> Installed, Slotted ATE rotors and hawk pads
post Mar 6, 2008 - 5:56 PM
SemperFiMarine
Joined Jun 19, '06
From Las Vegas, Nevada
So I installed them finally.
But I ****ed up somewhere.
Cause now I have excessive noise like its rubbing somewhere. (high pitched metal on metal screeching noise)
And a mushy pedal.
My Thoughts: Good game.
post Mar 6, 2008 - 5:59 PM
hongkongnerdboy
Joined Jul 26, '07
From riverside,CA
probably didnt align it right.
take all of it out and do it again
post Mar 6, 2008 - 10:03 PM
alltracman78
Joined Aug 9, '06
From Ma
If it's all the time you probably either have the heat shield rubbing the rotor or the clips for the caliper brackets rubbing the rotor.
Did you bleed your brakes after you were done?
Any fluid leakage from the pistons when you recompressed them?
Lo-Fi Version Time is now: November 26th, 2024 - 1:25 PM
