2 Pages V  < 1 2
> metal in oil and now other things
post Mar 14, 2008 - 8:22 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
another thing, only 4k into a fresh engine you will have more metal in the oil because the rings are still seating into the bores, it wont be truely worn in for about another 6000 miles. yes, it really takes an engine THAT long to wear in completely. after the initial 10 to 15 thousand miles wear levels off, until then its sill seating things and wearing things into place.
post Mar 16, 2008 - 2:20 PM
6G96GT
Joined Jan 20, '08
From East Coast
Usually if it's rod bearing particles, it would be a pasty swirl in the oil and not hard tiny particles. The rod bearing metal is a babbitt metal that quickly pastes up in an engine. Sometimes there's residue in the oil pan and sometimes there is not. I would watch the oil pressure guage like a hawk though and if it starts to run low and the engine fights to stay on at idle then turn it off and DONT try to start it again...tow it before you blow the engine cause that's definitely rod bearing or bearings even.
I used to run synth. oil (and I can easily afford it, thanks) but I don't anymore...it was explained to me that first, we aren't running nascars here and second, it just allows more crap to stay in the synth. oil longer because there's more mileage between oil changes. Just get the regular oil like Castrol GTX and change faithfully every 3K.
QUOTE(Bitter @ Mar 14, 2008 - 8:22 PM) [snapback]654024[/snapback]
I would have to say the most "crucial" term for engine break-in is the first 20 miles of driving at different speeds because that's when the rings make their first chicken scratches on the cyl-walls and make the guidelines for the rest thereafter.
post Mar 16, 2008 - 2:44 PM
Bitter
Joined Mar 11, '06
most crucial, yes for sure. but for upto 10K miles after you'll see more metal in the oil drains than later in the engines life.
post Mar 16, 2008 - 4:29 PM
celicast3sgte
Joined Jul 10, '05
From Monroe, WA
this is getting rediculous the rumors that are out about oils and change this change that... synthetic can hurt a brand new motor (dont believe me run a boxer engine on syn. for a while and see what happens). The reason i use the boxer motor as an example is because it will fail everytime and for the same reason. syn is too slippery for the piston rings. As for a new motor, it needs to have some metal on metal grinding to properly seat the piston rings. which is actually 95% broke in within the first 50miles (yes fifty miles). so those of u who say baby your motor for 10k miles. thats BS.
ok, aside from my rant.. you should check your oil before 1000miles, by then it could be too late. my question is you said its a rebuild, have you changed the oil on it yet since you started running the motor? if not the metal is normal. if you have, change the oil after a few hundred miles if pressure stays normal and no knocking occurs. then drain it and see whats in there.
but that is how i would go about it. the point of forums is to collect everyone's idea and formulate your own based on theirs. not to take anyone person's word as the truth. (no matter how much they assure you). myself and everyone here included.
post Mar 16, 2008 - 4:38 PM
Bitter
Joined Mar 11, '06
i've heard the opposite about synths and breaking engines in. what i've heard is that because the oil is more uniform it fills the cross hatches better and allows the rings more even contact. but its all really moot. engines ran fine and broke in fine before synthetic and engines have ran fine and broken in fine ON synthetic oils too. oil is pretty much oil UNLESS your engine is subjected to extremes. plenty of people who race competitively use their own blends of several oils in their cars because no one oil gives them what they want. others just dump in some mobil1 and call it a day. at the end of the day all the cars went around the track and drove home.
unless its -10 every time you start your car or unless you're turbo charged a premium conventional oil is fine. i choose to run a full syn in winter because the engine cranks easier in the extreme cold with it. in the summer i run a blend, either season i do 5k change intervals or 6 months whichever comes first. usually 6 months.
post Mar 16, 2008 - 7:50 PM
blckcelica95
Joined Nov 20, '03
From Derry, NH
i have changed the oil 3 time since the motor wasfirst was fired up. i have been watching the oil like a hawk turst me i dont feel like loosing all my money and time that i have put into this motor. i have been checking my oil daily and no metal (showing on the dip stick) since i changed the oil but then again it only been a few days. also the car hasnt had the issue with starting since i change the wires out .
