> What to torque it to?, 6 hexhead inner cv bolts
post Mar 24, 2008 - 9:24 AM
6gsillyca
Joined Jan 13, '06
From UnderTheGround403
EDIT:
Can someone please tell me what the 6 hexhead bolts should be torqued to? My manual lists:
hub nut - 137 ft-lbs
driveaxle inner cv joint-to-differential side gear shaft flange - 27 ft-lbs
right driveaxle centre bearing bracket bolts - 47
None of these seem correct, but since my axles are *non-stock* I'm not sure what the technical part term would be for them.
END EDIT
I need to replace my outer cv boot. I was looking into getting a new axle shaft, because I have read it is easier to RnR the whole axle rather than individual parts (axle, cv joint, cv boot etc). Then you also shouldn't need to worry about any damage to your joint because of the craked boot.
I need to know what parts to order though. Cv boot is on the front pass wheel. Would the axle half come with both inners and outers, and then would I need to RnR the inner with the e153 inner from my current set-up?
Would someone be able to explain what the inner and outer axles are, and how/where the inner attaches to the outer?
Here is a link to my thread in another sextion, but I thought the boosted guys might know the e153/st185 axles a bit better.
http://www.6gc.net/forums/index.php?showtopic=57022
This post has been edited by 6gsillyca: Apr 15, 2008 - 12:42 AM
post Mar 24, 2008 - 2:19 PM
phattyduck
Joined Dec 5, '05
From LA, CA
Rebuilt ST185 front axles come as just the outers (same with Camry V6 and all other E-series axles). You will unbolt the inner and outer section. The "outers" includes both CV joints but not the stub that goes into the transmission. If you have a spacer setup or anything special with your inners, they stay on the car so you don't have to worry about that.
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Mar 24, 2008 - 7:23 PM
6gsillyca
Joined Jan 13, '06
So a st185 axle will come with both inners and outers assembled together from napa?
Do I just need to unbolt where the 6 cap head bolts are? Or is there another part after the inner cv joint that comes apart(before the 6 bolt piece)? I'm not 100% sure where the inner/outers connect, what stays and what gets replaced...
All I would need is a passengers side st185 rebuilt axle, and I should get everything I need? Or would I need the drivers side st185 axle?
Would I need any e153 components?
This post has been edited by 6gsillyca: Mar 24, 2008 - 7:23 PM
post Mar 24, 2008 - 8:26 PM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
Yes, all you need to do is unbolt the six 8mm recessed hex bolts from the transmission side, and undo the 30mm axle nut and you'll have the axle ready to remove.
From there, undo the two 17mm nuts and one 17mm bolt that fasten the ball joint to the A-arms and you can swing the whole hub away just enough to work the axle out from the hub splines and seperate the outer axle assembly from the inner axle stub. You don't have to take out the stub, that stays in the transmission.
But definately get just an entirely new outer axle and bolt it in. Its a quick job and most auto stores charge about $75 for a new one with a core trade in.
post Mar 24, 2008 - 9:36 PM
6gsillyca
Joined Jan 13, '06
QUOTE(Silver94CelicaOwner @ Mar 24, 2008 - 7:26 PM) [snapback]657493[/snapback]
Thank you, that is exactly the sort of how to write up I was looking for.
EDIT:
Would it matter what year st185 I order for? The tranny and inner axles are 93 e153 w/ oem lsd. Would I need to get a 93 to match, or does it matter?
This post has been edited by 6gsillyca: Mar 24, 2008 - 9:40 PM
post Mar 25, 2008 - 10:36 AM
Silver94CelicaOw...
Joined Oct 13, '02
Nope, it doesn't matter.
Any Celica All-Trac outer between 1990-1993 will work just fine, as well as 1988-1991 Camry V6. They share identical outer axles and the same part numbers at stores like Autozone, Advance Auto, and NAPA. If you have ABS that you want to keep, you'll want to get an outer axle for either car with ABS teeth on it.
The only part that is crucial to match up when you're using LSD is getting a corresponding inner axle from whatever year LSD transmission you're using. Outers are interchangable between LSD and non-LSD, no problems.
post Mar 25, 2008 - 11:24 AM
6gsillyca
Joined Jan 13, '06
Ok thanks. I knew there were differences between the inners (lsd, non lsd, abs, non abs, 90-92, 93+) so I wasn'y sure if I needed to match the outers some how.
Thanks 6gc!
Corey.
post Mar 25, 2008 - 1:40 PM
phattyduck
Joined Dec 5, '05
From LA, CA
Just so you are clear, the 'inner' axles are the part that actually goes into the transmission. It is just a solid stub. The 'outer' axles is the rest of it, where it goes into the hub, the outer CV, the axle and the inner CV. The inners and outers bolt together with those 6 hex-head bolts. Watch out when you unbolt them so you don't drop grease all over the place.
The left and right outer axles are the same for the ST185 and early Camry V6. The only thing you have to worry about is ABS or non-ABS (and ABS axles work in a non-ABS car, just not the other way around).
-Charlie
post Mar 26, 2008 - 12:22 AM
6gsillyca
Joined Jan 13, '06
Can someone confirm for me if st185 had the option of abs, or were they all abs equipped? Because the st185 was "top of the line" it should have almost all of the options included already.
