17 Pages V  < 1 2 3 4 5 > »
> DEATH's GT2 Progress [Updated 01-24-13], 6 years/60k? Miles and FCUKING RIDICULOUS!!!
post Mar 27, 2008 - 2:19 PM
D-Man
Joined Jan 18, '08
From Houston
okay, i got your back on the horn. I cant find the post but i refreshed my memory about the damn thing... I'll help you fix it up today.
Also, did you ever hook up your air bag? I believe it was you with the air bag not plugged in right? If so then that makes life easyer (and safer) to accomplish. biggrin.gif
Damn D-Man - most impressive.
post Mar 27, 2008 - 2:31 PM
DEATH
Joined Dec 19, '07
From tx
QUOTE(95celgt @ Mar 27, 2008 - 2:06 PM) [snapback]658706[/snapback]
I have a complete steering colum with clock spring and switches i can sell u cheap if you need it for the horn//
You won't hook me up with it after I bought the whole damn car? J/k j/k
Is there something I should know about the horn switch? Why isn't it working in the first place? Also the driver's airbag is hooked up properly right? just no passenger side cause it's a '94 right?
QUOTE(D-Man @ Mar 27, 2008 - 2:19 PM) [snapback]658713[/snapback]
that was my thread anyway. The switch gets power and it clicks but just isn't outputting 12v or else I'm checking the wrong wires IDK. I haven't gotten too deep into that stuff as I just now have the luxury of it. I just wired up a simple circuit for in the meantime - now I'm ready to restore that stuff to proper OEM specs.
Nice to know I have the peace of mind and luxury to worry about little sh*t like this finally.
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Mar 27, 2008 - 2:38 PM
D-Man
Joined Jan 18, '08
From Houston
yeah, when you feel safe enough to DRIVE the car (and at night tongue.gif ); and your biggest problem is that you have to push a button instead of your stearing wheel to honk the horn... lol.
I gave up on my horn long ago... i've got to worry about this idol before i give a damn about my horn. That's what i use my neutral for, i make enough noise to get peoples attention laugh.gif
This post has been edited by D-Man: Mar 27, 2008 - 2:38 PM
post Mar 27, 2008 - 2:40 PM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(lagos @ Mar 26, 2008 - 7:47 PM) [snapback]658425[/snapback]
Bingo. You actually supposed to have a factory ground wire there. For some reason yours was missing.
This made me realize something... the stock alltrac has a metal torque bar that bolts from the top of the alt bracket to the chassis of the car. This probably doubles as a really thick grounding point for the whole motor! Since we leave those torque bars off when we swap (wont fit) it wouldn't be a bad idea to add an extra ground wire there.
Btw, dont waste your money on a 200$ apexi grounding it. Its a total rippoff. Just buy more battery wire from the car parts store, like you did and add any grounds you might want.
Give me some time to look through my wiring notes and see whats up with the speedo wiring.
That's not a torque bar that you see there, it is just a motor mount stiffener. It just goes from the alternator bracket to the top of the engine mount (on the motor side, not the chassis side). It wouldn't aid in grounding...
That said, the ground strap on that side of the motor is really important. I'd connect that point to the chassis (not on the strut tower, use one of the bolts for the power steering reservior). The most important ground is on the back of the intake manifold. An extra ground wire there might also help out.
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Mar 27, 2008 - 2:52 PM
DEATH
Joined Dec 19, '07
From tx
QUOTE(phattyduck @ Mar 27, 2008 - 2:40 PM) [snapback]658723[/snapback]
-Charlie
Cool thanks. Where at on the Intake Manifold? You got a pic or anything?
I did actually ground it to the bolt holding the powersteering reservoir down - that's where it's supposed to be huh? Good guess I guess. That other pic was just for testing and illustration purposes but It would have worked perfectly if I had left it there. Moving it to the PSR wouldn't change anything about the way it works - just looks better.
EXT: WRC/TRD/404
post Mar 27, 2008 - 2:57 PM
I guess your right, I always remembered it bolting to the strut tower, but i guess it goes to part of the motor mount. Either way, its there to help the engine not move around as much in the engine bay and eat up motor mounts (like our 6th gen swaps do).
It still bolts to the motor mount, that in turn, bolts to the chassis providing a ground.
post Mar 27, 2008 - 3:14 PM
DEATH
Joined Dec 19, '07
From tx
QUOTE(lagos @ Mar 27, 2008 - 2:57 PM) [snapback]658728[/snapback]
I think he's saying it bolts to the motor side of the mount and since that is basically two peices of metal suspended by rubber it won't provide a ground in addition to stiffening the motor. Why don't or can't we use them? I'd like to not chew through tranny mounts like my last 3s swap did. I have Kirk's mounts tho so maybe it won't be so bad this time. Years ago I had bought the TRD mounts for that old swap - those were a hell of an improvement [that was back when TRD still made parts for us kindasad.gif ]
Any luck finding those notes yet? I'm not rushing you or anything - just curious.
