> cig lighter illuminition
post Mar 9, 2008 - 7:58 AM
stevest202
Joined Oct 28, '07
From epworth uk
been trying for a while to get it lit up fully only way i managed to do it was install a second led to top to get the full ring lit
post Mar 9, 2008 - 9:52 AM
was thinking myself of three LEDS...
post Mar 9, 2008 - 6:36 PM
94TRDcelica
Joined Feb 4, '08
From UK
Ive only got one Led in there, its very tight, where can you put a second? Can you post a piccy?
post Mar 9, 2008 - 8:29 PM
thats one single led soldered, the resistor is in the harness.
but im thinking using
they are much smaller, but i dont know yet.... I bet i can fit 3 of these
This post has been edited by njccmd2002: Mar 9, 2008 - 8:30 PM
post Mar 10, 2008 - 2:13 PM
DEATH
Joined Dec 19, '07
From tx
Hope you don't intend to use the lighter now. I tried this before and metal canister that lighter sits in gets super hot and melted all the plastic components of the LEDs I used.
Good luck with it and post a how-to if it works without fire hazard. I'd really like to do mine too.
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Mar 10, 2008 - 4:01 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
I think the cig lighter ring should go in the "Things I Don't Like About the Celica" thread! That ring really sux bawlz.
post Mar 10, 2008 - 4:05 PM
QUOTE(DEATH @ Mar 10, 2008 - 2:13 PM) [snapback]651486[/snapback]
post Mar 10, 2008 - 4:13 PM
DEATH
Joined Dec 19, '07
From tx
Glad I could be of help - It'd be a stupid mod to loose your baby over
EXT: WRC/TRD/404
post Mar 10, 2008 - 4:54 PM
stevest202
Joined Oct 28, '07
From epworth uk
as to not cause any fires if you want to carry on using cig lighter ive put my new led on the console trim and altered so one led at top and one in original holder you have to strip socket down to drill the grey bit with a 4mm hole
4mm hole in outer grey part dont drill inner clear bit
that allows light source through now you have to fix a holder for the led that doesnt touch the lighter it self as stated gets very hot and this hold it back for safe use
IPB Image i used led pre wired so easy connections heres a link to the ones i used
http://www.ultraleds.co.uk/u12vb-blue-1200...res-p-1227.html
well i dont smoke, i only charge my cell phone. But i guess its good to tell everybody this hazard..
post Mar 11, 2008 - 6:06 AM
DEATH
Joined Dec 19, '07
From tx
QUOTE(njccmd2002 @ Mar 10, 2008 - 4:54 PM) [snapback]651569[/snapback]
I should reiterate - It's not a stupid mod. Just a stupid mod to loose your car over. Sorry if that sounded rude before. wink.gif
EXT: WRC/TRD/404
post Mar 11, 2008 - 9:19 AM
markjbutler
Joined Sep 27, '07
From Devon, UK
all these interior LEDs are 3V correct? i'm thinking about changing mine to all blue (how original!!) but hooking up a circuit that would switch on a red LED when the lighter is in use... should look pretty cool imo
post Mar 11, 2008 - 1:29 PM
QUOTE(DEATH @ Mar 11, 2008 - 6:06 AM) [snapback]651879[/snapback]
no its not rude, really! i never tought about it frown.gif . 10 points for pointing it out.. The cig lighter thing will be out in the trash, but i will need a dud or someting plastic to cover the hole, for safety sakes. tongue.gif
BTW a 3 led circuit looks like this in parallel: courtesy of http://ledcalc.com/#calc
This post has been edited by njccmd2002: Mar 11, 2008 - 1:38 PM
Lo-Fi Version Time is now: February 22nd, 2025 - 12:40 AM
