![]() Enthusiast ![]() Joined Dec 14, '02 From USA, NC Currently Offline Reputation: 0 (0%) ![]() |
i was wondering if this would fit in my car, i have 1994 celica GT, ST204 with the 5S-FE, would this fit in my car 3SGTE 2ND GEN w/ 2ND GEN HEAD / FORGED TURBO PISTONS W/ CORE EX.
how well would this fit in my car and what else does it require....heres the site where i found it at....http://www.toysport.com/ENGINE%20LIST%20MARCH%202002.htm if this wont fit what will? |
![]() Enthusiast ![]() ![]() Joined Aug 29, '02 From New Jersey Currently Offline Reputation: 0 (0%) ![]() |
Yes that engine will bolt up to your stock transmission and your engine mounts. Several people have done a 3sgte swap or are in the process of doing so on celica.net. You should check out that site. I would suggest getting a full clip instead of just the engine because it becomes a pain to source all the little parts you will need for the swap. Go to www.celica.net and check out the sticky post in the 6th gen forum you can also use the search feature since this post has been covered extensively there.
where do i get a full clip and how much???
![]() Enthusiast ![]() ![]() ![]() Joined Nov 12, '02 From Columbus, Ohio Currently Offline Reputation: 15 (100%) ![]() |
I wouldnt' get it from toysport they are too expensive. Try Johnnie Morris(at JEMCO), or Mike Coury at www.topshelfracing.com
I suggest getting one that is already in the county so it doesn't take too long. Buy a front clip. $2500 or less here's some info www.topshelfracing.com/project/ www.geocities.com/zegoat2000/homepage.html |
i need info on a GT swap not a ST
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) ![]() |
actually with a GT you really dont need a full clip, you really just need the ECU and wiring harness, saves some cash... STs are the only ones who would truely benifit from the full clip. -------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
the benefit of getting a full clip is you can get the AWd tranny and rear differential and have everything you need for your car to release the full potential of this engine
Enthusiast ![]() Joined Dec 25, '02 From The Netherlands Currently Offline Reputation: 0 (0%) ![]() |
1GGZE 2000CC 6 CYLINDER 24 VALVE SUPERCHARGED UNDER 10K $ 1,950.00
^question: how much horsies and torque does this sucker make and will it fit in a 6th gen? |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 4, '02 From Davenport Iowa Currently Offline Reputation: 0 (0%) ![]() |
This isn't entirely true... granted you pretty much do need a full clip for an ST swap and you can get buy without it on the GT...I did. but the clip would of been so much nicer to have... wouldn't need to relocate stuff. -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
Enthusiast ![]() Joined Dec 20, '02 From New York Currently Offline Reputation: 0 (0%) ![]() |
I have a auto 1995 GT. Can I still put in a 3sgte? I want third generation and I want AWD on it if possible. Is that possible?
Lo-Fi Version | Time is now: February 21st, 2025 - 12:26 PM |
