> A/C problem, a/c button flashing
post Mar 12, 2008 - 3:21 AM
nics
Joined Feb 15, '08
From Royal Oak, MI
I had this a/c problem, when I turn on the a/c while just started the car, it works fine, blows cold air but then when i drive the car until it warms up, the a/c button flashes. Could i be low in refrigerant or is it my compressor?
God made man....
Everything else...
Made in China
post Mar 12, 2008 - 11:23 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
does it still blow cold air when it flashes?
post Mar 12, 2008 - 2:21 PM
alltracman78
Joined Aug 9, '06
From Ma
Flashing means the compressor isn't running, so it's not going to blow cold air.
It might blow cold for a minute or two because the evaporator is still cold, but if the AC light is flashing the AC isn't working.
The light flashes when the AC amp [ECU] sees a difference in speed between the compressor and engine RPM [if it sees this it will turn the compressor off].
Most likely a bad compressor [RPM sensor on compressor or compressor itself], though check the belt first.
This post has been edited by alltracman78: Mar 12, 2008 - 2:22 PM
post Mar 12, 2008 - 10:52 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
dumb question - can i check it by myself or have someone check it? if i could DIY, what shoul i do?tnx
God made man....
Everything else...
Made in China
post Mar 14, 2008 - 1:09 AM
aqua1996
Joined Jun 8, '07
From Darwin, NT Australia
mine was doing that I found that it was the wire on the compressor had come off put it back on and perfect.. problem solved
post Mar 14, 2008 - 10:07 PM
trdproven
Joined Aug 2, '05
From Guam
This seems to be common in Toyotas. Usually happens all the time when it is raining. This is no big deal don't worry about it. When the sun is out, it does not happen. Sometimes if it starts flashing you can press the AC button off and back on again it might stay on, if it doesn't, and no cold air is blowing, then yes your compressor, condensor, not too sure is not running well because of the weather.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Mar 19, 2008 - 4:39 AM
nics
Joined Feb 15, '08
From Royal Oak, MI
yep, sometimes when i turn it on at night, it would run like ~30 min. maybe i would have som1 check it and if its the compressor, i would buy off fr ebay.
God made man....
Everything else...
Made in China
Lo-Fi Version Time is now: November 23rd, 2024 - 12:14 PM
