - 11:49 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
your not hitting it with a sledge hammer hard enough.
post Mar 6, 2008 - 1:16 PM
FreddyTheOthaMea...
Joined Feb 8, '04
From Thornton, CO.
http://www.celicatech.com/imagearchive/bgb...afts%202.2L.pdf ?
Fred
"...Armed with backbone and busted zoo gates, promising you from the bottom of my harmonica pocket - FOREVER - you will never have another lonely holiday..."
post Mar 6, 2008 - 1:18 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
I just kept twisting and pushing at the same time. Be patient, you'll get it.
94 Celica gt white (sold)
post Mar 6, 2008 - 7:38 PM
my96celica
Joined Jul 15, '07
From High ridge MO
QUOTE(bccentaur3 @ Mar 6, 2008 - 1:18 PM) [snapback]649879[/snapback]
Midas said they could'nt get it back in so what would that be?
post Mar 6, 2008 - 7:53 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Isn't there suppose to be a lock ring on the axle? Maybe they aren't doing it right. Thats why I never take my car to a shop. I do eveyrthing myself. They sould be able to twist and push it in. They will be able to hear a pop the most relieving sound ever btw. That means its in.
post Mar 6, 2008 - 7:57 PM
make sure the lock ring is facing down, side it it and align the splines, then use a big flathead screw driver and a hammer to gently tap it in from each of the 3 sides.
post Mar 6, 2008 - 7:59 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
the angel clip should be giving you more problems when you take the axle out...not when your trying to put it in.... doesn't Midas do exhausts....... haha make sure it's the right axle sometimes the axles get swapped from box to box.
This post has been edited by rjbibeau: Mar 6, 2008 - 8:01 PM
post Mar 6, 2008 - 8:00 PM
QUOTE(rjbibeau @ Mar 6, 2008 - 7:59 PM) [snapback]650054[/snapback]
that snap ring is called angel clip but doesn't Midas do exhausts....... haha make sure it's the right axle sometimes the axles get swapped from box to box.
Excellent point. I dont know how many times they gave me the wrong axle in the box.
post Mar 7, 2008 - 10:18 PM
my96celica
Joined Jul 15, '07
From High ridge MO
QUOTE(lagos @ Mar 6, 2008 - 8:00 PM) [snapback]650056[/snapback]
I took it up to an axle shop today and they got the axle in but there was like a half inch of play so the axle works it way out and it leaks.What could cause the axle to slide out when pressure is on it?Seals are fine.I've spent two weeks on this im done if anyone wants to buy let me know
post Mar 7, 2008 - 10:38 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Maybe they broke the lock ring. I honestly think you got the wrong axles. Shorter ones maybe, thats why its sliding out. Hold on you're selling the celica?
post Mar 7, 2008 - 11:36 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
the snap ring either came off or you definitely have the wrong axle.
post Mar 8, 2008 - 1:44 PM
my96celica
Joined Jul 15, '07
From High ridge MO
The axle was the one in the car I never changed them and the axle go's up and down like a hlaf inch.
The ring is also good they axle shop said that it might be the tranny.Yes im selling it, I'll let it go for like 2800 I still owe 250.00 on it but I cant pay to fix it Im a pizza man so I cant make money to pay it off.
This post has been edited by my96celica: Mar 8, 2008 - 5:56 PM
Lo-Fi Version Time is now: November 27th, 2024 - 8:20 AM