EXT: WRC/TRD/404
post Mar 27, 2008 - 4:21 PM
That bar is the wrong length/size for our cars, so it cant be used.
I used to have to replace motor mounts about once a year with the oems. Now with kirks mounts, I havent had them fail, but as a downside I do have some annoying vibrations from the cabin plastics that I have to figure something out for.
Ill try to sift through the diagrams sometime today. I havent had much free time the past two days.
This post has been edited by lagos: Mar 27, 2008 - 4:22 PM
post Mar 27, 2008 - 4:39 PM
DEATH
Joined Dec 19, '07
From tx
QUOTE(lagos @ Mar 27, 2008 - 4:21 PM) [snapback]658768[/snapback]
No problem - thanks again man.
the old TRD mounts were a nice halfway point point between the smoothness of stock and Kirk's mounts - but I wouldn't trade the performance for the smoothness anyway. To quiet the rattles I would use that spray foam stuff that comes in an aerosol can with a tube sticking out of it. You spray it in where the rattle is and it expands out and dries. Stuff works great for quieting rattles in trunks from systems. You can get it at any good mobile audio store. I'll see if I still have a can left and take a pic of it for you tonight.
EXT: WRC/TRD/404
post Mar 27, 2008 - 4:43 PM
Chanh55
Joined Jun 29, '03
post Mar 27, 2008 - 9:57 PM
alltracman78
Joined Aug 9, '06
From Ma
You sort out the wiring yet?
QUOTE(DEATH @ Mar 27, 2008 - 2:52 PM) [snapback]658725[/snapback]
-Charlie
The ECU grounds [wiring harness] bolt to the underside of the #2 intake runner, as long as the connection is good and the wires aren't damaged [the insulation likes to crack from the angle of the curve of the wire] you can't upgrade it, but you can ground the intake manifold directly to the chassis or to the trans, it won't hurt anything.
That ground strap on the alt bracket is fine bolted to the strut tower. That's the stock location and is part of the chassis. However it normally doesn't bolt to the strut mount stud, it's normally bolted to the side of the strut tower itself.
It does nothing to stop the engine from moving, it only adds bracing to the engine mount itself. Look at how it's positioned, it CAN'T brace the engine in regards to the engine bay, it would have to bolt to the chassis to do that.
And it also physically cannot provide a ground, the engine mount center is rubber. The brace is bolted to the engine side of the mount.
The chassis side [steel sleeve] is insulated from the engine side by several inches of rubber. smile.gif
post Mar 27, 2008 - 10:17 PM
< - 0wned.
All the while I thought it bolted to the strut tower, but its been a while since I had mine on the clip.
post Mar 27, 2008 - 10:57 PM
The ecu has 3 harness plugs. Remove the 3rd ecu plug and look at it with the female end facing you (look at all the plugs this way, when trying to count the pins). Pin9 should have a blue wire with a white stripe on it.
Then you have 3 interior plugs that come from the engine bay harness and plug in to the top/left of your ecu. Located the plug called II2. It should be a white, female plug with 19pins . Located pin 17, it should be an orange wire.
Now connect pin 17 from II2 to pin 9 from from the 3rd ecu plug. This sends a signal from your gauge clusted (through the II2 plug), back to the ecu.
You should now have 1 wire completed.
Now, locate II2 pin 10. It should be a blue wire.
Now locate plug IG2, pin3, Blue wire with a black stripe and connect it to the II2 pin10, blue wire.
IG2 should be a gray male plug with 20pins. If i remember correctly, this plug is just part of your harness and connects to a female version of itself. Someone correct me if im wrong, I dont have my book in front of me.
you should now have 2 wires completed
Located plug II1. It should be gray female plug with 13 pins, next to your II2 plug.
Find pin 12. It sould be a red wire with a blue stripe.
Connect it to plug IG2, pin 4 AND pin 15. so basically, 2 wires connected to 1, to form a Y.
You should now have 3 wires completed.
Located II1, Pin 13, blue wire with black stripe.
Connect it to IG2, pin 12, blue wire with yellow stripe.
You should now have all 4 wires hooked up, and your speedo should work.
This post has been edited by lagos: Mar 27, 2008 - 11:36 PM
post Mar 28, 2008 - 1:22 AM
95celgt
Joined Oct 5, '03
From South TX.
to be honest i dont know jack about how the horn works or how the airbag system works.
All 3 celicas i had never had a working horn and never cared to fix them, i was just suggesting some parts i have lying around...i have a celica shop in the attic lol
I bought the steering wheel/air bag and dash all new and well i removed the passenger airbag for weight....i dont know if the driverside would funcion or anything.
i included quite a bit of important freebies with the car remember lol, besides, at this point your only half of the way to the amount of money i put into the car:)
post Mar 28, 2008 - 2:26 PM
DEATH
Joined Dec 19, '07
From tx
QUOTE(lagos @ Mar 27, 2008 - 10:57 PM) [snapback]658980[/snapback]
Dude Lagos you're the man. If you ever need anything from me - just ask.
