> Water leak, Whats this?
post Aug 29, 2003 - 5:39 AM
khye
Joined Apr 17, '03
From Cork, Republic of Ireland
Anyone have any idea what this pipe is?
My fathers Celica (same as mine SS-II 3SGE) had a water leak from here.
I have put a little red arrow in there to point out the area where the leak occured.
Any help would be appreciated!
Thanks!
post Aug 29, 2003 - 8:54 AM
3TST
Joined Sep 27, '02
From UK
Well by the looks of it, the part bolted to the engine houses the thermostat for the air conditioning or heater system.
So one would assume that the pipe goes to one or the other of the above.
post Sep 2, 2003 - 1:57 PM
kyle314
Joined Nov 4, '02
From montrose colorado
it's an A/C line u will not get any water leaking from that if that is leaking it would be freon. if it is coolant look a little higher for a coolant leak. the water pump is just above the A/C compresser could be an o-ring or a bad water pump.
post Sep 4, 2003 - 2:21 AM
97GTinKC
From KC
Its more than likely just condensation. that is the A/C compressor. not uncommon to see ice build up there.
post Sep 4, 2003 - 10:22 PM
QUOTE (97GTinKC @ Sep 4, 2003 - 3:21 AM)
agreed, its condensation because if it was leaking and u were around it, u'd probably be dead.
Lo-Fi Version Time is now: February 25th, 2025 - 1:15 PM
