2 Pages V  < 1 2
> 7afe,what is what??, starter??
post Mar 11, 2008 - 9:34 PM
alltracman78
Joined Aug 9, '06
From Ma
You can buy an oil pan gasket, but the FIPG [or regular black Permatex silicone] will seal better if done right.
post Mar 21, 2008 - 1:19 PM
CelicaST_CALI
Joined Feb 28, '07
anybody wanna just give me a how to on this??wat socket are the bolts
BANNED. for life, you moron.
post Mar 21, 2008 - 1:46 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
10mm
post Mar 21, 2008 - 2:48 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
generally all the bolts on our cars are gonna be 10mm or 13mm, with some exceptions of course. I always reach for the 10mm first, 9 out of 10 times that's what it'll be (unless it's obviously much larger)
post Mar 21, 2008 - 3:16 PM
cochise
Joined Nov 14, '06
From michigan
QUOTE(CelicaST_CALI @ Mar 21, 2008 - 6:19 PM) [snapback]656459[/snapback]
1. Buy yourself a good set of metric wrenches and sockets. Don't buy crap tools, buy craftsman or snap-on or any good name brand that gives you a lifetime warranty. These tools will last you a lifetime if you keep em clean and don't lose them. Get a tool box to keep em in. That is the best advise you will ever get about tools.
2. remove the oilpan after draining all the oil out. There is a drain plug at bottom of oil pan. (dont lose it)
3. clean the mating surfaces where the pan attaches to the motor. clean them very well so there is nice shiny clean surface wth no oil or grease.
4. Use the FIPG (or the black permatex). nice even bead around the pan. gently replace the pan on the motor.
5. replace the bolts that you took out to get the pan off. Replace the drain plug.
6. Remove the oil filter. Replace with a new one.
7. Pour in new oil.
8. Start the engine and check to see if there are any leaks. If not shut off engine and check the oil level.
If all is well......God Job!
post Mar 21, 2008 - 4:22 PM
scothaniel
Joined May 1, '03
From Michigan
To add to that excellent previous post (gotta give props to my fellow Michiganders) -
1. And a gasket scraper, and maybe a can of PB Blaster.
2. When pulling the oil pan, be careful not to bend the pan out of shape when removing it. Also, while the pan is off, don't let any dirt or debris get into the block. I pulled the pan on a car last fall w/ the garage door open, and just then mother nature decided to let out a big gust of wind - leaves every where.....
3. nice shiny clean surface wth no oil or grease - and as little old silicone as possible. Without a parts cleaner its difficult to get all of it out, but try to anyways.
4. When putting on a new bead of silicone, keep it thin and away from the inside of the pan. You dont need much to make a good seal. If you put too much on, you'll run the risk of it oozing into the block when you reinstall the pan.
7. After the silicone has cured, pour in new oil.
Scott
West Michigan
post Mar 21, 2008 - 6:56 PM
alltracman78
Joined Aug 9, '06
From Ma
1-use BLUE threadlocker on the oil pan bolts when you reinstall them. This will help keep them from vibrating out.
2-IMO I ALWAYS clean all the old paint off the oil pan sealing surface. Toyota says not to, but they assume the paint isn't scratched. If it's scratched oil residue can get under the scratch and is next to impossible to full clean out.
Oil residue means the silicone won't seal to the surface at that point, which means you will most likely have a leak.
3-Ultra fine sandpaper is great for cleaning off the old silicone from the block surface. Something over 1000 grit.
QUOTE(GriffGirl @ Mar 21, 2008 - 2:48 PM) [snapback]656482[/snapback]
10, 12 or 14mm. No 13 for OEM bolts.
Starter bolts are 14MM
Oil pan are 10mm [not sure which your'e asking about]
post Mar 21, 2008 - 7:15 PM
CelicaST_CALI
Joined Feb 28, '07
ok well that is great thanks guyz,but i mean how to replace starter.should i really re seal the oil pan,wat good will it do??
This post has been edited by CelicaST_CALI: Mar 21, 2008 - 7:19 PM
post Mar 21, 2008 - 7:45 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
It will keep your oil from leaking out. Typically, you want to keep all your oil in.
post Mar 21, 2008 - 8:00 PM
CelicaST_CALI
Joined Feb 28, '07
ok,starter how to?
post Mar 23, 2008 - 9:20 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
1. disconnect negative battery cable
2. disconnect the 2 wires going to starter
3. remove the 2 bolts holding starter on
4. remove old starter and place new one in its spot
5. replace those 2 bolts on the starter
6. reconnect the 2 wires
7. reconnect battery
8. attempt to start car
post Mar 31, 2008 - 11:19 PM
CelicaST_CALI
Joined Feb 28, '07
ok thanks a lot ill do this somtime in april
post Apr 7, 2008 - 5:55 PM
CelicaST_CALI
Joined Feb 28, '07
any body have any pictures of teh starter bolts??i really cant see any thing,id like to take the right bolts off,thanks
2 Pages V  < 1 2
Lo-Fi Version Time is now: November 27th, 2024 - 4:54 AM
