Finished my project, but a few issues. |
Apr 6, 2008 - 2:41 AM |
Enthusiast Joined Nov 20, '03 From Derry, NH Currently Offline Reputation: 2 (100%) |
QUOTE(bccentaur3 @ Apr 6, 2008 - 3:58 AM) [snapback]661762[/snapback] Okay, a few more issues have arrived. So lately I've been noticing a puff of white smoke coming out of my exhaust when I stomp on it. But when I'm just cruising around there is no smoke visible from the rear view mirrow, but my girl friend tells me she can see smoke. I checked my coolant no signs of oil and checked my oil no signs of milky stuff. BUT I took the piping off of my turbo compressor and spotted oil all over the piping and a puddle sitting on my compressor. Its not black either, looks to me like fresh oil. Could some help me diagnose my problems. I will be doing a compression test, but lets just say my compression is good. is the issue my valves? But to me the obvious thing is my turbo, but wouldn't I be blowing blue smoke? HELP!!! SOS someone please help me. my turbo did the same thing...... then about a month later it was out, getting rebuilt. white smoke can be oil buring in the exhuast. check the turbo for play. that what i would check. -------------------- |
Apr 6, 2008 - 10:36 AM |
Enthusiast Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
Theres play side to side but a little. There is also a little in and out play.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Apr 6, 2008 - 10:45 AM |
Enthusiast Joined Feb 26, '07 From Boston, MA Currently Offline Reputation: 1 (100%) |
same thing here...everytime i step on it, i get white smoke coming out. Just bought a new turbo, hopefully will be here by the end of the week so i know if thats the problem or not.
Apr 6, 2008 - 10:52 AM |
well you know how you are suppose to cap the vacuum port on the throttle body that was connected to the valve cover? Well I capped that off, but I am routing the valve cover port to the intake from the turbo. But the nipple on the intake is tiny. Could that be restricting the the vent? Or should I just buy a tiny air filter and put that on the valve cover and see what happens?
Apr 6, 2008 - 6:32 PM |
So I put that filter on the crank case vent not the pcv. Well took it for a drive and smelled oil. So I poped the hood and guess what the filter is totally filled with oil. I checked my turbo again no in and out play and barely any shaft play side to side. So I'm assuming there is something wrong with my motor. Someone just clarify that my motor is blown so I can just order a new motor.
Apr 7, 2008 - 12:31 AM |
Enthusiast Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) |
QUOTE(bccentaur3 @ Apr 6, 2008 - 4:32 PM) [snapback]661978[/snapback] So I put that filter on the crank case vent not the pcv. Well took it for a drive and smelled oil. So I poped the hood and guess what the filter is totally filled with oil. I checked my turbo again no in and out play and barely any shaft play side to side. So I'm assuming there is something wrong with my motor. Someone just clarify that my motor is blown so I can just order a new motor. time for a catch can? excessive blow-by gasses could be caused by worn piston rings I'd do a compression check to see if any are low. -------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Apr 7, 2008 - 8:30 AM |
I'm on that today. I'll post results and you guys can let me know. Now, I'm off to class.
Apr 7, 2008 - 8:59 PM |
Okay
Cylinder 1= 190 psi 2= 100 psi 3= 140 psi 4= 180 psi So without a leak down test what does this tell you? Btw I am done driving her until I can rebuild the block. -------------------- 98 Celica gt red- totaled deer
Apr 8, 2008 - 5:57 AM |
Enthusiast Joined Sep 28, '07 From new jersey Currently Offline Reputation: 1 (100%) |
where do you get these commpresion checks done?
Apr 8, 2008 - 8:54 AM |
it tells me that cylinder 2 is gone and cylinder 3 is pretty much toast too. you should also do a wet compression test. basically you put a little bit of oil (my automotive book for school says about a 1/2 ounce) through the spark plug hole onto the top of the piston and do the compression check again. if the number goes up it means the problem is the cylinder rings, and if the number stays the same it means the head gasket or a valve is burnt.
btw, if you've never done a compression check before and have never been taught to do it correctly, you've got to crank the cylinders the same number of times... meaning when you're cranking for cylinder 1 you hear the engine go DAH-da-da-da-DAH-da-da-da... etc. the higher pitched one is the cylinder you are checking and when doing the test. You've gotta make sure you crank each cylinder either 4 or 5 times (as long as you do the same number for every cylinder) because if you crank one cylinder 5 times and the next only 3, obviously the numbers will be low. If you already knew all that then I apologize, I just want to make sure you're getting accurate numbers before you spend all the time and money rebuilding the engine. QUOTE(pabel89 @ Apr 8, 2008 - 3:57 AM) [snapback]662477[/snapback] where do you get these commpresion checks done? any automotive service shop will do it, or, you can buy a compression tester at any auto parts store for $20-30. If you can change your own spark plugs, you can check your compression, you just need a friend to help you. -------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Apr 8, 2008 - 9:17 AM |
what i see here is compression from the cylinders leaking past the rings and pressurizing the crankcase. a pressurized crank case makes it hard for a gravity oil return line to work properly. the oil backs up and then you see smoke come out your turbo because its pushing oil out the seals because you cant get the oil back in the pan quick enough. you could also be burning more then normal amounts of oil if your compression numbers are that low.
