> Rear hub
post Mar 9, 2008 - 3:08 PM
Zaish
Joined May 16, '04
From Mt Holly, North Carolina
Not sure if this is the correct forum but I've had some some banging coming from my rear passenger wheel when i press the brake down. Yesterday me and my friends were able to find out the hub inside is bent a little causing it to flex in and out and making my rotor not straight.
Anyways I am in need of one and didnt know if anyone knew a website you might be able to find it. It has a abs wheel at the end of the bearing. The bearing itself seems fine so is it possible to just get the hub itself? And if so how do you take it apart?
Only one I could find using google was one that was around 300$.
post Mar 10, 2008 - 10:22 PM
Zaish
Joined May 16, '04
post Mar 10, 2008 - 10:44 PM
try this
http://item.express.ebay.com/_Car-Truck-Pa...cmdZExpressItem
or this
https://www.trademotion.com/partlocator/ind...amp;catalogid=1
post Mar 11, 2008 - 6:53 AM
SteveHall
Joined Nov 8, '07
From Surrey, England
I had a small crash a while back resulting in a knackered hub. I ended up paying about £175 for a new one (about $350). I did establish they are not easy to find cheap, and don't bother getting a second hand one from a breakers, I had it on good authourity to pay the extra for a new one. I found this on my searches.
http://www.autopartswarehouse.com/shop_par...ota/celica.html
But they're a bit over $300, so probably not much use for this.
post Mar 11, 2008 - 12:31 PM
Zaish
Joined May 16, '04
Thanks for the help everyone. I was hoping that website was a bit much but its off to the junk yards for me. Thanks again.
post Mar 11, 2008 - 1:16 PM
QUOTE(Zaish @ Mar 11, 2008 - 12:31 PM) [snapback]651959[/snapback]
then its www.car-parts.com its a junkyard search.
post Apr 7, 2008 - 6:15 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
When you get your hub, did you have to remove the spindle from the existing broken hub or did you just take the hub to the shop and have it changed?
I just ordered a hub & bearing assembly from rockauto.com and I need to plan ahead. Could I just change out the old hub? Anybody?
Lo-Fi Version Time is now: November 23rd, 2024 - 4:53 PM
