> How do you secure a giant 12" sub in the back of a convertable tr
post Mar 13, 2008 - 10:41 PM
maddawg0
Joined Mar 6, '08
From Your moms house
everytime you hit any kind of bump the sub goes flying in the back, just enough to go "thump"... how do u secure it to carpet?
post Mar 13, 2008 - 10:42 PM
hongkongnerdboy
Joined Jul 26, '07
From riverside,CA
post Mar 13, 2008 - 10:48 PM
CelicaST_CALI
Joined Feb 28, '07
u cant secure it to the carpet,ull have to secure it to the frame....u should find some brackets that are good,drill some pilot holes then mount
BANNED. for life, you moron.
post Mar 13, 2008 - 10:51 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
It's very difficult to secure it in the back of a convertible. Friction will keep it stuck to the carpet, but nothing is keeping the carpet from sliding away too. You only have 1 12" sub? You can this. Cut a piece of wood that is the same shape as the carpeting. Put the wood you just cut under the carpeting, and then use screws to screw the box down to the wood. It should be good then.
post Mar 14, 2008 - 8:23 AM
D-Man
Joined Jan 18, '08
From Houston
you get a box like this:
that's only temp though, eventualy you need to get rid of the box to. lol.
Bolt it to the frame. Figure out where you want it, and secure it to the frame using L brackets or something.
Damn D-Man - most impressive.
post Mar 14, 2008 - 10:36 AM
Legit94GT
Joined Feb 6, '08
From Oregon
1 JL 1,000/1v2
2 JL 12" W6v2
2 Focal 6.5 component 165a1
Kenwood DDX512 head unit
Running 142.6db with the back seat up:)
post Mar 15, 2008 - 9:36 PM
tonytutino
Joined Jun 16, '06
From Bowling Green KY
they have subs made to fit in your spare tire space. they are tight. i have the problem of my box sliding around but i have a hatch:P i need to bolt mine down too. let us know how it goes man
post Mar 15, 2008 - 10:09 PM
punkuup5150
Joined Apr 10, '07
From lodi, ca
i made my subs so they fit into the little space in the back of a coupe. they slide up in there perfect and with carpeting it made it really snug. to even get it in there i have to pull the carpet on the floor twards the back of the trunk then slide the box and carpet back into place its that tight of a fit. and my amp mouonts right behind the box between the box and my seat with plenty of air movement to keep it cool.
Lo-Fi Version Time is now: February 23rd, 2025 - 3:40 AM
