ATTN: people considering 7th gen brake swap |
Mar 27, 2008 - 1:39 PM |
Enthusiast Joined Jul 2, '06 From Shrewsbury, ma Currently Offline Reputation: 5 (100%) |
Anybody considering doing the front brake swap from the 7th gen should read this... considering I beat the hell outta my car, and I'm starting to rack up the miles, and it's getting about time to think about doing my brakes again, I figured, hey why not replace the calipers before I need 2... so while im at it.. why not use the 7th gens parts. Seemed harmless till I acctually tried to order the parts.... according to Advance Auto parts computers, from 2000 n up the 7th gen gts use the same caliper... but theres a slight variation in the part numbers for the semi-loaded calipers (caliper with bracket) thru the years.....
the 1st one on the left is from the 2000 model.... the middle is for my 97 GT.... and the one on the right is from a 2003 GTS.... I'm using the one from the 2003 because it seems 2 give the most room n still line up, as I'm not sure if there will be any kind of interference... here is a closer look at the difference in the brackets between the 2000 and 2003 The part numbers for the 2003 (the caliper on the right) are Cardone: 19-B2580A 19-B2581A and can be bought at n e Advance, or at least interchanged at n e other self respecting part store... I think I also read somewhere on here that this only works for an ST... or that the GT brakes are the same size as the 7th gen, but this is wrong, as there were both rotors in stock n I definatly pulled out the tape measure..... |
Mar 28, 2008 - 11:50 AM |
Enthusiast Joined Sep 26, '07 From iowa Currently Offline Reputation: 1 (100%) |
well keep us updated man i have been wanting to do a 6th gen 7th gen mix with 7th gen front and rear seats rims and tires brakes and other random things all put on/in my 97 st so if the brake swap only works for st like you said u thought u read some were. thjats good news for me
-------------------- -Boss III
Mar 28, 2008 - 9:02 PM |
sure thing, I'll prolly document the whole thing for people who have nothing to do but read lol.... the only trick now, getting around 2 ordering the rest of the parts, then finding the time to do it lol... I'm actually ordering an ST caliper with bracket to verify wat works so check back soon
Mar 28, 2008 - 9:14 PM |
good work man, keep the pics comin!
13.6@108MPH, 5SFTE Powered |
Mar 28, 2008 - 10:27 PM |
do the bolt holes on the torque plates (caliper brackets) line up the same on the 2000 and 2003 ?
and are the actual pistons of the 6gen and 7gen calipers the same size/diameter ? -------------------- |
Mar 28, 2008 - 10:39 PM |
Enthusiast Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
Nice questions. I've always wondered about the size difference of our gt pistons compared to a 7th gen gts.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Mar 30, 2008 - 2:28 AM |
yes, the bolt holes all lined up, the 97 00 and 03... as far as the piston goes I'll have 2 measure, but if i remember from eyeballing it, they were very similar... it seems the only thing ur really gaining from the swap is surface area from the larger rotor, and after-market part choice/availability..
Mar 30, 2008 - 11:00 PM |
k.. went and did some measuring... the piston from the 6th gen GT and the '03 GTS are the same size, or at least within a millimeter or 2 as the boot kept getting in the way...
I took a look at the rotors as well... the rotor on the left is for my 97 GT and measures about 10 inches (55mm) in diameter... while the one on the right is for the '03 GTS and measures about 10 3/4 inches (74mm) both look to sit the same in thickness and both share the same hub section leaving the ONLY difference the diameter... that means they fit on the hub, no dremel required... There was an error in shipment for the ST parts so still waiting for those... Ill let u guys know when they finally come in I'm planning on using a slotted rotor, but for anybody that is interested in factory spec replacement... Bendix number: '97 GT : 145009 '03 GTS : 145294 This post has been edited by woatherekilla: Mar 30, 2008 - 11:18 PM |
Mar 30, 2008 - 11:12 PM |
Nice! Looks like I'll just purchase the 7th gen rotors and see what differences that will make.
Mar 30, 2008 - 11:41 PM |
QUOTE(bccentaur3 @ Mar 30, 2008 - 11:12 PM) [snapback]659914[/snapback] Nice! Looks like I'll just purchase the 7th gen rotors and see what differences that will make. that won't work, you'll need the 7th gen calipers as well, the piston is the same size, but the actual bracket is a little longer to accommodate the bigger rotor. -------------------- |
Mar 31, 2008 - 12:03 AM |
Zut!!! I gues I'll check the wrecking yards.
Apr 7, 2008 - 11:02 PM |
k.. little bit of an update... I ordered a caliper and a rotor for a 96 ST... matched the bolt holes to the calipers I already have, and TADA.. definatly the same ....the only thing throwing me off now is the rotor... when I matched it up to the rotor for the '03 GTS, it was the same diameter, but a little thicker... so thinking that I may have ordered the wrong rotor I started checking part numbers for 6th gens... It may jus be the way it was listed for Advance, but it seems that which rotor is which bounces between the years.. so I guess I'm gonna hafta jus measure the rotor that comes off the car when i finally get around 2 doing it 2 make sure..
Jun 7, 2008 - 12:54 AM |
Enthusiast Joined Apr 24, '04 From S. Cali Currently Offline Reputation: 0 (0%) |
no update on this???
Jun 7, 2008 - 1:08 AM |
Enthusiast Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
no update on this??? what did you need to know? http://www.6gc.net/forums/index.php?showto...5707&hl=7th |
Jun 12, 2008 - 9:25 AM |
Enthusiast Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) |
So basically other than aftermarket support there seems to be no point in doing this. The rotor surface appears to be .375 bigger in radius [from his/her measurements] but I want somone to measure the actual used part of the rotor - much of the rotor's surface may not be used and we may find this is not really an upgrade at all Only way to tell would be to measure the worn portion of 7th gen GTS vs the worn portion of a 6th Gen GT/GTS.
Any difference in clamping force of the 7th gens? Someone just swapping out their old 6th gen calipers for new anything will think so but do we actually have any numbers to back this up? This post has been edited by DEATH: Jun 12, 2008 - 9:25 AM -------------------- ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Jun 12, 2008 - 10:31 AM |
It was discussed in the other thread that it was more of an upgrade for ST guys.
Jun 12, 2008 - 10:45 AM |
OK I see that. Plus they have options for big brake kits - thanks for the heads up.
Lo-Fi Version | Time is now: November 29th, 2024 - 9:28 AM |
