> seat belt sensor!
post Apr 1, 2008 - 7:26 PM
pabel89
Joined Sep 28, '07
From new jersey
hey some of you know i installed aftermarket seats in my car, so i got a 4 point harness seat belt for my car. im not using my factory seat belt, so my seat belt light is on. what would i have to disconnect to take that sensor off. i took off the wire under my seat which connects to the seat belt but its still on?
post Apr 1, 2008 - 7:31 PM
Jaws4God
Joined Mar 27, '04
you just have to connect the two wires together.. I did that for a while when I had 4 point harnesses, you just have to complete the circuit.
This post has been edited by Jaws4God: Apr 1, 2008 - 7:32 PM
post Apr 1, 2008 - 8:10 PM
pabel89
Joined Sep 28, '07
From new jersey
which two wires the one before the connector or the ones after?
post Apr 1, 2008 - 9:22 PM
mneal2_92788
Joined Nov 7, '06
From Lawrence IN, 46226
it wont matter, the connector is just and extention really, so either or.
post Apr 2, 2008 - 4:09 AM
stevest202
Joined Oct 28, '07
From epworth uk
if you do it after the connector you can revert back later easier
post Apr 2, 2008 - 9:23 AM
DEATH
Joined Dec 19, '07
From tx
Or you could just pull the bulb in the GC however your airbag will not go off like that or with your current setup if everything is working right.
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Apr 2, 2008 - 1:33 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
i could be wrong but i'm almost 100% sure the airbag is not run at all through the seat belt indicator.... newer model toyotas do that with the passenger seat but driver seat airbags will always deploy....
Breaking Axles...
Lo-Fi Version Time is now: February 20th, 2025 - 12:08 AM
