powersteering belt, how to tighten? |
Mar 11, 2008 - 3:32 PM |
Enthusiast Joined Nov 29, '07 From california, marysville Currently Offline Reputation: 0 (0%) |
my powersteering belt is squeaking when i make turns, i try to tighten it from the bottom of my car the other day but i cant find the spot to tighten it. anyoneknows where it is located exactly? pictures would be better
Mar 11, 2008 - 4:09 PM |
Check your power steering fluid, it's more likely that you're low on fluid - I believe your belt would squeak if it either needed to be replaced, or were too tight. Tightening it won't help.
Mar 11, 2008 - 4:12 PM |
Enthusiast Joined Aug 16, '04 From Baton Rouge, LA Currently Offline Reputation: 0 (0%) |
QUOTE(GriffGirl @ Mar 11, 2008 - 9:09 PM) [snapback]652095[/snapback] Check your power steering fluid, it's more likely that you're low on fluid - I believe your belt would squeak if it either needed to be replaced, or were too tight. Tightening it won't help. When your low on fluid it makes more of a whine than a belt noise. Tightening the belt can stop a squeal. Anyways. There should be a tensioner on your power steering pulley. Your gonna need to loosen the bolt on the pulley then tighten the tensioner. -------------------- |
Mar 11, 2008 - 4:16 PM |
QUOTE(GriffGirl @ Mar 11, 2008 - 4:09 PM) [snapback]652095[/snapback] Check your power steering fluid, it's more likely that you're low on fluid - I believe your belt would squeak if it either needed to be replaced, or were too tight. Tightening it won't help. i forgot to mention, the belt is very loose! |
Mar 11, 2008 - 4:34 PM |
Mar 11, 2008 - 8:03 PM |
Low fluid can cause a squealing noise, though usually it will groan and not squeal.
A loose or worn/glazed belt will squeal. There is no tensioner on a S series pwr steering pump, you have to loosen 2 bolts and pry the pump, then tighten the bolts. QUOTE(lagos @ Mar 11, 2008 - 4:34 PM) [snapback]652119[/snapback] Lagos, that doesn't help for tightening the belt.... That is for rebuilding and checking the rack. There was JUST a thread on here about how to tighten, do a quick search and it should come up. -------------------- |
Mar 12, 2008 - 2:03 PM |
Enthusiast Joined Jun 16, '06 From Bowling Green KY Currently Offline Reputation: 7 (100%) |
take a 2x4 of wood and stick it between the power steering reservoir and the valve cover, pry till its tight. thats what toyota told me to do over the phone...
-------------------- **If you play My Brute, joing the 6gc.net clan!**
--A section of a kid's actual test that had been scanned-- |
Mar 12, 2008 - 2:12 PM |
Good advice for an ST, but he has a GT, totally different.....
Mar 12, 2008 - 2:19 PM |
woops i didn't even realize that. duh
Mar 16, 2008 - 7:49 PM |
Enthusiast Joined Aug 2, '07 From las vegas Currently Offline Reputation: 0 (0%) |
i got so used to driving without p/s so would it matter if i took of the p/s pump, belt? i dont think i can go back to p/s on my celi
Mar 18, 2008 - 7:47 AM |
it wouldn't hurt it man. i drove without a belt on for the longest time. i got used to it too and i kinda liked it. you feel really ''connected'' with the road.
Mar 18, 2008 - 7:52 AM |
I absolutely HATE the power steering setup on the 3s/5s...seems so, primitive.
You'll have to get under the car and pry the pump up while tightening the hinge bolt. -------------------- |
Mar 18, 2008 - 6:55 PM |
Enthusiast Joined Feb 4, '08 From UK Currently Offline Reputation: 0 (0%) |
http://www.6gc.net/forums/index.php?showto...r+steering+belt
Follow the instructions I worte at teh bottom of the thread, that should help! -------------------- |
Lo-Fi Version | Time is now: November 23rd, 2024 - 5:46 PM |