This post has been edited by blckcelica95: Mar 17, 2008 - 6:58 PM
Driving a 5SFTE and LOVIN IT!!!!!!
http://www.myspace.com/17psicelica <-- celica engine build pics
post Mar 17, 2008 - 6:58 PM
blckcelica95
Joined Nov 20, '03
From Derry, NH
so here is my newest issue and since it may have to do with a potential rob bearing failure i will put it in this section instead of forced induction. so i took my car out on Saturday night and gave her a work out . now the car has developed a hesitation (it feels like it did when hitting knock at high boost) but only when boosting the car above 7 psi but not always. Sometime it pulls like it always has. My first thought was maybe i had taken out the head gasket . nope cyl1 205 psi cyl2 207 cyl 3 205 cyl4 210. second though messed up the turbo , no abnormal play. third thought maybe its a fuel issue so switch it back to an older map to see if that fixed it, but it didn't. so i need to some ideas . also checked plug gap set to .30.
post Mar 17, 2008 - 7:34 PM
Bitter
Joined Mar 11, '06
so you're getting a misfire under boost., correct? what was your AFR looking like when you got the misfires?
post Mar 17, 2008 - 7:37 PM
blckcelica95
Joined Nov 20, '03
From Derry, NH
13-12 range i have recorded the issue on my data logger for the emange
This post has been edited by blckcelica95: Mar 17, 2008 - 7:38 PM
post Mar 17, 2008 - 8:11 PM
97lestyousay
Joined Jul 7, '03
QUOTE(DEATH @ Mar 14, 2008 - 9:53 AM) [snapback]653857[/snapback]
QUOTE(blckcelica95 @ Mar 14, 2008 - 9:34 AM) [snapback]653770[/snapback]
so i was talking to a couple people about oils and i was told that synthetics oils can become abrasive, has anyone else heard that ?
Sounds like some more of the usual BS from haters who can't afford synthetic.
I've never heard that. I didn't have such great luck with synthetic, I switched back to castrol.
It may have been coicidence but I started going through oil fast, the 97 st motor seems notorious for that.
It may have had nothing to do with synthetic oil and may just be valve guides, but I figure why keep pouring
6 dollars in every 1500 miles pour 3 instead.
JDM guy made me do it.
post Mar 17, 2008 - 9:09 PM
Bitter
Joined Mar 11, '06
QUOTE(blckcelica95 @ Mar 17, 2008 - 7:37 PM) [snapback]654922[/snapback]
alright, well its not a lean or rich misfire probably. post up the logs, maybe someone can give some more insight into whats causing the misfire. if you make a separate thread link it here so i can take a look at your logs too.
post Mar 17, 2008 - 9:39 PM
blckcelica95
Joined Nov 20, '03
From Derry, NH
QUOTE(Bitter @ Mar 18, 2008 - 2:09 AM) [snapback]654952[/snapback]
i retract my previous statement it more around 11 -10 a/f IPB Imaged
post Mar 17, 2008 - 9:48 PM
Bitter
Joined Mar 11, '06
eh, 10 to 11:1 is rich, but not soo rich it should cause misfires. hell my 7afe hits those kinds of AFR's stock NA running full tilt in the upper rpms.
you werent logging timing as well?
This post has been edited by Bitter: Mar 17, 2008 - 9:49 PM
post Mar 17, 2008 - 10:08 PM
blckcelica95
Joined Nov 20, '03
From Derry, NH
i will take another log tomorrow. the timing on the log dosent seem to be working becuase it showing all negative values -80 to -100+ during that boost run
This post has been edited by blckcelica95: Mar 17, 2008 - 10:09 PM
post Mar 20, 2008 - 8:26 PM
6G96GT
Joined Jan 20, '08
From East Coast
Here's some ideas...leaky ecu?? Improper A/F (do some 3rd gear pulls at the dyno...see what's going on). Are you using a reputable wideband 02 sensor for the tuning or just stock for your readings? What about a boost leak test?? You should probably go to a pro shop and have them check your oil pressure at the cyl-head and see what it's running at when under mid-high throttle.
This post has been edited by 6G96GT: Mar 20, 2008 - 8:28 PM
post Mar 20, 2008 - 8:29 PM
blckcelica95
Joined Nov 20, '03
From Derry, NH
QUOTE(6G96GT @ Mar 21, 2008 - 1:26 AM) [snapback]656173[/snapback]
i found the problem , belevie it or not , it was my plug wires changed them out and car runs like a champ.
post Mar 20, 2008 - 8:47 PM
Bitter
Joined Mar 11, '06
that'll do it. under boost you need ALL of the spark power you're making to jump that gap.
2 Pages V  < 1 2
Lo-Fi Version Time is now: February 13th, 2025 - 1:46 PM
