> oil in my hood
post Mar 28, 2008 - 2:27 PM
pabel89
Joined Sep 28, '07
From new jersey
hey just 3 days ago i been noticing thier like oil in the inside of my hood, so i cleaned it up and ran the car again , and thier it was again oil on my hood. but the wierd thing is thier inst any on my engine?
post Mar 28, 2008 - 2:30 PM
tankd0g
Joined Oct 4, '07
From Nova Scotia
QUOTE(pabel89 @ Mar 28, 2008 - 2:27 PM) [snapback]659181[/snapback]
PCV pop off the head head due to being clogged maybe?
post Mar 28, 2008 - 2:31 PM
DEATH
Joined Dec 19, '07
From tx
Is it in a line front to back situated on the left hand [pass] side directly over the belts? This is very common and just means one of your seals has started to leak and the belts are throwing oil on the hood and firewall. Don't sweat it - they start doing that with pretty low mileage and it's not usually alot - just keep an eye on how much oil your engine uses to determine if it's excessive or not. wink.gif
Hope this helps
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Mar 28, 2008 - 2:49 PM
pabel89
Joined Sep 28, '07
From new jersey
thanks alot i really apreciate it, im a see if i change all my seals by monday. thank you
post Mar 28, 2008 - 3:02 PM
DEATH
Joined Dec 19, '07
From tx
Was it in a pattern like I described?
EXT: WRC/TRD/404
post Mar 28, 2008 - 3:07 PM
pabel89
Joined Sep 28, '07
From new jersey
its just like a big splash in the center.
post Mar 28, 2008 - 3:14 PM
DEATH
Joined Dec 19, '07
From tx
hmmm - that doesn't sound like wat I was talking about. You need to get that figured out before you starve your engine.
EXT: WRC/TRD/404
post Mar 28, 2008 - 3:18 PM
tankd0g
Joined Oct 4, '07
From Nova Scotia
Is it running crappy? Might have a loose spark plug.
post Mar 28, 2008 - 3:30 PM
alltracman78
Joined Aug 9, '06
From Ma
How about you post a GOOD pic of the oil splash [the whole underside of the hood] and one of the engine bay and let's see what we can find.
post Mar 28, 2008 - 3:38 PM
pabel89
Joined Sep 28, '07
From new jersey
im a take the pic tommrow, and no its actually running pretty good the turbo spooling up nicely, its running ok.
post Mar 28, 2008 - 4:37 PM
alltracman78
Joined Aug 9, '06
From Ma
Ahh, you have a turbo.
I saw GT with no 5SFTE mentioned....
Your BOV/BPV is venting the oil from your PCV system.
Which means you have a lot of blowby. Normal on turbo cars, to an extent. Yours sounds a bit excessive.
Most likely either you have worn compression rings or the PCV system is clogged.
Or your turbo is leaking out the intake seal.
post Mar 28, 2008 - 4:43 PM
QUOTE(alltracman78 @ Mar 28, 2008 - 5:37 PM) [snapback]659254[/snapback]
jeremey, he dont have a GT, he has an ST, (7afe, 1.8L)
pics are needed.
post Mar 28, 2008 - 4:56 PM
alltracman78
Joined Aug 9, '06
From Ma
I didn't bother to go back and check, I "remembered" seeing GT.
Pics will help, but if he's got a turbo, that's the most likely source, it was my first thought, but I didn't see any mention of a turbo so I didn't bother....
This post has been edited by alltracman78: Mar 28, 2008 - 4:56 PM
post Mar 29, 2008 - 2:53 PM
pabel89
Joined Sep 28, '07
From new jersey
i find my problem, my turbo is shot, also the intercooler pipe that attaches to the turbo wasnt thier when i went to check it out this morning. thier was oil inside the intercooler pipe also. i need a new turbo= (
Lo-Fi Version Time is now: November 27th, 2024 - 12:22 AM