Out of the 4 places I called looking for an axle only 1 place asked if I had abs. When I asked the other 3 if they needed to know, they replied that there was no option to choose abs or non abs, which leads me to believe that abs was standard on st185's and all of them *should* be abs axles...Is that correct, or was there an option for abs or not?
post Mar 26, 2008 - 11:04 AM
6gsillyca
Joined Jan 13, '06
Will I need to repack the inner/outer/spacer section with axle grease, or just put the pieces together, in the order they are in now, and rebolt them together?
post Mar 26, 2008 - 2:58 PM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(6gsillyca @ Mar 26, 2008 - 9:04 AM) [snapback]658170[/snapback]
You will need to repack the inner CV with grease. It should be included with the axle that you receive.
-Charlie
post Mar 26, 2008 - 2:59 PM
scothaniel
Joined May 1, '03
From Michigan
Yes, there are ABS and non-ABS alltrac axles.
Scott
West Michigan
post Mar 27, 2008 - 10:09 PM
alltracman78
Joined Aug 9, '06
From Ma
QUOTE(scothaniel @ Mar 26, 2008 - 2:59 PM) [snapback]658244[/snapback]
100% correct.
Same goes for the Camry axles.
However, I don't know if you can even find non ABS axles [doesn't matter directly to you, just for general FYI].
ABS axles will work fine on a non ABS car, so it's cheaper to just make one type.
If you get a whole axle it should already have the inner joint greased, but I guess some companies might not do that, all depends who you go through.
You will need a gasket for the joint however [unless the hybrid joints don't use one, but I would guess they do, or else you'll be leaking grease], it's a cork gasket that is sticky on one side, order it for an Alltrac axle.
Also just for general info, ithe pre and post revision Alltracs [90/91 vs 92/93] have DIFFERENT axles, and the drivers and passengers is different also.
The axles are interchangeable, the only difference is the groove for the outer boot on the outer joint.
A post revision boot wont' fit on a pre revision joint, but a pre revision boot will fit on a post revision joint IIRC.
The passenger side axle has a rubber vibration dampener on it, the drivers side doesn't have this.
Aftermarket axles might not have this distinction.
Either axle will bolt to either side, it just effects the Alltrac as far as smoothness, it shouldn't effect FWD. FWD has a longer pass side, while the Alltrac doesn't.
post Apr 6, 2008 - 4:21 PM
6gsillyca
Joined Jan 13, '06
So I was able to get out and have a look to see what the damage was, and it looks like my outer boot has got a few cracks in it. I also found cracks in my inner boot, so I guess I'll try and return my outer replacement boot and get the whole axle instead.
Do I need to disconnect the sway bar from the lower control arm? Are the "boots" for the bolts that connect the sway bar to the lower control arm sealed? I tried to loosen them, but when I did I heard a "pop" and a little bit of grease leaked out. The bolt just free spins and I do't know how to remove it or if I even need to take it off. Should I worry about the boot having a hole now?
Can someone else confirm the hex head bolt size for me? Silver94 mentioned they are 8mm hex keys, but I would just like a double check before I go buy a 8mm and find its the wrong size...
Your hex keys may or may not be 8 mm. Mine are 10mm.
This post has been edited by 6gsillyca: Apr 7, 2008 - 10:33 PM
post Apr 7, 2008 - 10:34 PM
6gsillyca
Joined Jan 13, '06
Do I need to tuorqe these when I tighten them? How do I tourqe hex keys? Is there any way I can attach these to an impact gun (to loosen)?
post Apr 8, 2008 - 11:43 AM
6gsillyca
Joined Jan 13, '06
Is my axle supposed to have the 3 "ridges" or is that part of my spacer and I need to seperate them? If the spacer is still on attached to the inner stub, then which ring would it be? While everything is apart, does anyone want more/detailed pics of my spacer set-up? Jay had a thread a while back but only had pics of the assembled pirce.
To re-install my new axle, does the hub or inner cv part go in first? I took the 3 17mm bolts off my a arm/ball joint, but wasn't able to get the tierod (I think thats what it is) or my sway bars off the a arm, so I can't really move the hub. I got my old one out by doing a lot of wiggling...
This post has been edited by 6gsillyca: Apr 8, 2008 - 11:52 AM
post Apr 15, 2008 - 12:42 AM
6gsillyca
Joined Jan 13, '06
bump for torque spec
post Apr 17, 2008 - 11:54 AM
alltracman78
Joined Aug 9, '06
From Ma
48 lb/ft
Make SURE you use BLUE thread lock too. These bolts LOVE to loosen.
It's easiest to tighten with an impact or air wrench.
Attach the inner joint first.
Are the stock bolts long enough? They look too short? :shrug:
You're supposed to have a cork gasket there to seal the grease in. Otherwise it likes to leak out.
To get the tie rod out you need to remove the cotter pin and nut first, then bang the side of the knuckle where it sits until it pops out.
Make sure you tighten the wheel nut good, if you don't you can damage the wheel bearing.
post Apr 17, 2008 - 11:58 AM
alltracman78
Joined Aug 9, '06
From Ma
Go to this thread, it explains how to get the tie rod out.
DON'T use his example, scroll down to my post, he used the wrong [can damage the tie rod joint] way.
http://www.6gc.net/forums/index.php?showto...&hl=tie+rod
post Apr 19, 2008 - 12:06 AM
6gsillyca
Joined Jan 13, '06
It came with a cork gasket already installed. Will do on the loctite.
I ended up not needing to get the tie-rod end off, but I had previously read your method of hitting the side, and that did not work. Do you need to really hit it good?
Also, when I packed the axle grease, I put most of it inside the "cup". When I turn the wheel, it doesn't turn smoothly. It has lumpy spots.
Lo-Fi Version Time is now: November 27th, 2024 - 5:03 AM