I'll get started on that as soon as I finish going over the doors to make sure everything is perfect - I already started so may as well finish. When I'm done with this car there won't be a single thing I haven't inspected and put to stock [except under the hood of course]
QUOTE(95celgt @ Mar 28, 2008 - 1:22 AM) [snapback]659017[/snapback]
I know man I was just playing. I got the rest of the missing parts the other day when Havok took me to that parts car. It would make a good shell if you're still looking but I think the towing would kill that.
EXT: WRC/TRD/404
post Mar 29, 2008 - 9:32 AM
DEATH
Joined Dec 19, '07
From tx
Shes getting her first oil change today: Mobile1 Fully Synthetic with TRD filter [got a deal on 2 for $10 so why not?]. I've spent most of the morning tightening the many loose screws I found underneath.
Question: Since I did the A/C delete is there any reason why I can't remove the heat exchanger between the Radiator and the FMIC [used to cool other sh*t etc]? Reason being I am going to install my Koyo Radiator and it has the big Koyo Logo on the front that you can't see cause of the heat exchanger, plus it's just dead weight if all it does is get rid of a/c heat and I have no a/c. I know it's probably a waste of time to most people but I like to see that kind of stuff - especially on a $350 part biggrin.gif
I hope to start the Speedo thing tomorrow morning.
This post has been edited by DEATH: Mar 29, 2008 - 9:33 AM
EXT: WRC/TRD/404
post Mar 29, 2008 - 12:05 PM
QUOTE(DEATH @ Mar 29, 2008 - 10:32 AM) [snapback]659471[/snapback]
yup, you can pull out all that stuff if you want to. condenser, lines ect.
post Mar 29, 2008 - 5:33 PM
DEATH
Joined Dec 19, '07
From tx
Sweet - thanks. Today I did the oil change and tried to track down a coolant leak [The Overflow container had a hole in it - all that search and it's always simple rolleyes.gif ]. I finished rebuilding all the door panel back to stock and rattle free. Then I decided to indulge basic creature comfort and installed my new Boston Acoustic SX60 components along with my old components in the rear - sounds so beautiful.
I tightened a ton of loose bolts underneath the car and got the trunk plastics in right and rattle free. The cars nicer to drive without all the rattles.
It's been a good day for the car.
I'll start the speedo thing tomorrow to give me all week to get parts if necessary [doesn't sound like it should be]. Next week I'll pull the front bumper off and install the radiator, crash bar and pull that heat exchanger out.
This post has been edited by DEATH: Mar 29, 2008 - 5:35 PM
EXT: WRC/TRD/404
post Jun 18, 2008 - 7:36 AM
DEATH
Joined Dec 19, '07
From tx
OK - Been a couple of months since I updated this. Here goes:
-Finished removing A/C lines and condensor
-Mounted the FMIC Properly/Straightened the front end
-Fixed all ground related issues
-Found and Fixed numerous wiring issues [Found bare 12v wire dangling above ECU that would short to the ECU case - WTF rolleyes.gif ]
-Continued replacing all vac lines with quality silicone hosing [still a few more to go]
-Fixed all but one small coolant leak [will be knocking that out next time I'm under the car]
-Replaced all couplings with 4 Layer [9 if you count the silicone inbetween] reinforced type and SS T-Bolt clamps
-Installed AEM UEGO Wideband o2 Sensor/Gauge/Controller
-Installed 2sRus MBC and bumped the boost up to 10PSI [Holy fcukin monkey nuts what a difference from 5PSI]
Still left to do:
-Hook up aftermarket water temp and oil pressure gauges
-Buy and install EGT gauge [Probably GReddy - may be purchasing today]
-Install Koyo Racing Radiator
-Buy/install electric exhaust cutout after downpipe
-Install Magnaflow high flow cat [Bought but not installed yet]
-Install windshield washer reservoir/pump [Bought but not installed yet]
-Fix horn wiring
-Fix speedo wiring [Thanks Lagos - yes I know I'm slacking but I'll do it when I do the next step:
-Install SAFC-II
-Loom up all the new wiring I've installed nicely and semi-permanently
-Dyno tuning
Now I have some questions:
1. The AEM Wideband reads between 14.5 to 15.2 at idle, will drop into the 11.0+ range under hard boost. For the most part I never see the red lights light up except right when I shift and it'll either jump to 16.0+ for just a second or it will show ---. Is this normal or something I should be concerned with?
2.
-will be updating/adding more throughout the day as time allows [I am supposed to be working here]
This post has been edited by DEATH: Jun 18, 2008 - 8:48 AM
EXT: WRC/TRD/404
post Jun 18, 2008 - 9:33 AM
Everything is working normally.
You should see 14-15 at idle or cruise (this tells you your o2 is working correctly)
Under boost, you want to see around 10-12afr. Mid 11s is ideal.
When you let your foot off the gas (like when you shift), the afr should jump all the way lean.
Turn you boost up! At the VERY least, you should be at 13psi with your fuel cut disabled.
Lo-Fi Version Time is now: November 29th, 2024 - 8:13 AM
