> wiggling car, uh oh :S
post Mar 23, 2008 - 8:01 PM
tigersvain
Joined Feb 21, '08
From Saint John, NB
well i put my rims on this weekend and now i have a really bad wiggle at bumps and even just randomly down the highway...the car did this before with the steel wheels on but not so badly, i figured it was just my tires that were garbage :S but now its worse, sway bar links? what other options could this be..theres no noise it just wiggles the car almost like hittin a patch of ice sorta feel
94 Celica GT Hatchback 5spd
89 Nissan 240sx coupe 5spd -RIP
87 BMW 325 2dr 5spd - SOLD- Gone but never forgotten
post Mar 23, 2008 - 9:47 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
check your ball joints..this will cause the car to be taken from ya sometimes and also your tie rods check for play in em. and then go get an alignment
This post has been edited by rjbibeau: Mar 23, 2008 - 9:49 PM
post Mar 23, 2008 - 10:06 PM
tigersvain
Joined Feb 21, '08
From Saint John, NB
the whole front end is very tight and stiff , also the car drives very straight, almost seems the wiggle comes from the rear end of the car :S
post Mar 24, 2008 - 2:25 AM
trdproven
Joined Aug 2, '05
From Guam
is it the sway bushings or the endlinks, tie rods, wheel hub is loose, etc.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Mar 24, 2008 - 3:07 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
bad bearing......or you need balancing??? or something is bent???
post Mar 24, 2008 - 3:02 PM
alltracman78
Joined Aug 9, '06
From Ma
Your thrust angle is probably off.
Get a 4 wheel alignment.
post Mar 24, 2008 - 3:07 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
^x2, and get the wheels balanced while you're at it.
post Mar 24, 2008 - 3:27 PM
Rayme
Joined Feb 18, '06
From NB, Canada
Jack up your rear, hold the tires at 9 and 3 o'clock, and wiggle them (like you were trying to manually steer them), if you have 1-2mm looseness there you might need some new control arms.
Exactly what you are describing happend to me on my 5th gen.
-Rémy
02 SiR, 08 250R
post Mar 24, 2008 - 3:37 PM
D-Man
Joined Jan 18, '08
From Houston
Even though it sounds stupid; Check your tires...
Damn D-Man - most impressive.
Lo-Fi Version Time is now: February 19th, 2025 - 8:12 PM
