![]() Enthusiast ![]() Joined Aug 19, '03 Currently Offline Reputation: 0 (0%) ![]() |
I was wondering if I could add a quad-tip exhaust system using one muffler and everything else is stock...?
The Quad set up I was thinking about looks something like this... Firebird base quad set up So do you think that this would be a good set up... Thanks... Mica |
![]() Administrator ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '02 From Seattle, WA Currently Offline Reputation: 14 (100%) ![]() |
No-one makes a quad-tip exhaust system for our cars, but I'm guessing that you'd be able to have one made at an exhaust shop if that's the look you're going for.
Also, you're saying that you want to leave your piping stock? If I were you, I'd replace the piping with 2.25" piping and put on a high flowing muffler. You'll actually get some performance out of your exhaust setup if you go that route. ![]() -------------------- New Toyota project coming soon...
![]() Enthusiast ![]() ![]() ![]() Joined Sep 27, '02 From UK Currently Offline Reputation: 1 (100%) ![]() |
I don't see why not.
You probably need some custom piping making up for it to fit correctly. BTW: I think that a company called AWR make custom cat back exhaust systems with twin or quad tailpipes. I'll try and find out more. |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 15, '02 From Corona & Vallejo, CA Currently Offline Reputation: 0 (0%) ![]() |
If you want a real answer... go down to the muffler shop and ask them if it's possible for them to do... some shops may be able to do some type of custom work, and others can't... Personally, I don't think you should do that... and also, I don't know how they would "hang" the muffler... |
Some ideas on exhaust systems albeit in french:
http://www.awrfrance.fr/default_zone/fr/ht...ml/page-14.html |
Lo-Fi Version | Time is now: February 17th, 2025 - 7:13 PM |