Apr 8, 2008 - 10:37 AM |
QUOTE(6strngs @ Apr 8, 2008 - 8:54 AM) [snapback]662491[/snapback] it tells me that cylinder 2 is gone and cylinder 3 is pretty much toast too. you should also do a wet compression test. basically you put a little bit of oil (my automotive book for school says about a 1/2 ounce) through the spark plug hole onto the top of the piston and do the compression check again. if the number goes up it means the problem is the cylinder rings, and if the number stays the same it means the head gasket or a valve is burnt. btw, if you've never done a compression check before and have never been taught to do it correctly, you've got to crank the cylinders the same number of times... meaning when you're cranking for cylinder 1 you hear the engine go DAH-da-da-da-DAH-da-da-da... etc. the higher pitched one is the cylinder you are checking and when doing the test. You've gotta make sure you crank each cylinder either 4 or 5 times (as long as you do the same number for every cylinder) because if you crank one cylinder 5 times and the next only 3, obviously the numbers will be low. If you already knew all that then I apologize, I just want to make sure you're getting accurate numbers before you spend all the time and money rebuilding the engine. QUOTE(pabel89 @ Apr 8, 2008 - 3:57 AM) [snapback]662477[/snapback] where do you get these commpresion checks done? any automotive service shop will do it, or, you can buy a compression tester at any auto parts store for $20-30. If you can change your own spark plugs, you can check your compression, you just need a friend to help you. Thanks, but I already know how to do the compression test. I just ran out of day light to do the wet test. Will do it tomorrow, but I already have plans for my motor. I think I'm just going to take my motor out and take it to a shop and have them inspect it. My plans for right now is to use some forged pistons on my factory rods and get some head work done. So basically the only things that are being upgraded is the froged pistons and regrind cams. I think I can get my head ported and poilished for a good deal. I'm expecting a call from the shop today. -------------------- 98 Celica gt red- totaled deer
Apr 8, 2008 - 11:12 AM |
QUOTE(bccentaur3 @ Apr 8, 2008 - 11:37 AM) [snapback]662511[/snapback] QUOTE(6strngs @ Apr 8, 2008 - 8:54 AM) [snapback]662491[/snapback] it tells me that cylinder 2 is gone and cylinder 3 is pretty much toast too. you should also do a wet compression test. basically you put a little bit of oil (my automotive book for school says about a 1/2 ounce) through the spark plug hole onto the top of the piston and do the compression check again. if the number goes up it means the problem is the cylinder rings, and if the number stays the same it means the head gasket or a valve is burnt. btw, if you've never done a compression check before and have never been taught to do it correctly, you've got to crank the cylinders the same number of times... meaning when you're cranking for cylinder 1 you hear the engine go DAH-da-da-da-DAH-da-da-da... etc. the higher pitched one is the cylinder you are checking and when doing the test. You've gotta make sure you crank each cylinder either 4 or 5 times (as long as you do the same number for every cylinder) because if you crank one cylinder 5 times and the next only 3, obviously the numbers will be low. If you already knew all that then I apologize, I just want to make sure you're getting accurate numbers before you spend all the time and money rebuilding the engine. QUOTE(pabel89 @ Apr 8, 2008 - 3:57 AM) [snapback]662477[/snapback] where do you get these commpresion checks done? any automotive service shop will do it, or, you can buy a compression tester at any auto parts store for $20-30. If you can change your own spark plugs, you can check your compression, you just need a friend to help you. Thanks, but I already know how to do the compression test. I just ran out of day light to do the wet test. Will do it tomorrow, but I already have plans for my motor. I think I'm just going to take my motor out and take it to a shop and have them inspect it. My plans for right now is to use some forged pistons on my factory rods and get some head work done. So basically the only things that are being upgraded is the froged pistons and regrind cams. I think I can get my head ported and poilished for a good deal. I'm expecting a call from the shop today. i would source a set of 3s rods, and have the 5s crank machined to accept them. the weak point on the 5s rods is the bolts, which ARP does not have an application for. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Apr 8, 2008 - 12:02 PM |
I was actually reseacrhing on the 3s rods. Well on ebay they are selling Eagle 3s rods for about $330 with the arp rod bolts too. Should I go that route? Or should I be cautious with that? Let me know, because I don't want to pull the trigger too early and screw myself.
Apr 8, 2008 - 2:18 PM |
i get alot of blow by gases, but randomly not all the time, like 3 times a day i can hear it its like if it were back fireing but way lower. would that affect my tune, what can i do to fix this problem?
This post has been edited by pabel89: Apr 8, 2008 - 2:19 PM |
Apr 8, 2008 - 3:46 PM |
QUOTE(bccentaur3 @ Apr 8, 2008 - 1:02 PM) [snapback]662539[/snapback] I was actually reseacrhing on the 3s rods. Well on ebay they are selling Eagle 3s rods for about $330 with the arp rod bolts too. Should I go that route? Or should I be cautious with that? Let me know, because I don't want to pull the trigger too early and screw myself. well, if you have the budget for them sure, the eagles are an even better choice (theyre lighter). if not, you can usually score a set of 3s rods pretty cheap over on mr2oc or alltrac.net (under 100$) -------------------- Former Team 5SFTE pro member ;)
Apr 8, 2008 - 3:56 PM |
Wow, I never thought of that. Thanks for the advice manny. And yes, I do have a budget and my moms on the brink of killing me if I don't stop spending money on my car.
Apr 8, 2008 - 7:03 PM |
Thanks to Manny, I managed to score myself some 3s rods for 60 shipped. WOOT!!!!! Now I gotta source out some pistons. Trying to decide right now if I should get them before I send my block out. Not sure if I have any scratched on the cylinder walls.
Lo-Fi Version | Time is now: February 13th, 2025 - 8:02 AM |
